    D5 Render Work
    95 Posts 12 Posters 16.1k Views 12 Watching
    • pixelcruncherP
      Great work! Very realistic renders.
      • marked001M
        marked001
        cafe render...
        http://www.revision21vis.com
        instagram: revi21on
        • ntxdaveN
          ntxdave
          Nice πŸ‘ πŸ‘ πŸ‘
          I wish I could come up with something like this. πŸ˜„
          Press F1...thank me later
          • marked001M
            marked001
            Its all the software! Very easy to get good results.
            instagram: revi21on
            • ntxdaveN
              ntxdave
              I meant coming up with the model itself. I don’t seem to be able to design something like this. Yes, once designed the render engines are making it somewhat easier to come up with good renders.
              I like your results. πŸ‘ πŸ‘
              • marked001M
                marked001
                Well I definitely do not design the majority of the stuff I post. Some when its conceptual and there isn't actually a design or when we're working through a design. But for the most part, these are all other's designs.. in case that wasn't clear.
                instagram: revi21on
                • ntxdaveN
                  ntxdave
                  Thanks for the reply. Where do you find stuff like this (and your other neat scenes/models)?
                  • marked001M
                    marked001
                    99% of this stuff is paid work so comes from the architect, designer, broker, etc. Sometimes its just a plan and some photo reference of what they want, sometimes plans and elevations and complete finishes.
                    instagram: revi21on
                    • ntxdaveN
                      ntxdave
                      OK, now I understand. πŸ˜„ πŸ˜„
                      • Bryan KB
                        That cafe is excellent! πŸ‘
                        • marked001M
                          marked001
                          Thanks Bryan.
                          Here are some conceptual images for a set build of a high end upper west side apartment for a tv show. They're a weird format because that's the aspect ratio the show is being shot in.
                          instagram: revi21on
                          • L
                            Beautiful Mark great style and modelling, and I like that aspect ratio. cinematographic πŸ‘
                            • marked001M
                              marked001
                              Its definitely odd to try to use indoors and see as much as you can. 2:1...I guess its a compromise between 4:3 and 16:9
                              instagram: revi21on
                              • Bryan KB
                                Those set mock-ups turned out really good! πŸ‘
                                  Very nicely done, worth a raise. πŸ‘
                                  • marked001M
                                    marked001
                                    Its Union work.. so a raise is out of the question for a few years.. haha.
                                    Object moved
                                    (www.usa829.org)
                                    instagram: revi21on
                                    • marked001M
                                      marked001
                                      quick one from friday afternoon. addition to an existing house.
                                      One thing I like over Lumion, with D5 is that this is straight out of D5 with no post processing. Obviously I 'should' probably spend a little time, but sometimes there just isn't time available. But with Lumion I was always forced to do some post processing to get it where I want it.
                                      instagram: revi21on
                                      • ntxdaveN
                                        ntxdave
                                        I really like this one. πŸ‘ πŸ‘ πŸ‘
                                        • marked001M
                                          marked001
                                          A couple more from last week from the show I'm working on.
                                          instagram: revi21on
                                            @marked001 said:
                                            Thanks! A couple more from last week from the show I'm working on.
                                            The lighting is great. Everything is great. But the lighting is really nice.
                                            The subtle noise patterns really breaks up the textured walls.
                                            • 2 / 5
