    Rayscaper Alpha Version Available
    114 Posts 14 Posters 19.7k Views 14 Watching
    • pixelcruncherP
      @majid said:
      I am getting better at it.
      Ooh very nice, always happy to see renders made with Rayscaper. Keep them coming!
      • jo-keJ
        jo-ke
        I've sent you the file with the cabinet, to inspect.
        http://www.zz7.de
        • ntxdaveN
          ntxdave
          I would like to suggest that RayScaper reach out to thr Twilight Render team and see if it would be possible for the two teams/companies work out some type of merger/get together. TR has announced a “sunset” although they have had a great product and excellent support team. Looking at where RayScaper is headed and where TR has been, it seems like they could possibly come up with a great product with a great support team.
          Just to let you know, I have made the same proposal to the TR team.
          Press F1...thank me later
            • ntxdaveN
              ntxdave
              One more suggestion: start a forum. Maybe it is too early though. 😉
              • pixelcruncherP
                @jo-ke said:
                I reinstalled rayscaper on my notebook.
                I reopend the test file, that I made yesterday, but most of material are lost.
                The file is saved in my dropbox.
                So this one worked after refreshing the HDRI? Still I think that’s a bug, Rayscaper shouldn’t have amnesia and forget about your configuration.
                If this happens again, would you mind sending the log? That should give me a clue of why it failed to load the HDRI.
                Thanks,
                Thomas
                • jo-keJ
                  jo-ke
                  http://www.zz7.de
                  • jo-keJ
                    jo-ke
                    OK, I've found out: HDR has to be refreshed.
                    The tramwaymodel renders well exept the blue surfaces.
                    http://www.zz7.de
                    • pixelcruncherP
                      Thanks jo-ke for reporting. I can reproduce this bug locally and plan to have a release this week that fixes this bug, and the umlaut crash.
                      Regards,
                      Thomas
                        SandraEli Newcomers
                        Please keep us posted when the Mac OS version is out
                        I want to test it so bad
                        • pixelcruncherP
                          Hey SandraEli,
                          Thanks for the interest! A Mac version is in the works, but the primary focus is to remove the alpha label and release a rock-solid Windows version.
                          I will keep you posted when the Mac version is out.
                          Cheers,
                          Thomas
                          • majidM
                            majid
                            This is great that there are plenty of free materials available in Rayscraper, but wondering how may I change their scale or rotation. Am I missing a tutorial/description?
                            • pixelcruncherP
                              Hey Majid,
                              You are right. Documentation and tutorials still need to be added for Rayscaper.
                              There are two ways to change the placement of a texture on a material.
                              You can edit the UV transformation of the textures individually or use the global UV editor to edit all textures for a material in parallel.
                              Edit individual textures
                              You can do this by opening the texture settings assigned to the slot, for example, in the below image for the Color slot. And then, modify the transformation; it updates in real-time, so you should be able to eyeball it.
                              Edit all textures of a material
                              Or you can edit all textures for a single material simultaneously using the Global UV editor. This one can be opened via the edits menu at the top of the material.
                              I hope this helps. Let me know if it's not clear, then I can make a quick video.
                              Better documentation and tutorials will arrive soon.
                              Cheers,
                              Thomas
                                sashapepperspray
                                is there a way to pan or zoom on the rendered image in the render viewport?
                                • pixelcruncherP
                                  Not there yet, but it’s on the roadmap for the 1.0 release.
                                  Cheers,
                                  Thomas
                                  • majidM
                                    majid
                                    I was really busy recently doing my project. Just installed the latest version and tried it using the previous model. The toolbar does not show and when I start rendering many materials are missed and had to reload them manually. Also it seems slower to me...Maybe it is because my laptop is old and the GPU needs an update...
                                    I will keep an eye on this post and pray for fast updates 😄
                                    • pixelcruncherP
                                      Hey Majid,
                                      Which version are you using?
                                      You can get the toolbar back with this: https://rayscaper.com/manual/user-interface/#i-lost-my-toolbar - I renamed the title of the toolbar in a previous release, hence the reason it disappeared.
                                      Can you share the log and scene where the materials went missing? The log is named SUEX_Rayscaper.log, see item 5 here on how to get it: https://rayscaper.com/getting-help/report-a-bug/
                                      What is slower? Do the render times or the user interface feel slower? If it's slow, I consider that a bug 💚
                                      I will be releasing Rayscaper on a more frequent cadence now, have to get to 1.0.
                                      Cheers,
                                      Thomas
                                      • majidM
                                        majid
                                        I did a clean installation, yet the toolbar is missing..
                                        I think the denoiser refresh is less frequent maybe ...
                                        • pixelcruncherP
                                          I replied to your message, I need some more info.
                                          Cheers,
                                          Thomas
                                          • majidM
                                            majid
                                            Thanks THomas. Just replied to it.
                                            • 4 / 6
