    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 917.2k Views 122 Watching
      You need to save the license file[s] somewhere sensible - I use a special licensing folder in my Documents.
      Then you validate the license for that extension by using the validate button etc in the Tools > Fredo6 Collection > ExtensionName > License... submenu for that extension, which opens a dialog...
        PS: Also make sure that you have installed the latest version of the extension, LibFredo6 and the SketchUcation toolset [for the licensing], and have restarted SketchUp...
          mstumpo
          Tools On Surface not displayingOK, I got past this and all appears good. However, the toolbar for Tools On Surface is blank on my screen. In fact, any plugin that uses on-screen options shows as blank. Nvidia driver issue? see attached.
          • fredo6F
            NEW RELEASE: FredoTools v4.5a - 02 Apr 24
            Requirement:
            • LibFredo6 v14.3b or above
            FredoTools 4.5a is a maintenance release for:
            • Future compatibility
            See FredoTools plugin home page for Download.
            See also main post of this thread for User Discussion.
            yanrothwellY 1 Reply Last reply
            • yanrothwellY
              yanrothwell @fredo6
              @fredo6 Hi I have used Fredo6's tools for manyt years and they are always super useful.
              At present, since SU2024 I have had issues with SUClock, which I stopped using whilst it was updated.
              I've since started using SUClock since the update and its been working fine.
              Today I started up SU2024 with an existing project (double clicking on the skp file itself, incase that is ever relevant how I 'opened up' the file) and I got the following error.
              This error hasn't gone away and did not start working up next restart of SU2034, so I wonder if you can help - Screenshot 2024-06-04 104337.png
              I see the icon of SUClock but it does nothing when clicked on.
              Multiple restarts have not fixed anything. There are similar errors with ThruPaint and Toposhaperm unforrtunately. Can anyone help? plugin information as follows:
              Fredo6 Plugins Information on 2024-06-04 12:00:59 +0100
              • Sketchup: 24.0.484
              • LibFredo6: v14.5b
              • LibFredo6 Binary loaded
              • Sketchucation ExtensionStore: 4.4.0
              • SCFLicense: v6.4a - 74
              • Fredo6 Plugins
                LordOfTheToolbars v2.7b
                Curviloft v2.0a - licensed FULL
                Curvizard v2.5a
                FredoCorner v2.7a - licensed FULL
                FredoScale v3.6a - licensed FULL
                FredoTools v4.5a
                JointPushPull v4.8a - licensed FULL
                SUClock v3.1a
                ToolsOnSurface v2.6a - licensed FULL
                TopoShaper v2.7a - licensed FULL
                Signature File: 2022-03-30 14:03:14 +0100
                ClothWorks: 2022-10-27 15:42:55 +0100
                Curviloft: 2022-09-03 15:21:17 +0100
                FredoCorner: 2024-03-04 13:57:21 +0000
                FredoScale: 2022-04-25 11:42:35 +0100
                FredoSpline: 2022-11-21 16:26:56 +0000
                JointPushPull: 2022-05-08 14:44:25 +0100
                ToolsOnSurface: 2022-04-25 13:46:45 +0100
                TopoShaper: 2022-09-02 16:10:20 +0100
              MrHide_1.8a
              AutoInstall Finished.
              Using Main Plugins Folder.
              C:/Users/<user>/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins
              http://www.ianrothwell.co.uk
              fredo6F 1 Reply Last reply
              • fredo6F
                fredo6 @yanrothwell
                @yanrothwell
                Did you install SU2024 with 'Run as dministrator'?
                • yanrothwellY
                  yanrothwell @fredo6
                  @fredo6 yes
                  • fredo6F
                    fredo6 @yanrothwell
                    @yanrothwell
                    Could you open the Ruby console and copy paste the following command, and then type Enter:
                    UI.openURL F6_SUClock::Project.get_tmpdir
                    This will open the temp directory, in which you have files with extension .txt and a form like XXX__YYY.txt.
                    Just erase them. It seems that one of them is corrupted.
                    Erasing them should not impact your SUClock data.
                    Then restart Sketchup.
                    • yanrothwellY
                      yanrothwell @fredo6
                      @fredo6 Many thanks - after doing just that and restarting, it worked. no errors upon startup.
                      Cheers \o/
                      • fredo6F
                        NEW RELEASE: FredoTools v4.5c - 24 Jun 24
                        Requirement:
                        FredoTools 4.5c is a maintenance release for:
                        • Fix for the caluclation of volumes in SolidVolume
                          rv1974
                          a true Doh! moment - Angle Inspector has Slope meter in %% ! Many many thanks, Fredo.
                          P.S. Maybe one day it would become interactive - showing live the slope altering.
                          • fredo6F
                            NEW RELEASE: FredoTools v4.6a - 21 Oct 26
                            Requirement:
                            • LibFredo6 v16.3b or above
                            FredoTools 4.6a is a maintenance release for:
                            • Compatibility SU2027
                            • Fix along with LibFredo6 v16.3a
                              romelsantiago0892 Newcomers
                              We have a lincense of the fredo tools knowing that thru paint is bundled together with it, but then the Thru paint has seperate lincense today, how will we be able to activate the thru paint if that is now seperated. kindly need Help.
                              • 20
                              • 21
                              • 22
                              • 23
                              • 24
                              • 24 / 24
