    Rayscaper Alpha Version Available
    114 Posts 14 Posters 21.8k Views 14 Watching
    • pixelcruncherP
      @sandraeli said:
      Please keep us posted when the Mac OS version is out
      I want to test it so bad
      Hey SandraEli,
      Thanks for the interest! A Mac version is in the works, but the primary focus is to remove the alpha label and release a rock-solid Windows version.
      I will keep you posted when the Mac version is out.
      Cheers,
      Thomas
      • majidM
        majid
        This is great that there are plenty of free materials available in Rayscraper, but wondering how may I change their scale or rotation. Am I missing a tutorial/description?
        • pixelcruncherP
          Hey Majid,
          You are right. Documentation and tutorials still need to be added for Rayscaper.
          There are two ways to change the placement of a texture on a material.
          You can edit the UV transformation of the textures individually or use the global UV editor to edit all textures for a material in parallel.
          Edit individual textures
          You can do this by opening the texture settings assigned to the slot, for example, in the below image for the Color slot. And then, modify the transformation; it updates in real-time, so you should be able to eyeball it.
          Edit all textures of a material
          Or you can edit all textures for a single material simultaneously using the Global UV editor. This one can be opened via the edits menu at the top of the material.
          I hope this helps. Let me know if it's not clear, then I can make a quick video.
          Better documentation and tutorials will arrive soon.
          Cheers,
          Thomas
            sashapepperspray
            is there a way to pan or zoom on the rendered image in the render viewport?
            • pixelcruncherP
              Not there yet, but it’s on the roadmap for the 1.0 release.
              Cheers,
              Thomas
              • majidM
                majid
                I was really busy recently doing my project. Just installed the latest version and tried it using the previous model. The toolbar does not show and when I start rendering many materials are missed and had to reload them manually. Also it seems slower to me...Maybe it is because my laptop is old and the GPU needs an update...
                I will keep an eye on this post and pray for fast updates πŸ˜„
                • pixelcruncherP
                  Hey Majid,
                  Which version are you using?
                  You can get the toolbar back with this: https://rayscaper.com/manual/user-interface/#i-lost-my-toolbar - I renamed the title of the toolbar in a previous release, hence the reason it disappeared.
                  Can you share the log and scene where the materials went missing? The log is named SUEX_Rayscaper.log, see item 5 here on how to get it: https://rayscaper.com/getting-help/report-a-bug/
                  What is slower? Do the render times or the user interface feel slower? If it's slow, I consider that a bug πŸ’š
                  I will be releasing Rayscaper on a more frequent cadence now, have to get to 1.0.
                  Cheers,
                  Thomas
                  • majidM
                    majid
                    I did a clean installation, yet the toolbar is missing..
                    I think the denoiser refresh is less frequent maybe ...
                    • pixelcruncherP
                      I replied to your message, I need some more info.
                      Cheers,
                      Thomas
                      • majidM
                        majid
                        Thanks THomas. Just replied to it.
                          sashapepperspray
                          two questions
                          are bump maps (height maps) planned to be added for materials?
                          are cutting components going to be supported (once hidden objects are)?
                          thank you for your work.
                          • pixelcruncherP
                            two questions
                            Yes, bump maps will be in the upcoming 1.0 release.
                            Are you referring to section cuts? They are planned for the 1.x release.
                            The Rayscaper roadmap is here: https://rayscaper.com/manual/roadmap/
                            Cheers,
                            Thomas
                            • ntxdaveN
                              ntxdave
                              Thanks for sharing. πŸ˜„
                              Press F1...thank me later
                                sashapepperspray
                                I am talking about components that glue to face and cut an opening
                                • pixelcruncherP
                                  Do you mind posting an example to help me understand better?
                                  Thanks,
                                  Thomas
                                  • jo-keJ
                                    jo-ke
                                    that looks much better
                                    saving in a folder containing "ΓΌ" is not possible yet it caused this error:
                                    http://www.zz7.de
                                    • pixelcruncherP
                                      Thanks for reporting! This will be fixed in the next release.
                                      Cheers,
                                      Thomas
                                      • F
                                        fakebob
                                        Hi! This software shows so much promise! I'm excited more than when I first got kerkythea waaaaay back.
                                        I downloaded the newest alpha 0.8.4 today because the 0.8.3 one just crashed my 2023 sketchup pro on either:
                                        a) adding a sketchup texture/colour to a face or
                                        b) opening the Rayscaper Start Render screen (it pops up then everything crashes)
                                        Is anyone else having the same issue? I removed the previous version before installing the update.
                                        Bob
                                        • E
                                          ezequiel1982 Newcomers
                                          Hi! I installed on Sketchup 2022 and I'm getting the following error:
                                          Error; #<LoadError; cannot load such file -- /users/ezequiel/library/application support/sketchup 2022/sketchup/plugins/rayscaper/installed/Mac/2.7.2/0.8.4 Alpha/resources/SUEX_Rayscaper_SetDllDirectory>
                                          /Applications/SketchUp 2022/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.7.1/lib/ruby/2.7.0/rubygems/core_ext/kernel_require.rb;92;in `require'
                                          /users/ezequiel/library/application support/sketchup 2022/sketchup/plugins/rayscaper/main.rbe;84;in `<module;Rayscaper>'
                                          /users/ezequiel/library/application support/sketchup 2022/sketchup/plugins/rayscaper/main.rbe;5;in `<main>'
                                          /Applications/SketchUp 2022/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `eval'
                                          /Applications/SketchUp 2022/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require'
                                          /Applications/SketchUp 2022/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load'
                                          /Users/ezequiel/Library/Application Support/SketchUp 2022/SketchUp/Plugins/rayscaper.rb;16;in `register_extension'
                                          /Users/ezequiel/Library/Application Support/SketchUp 2022/SketchUp/Plugins/rayscaper.rb;16;in `<module;Rayscaper>'
                                          /Users/ezequiel/Library/Application Support/SketchUp 2022/SketchUp/Plugins/rayscaper.rb;6;in `<top (required)>'
                                          • pixelcruncherP
                                            Hey there,
                                            Looks like you are trying Rayscaper on a Mac. We don't have a Mac version yet. We want to stabilize our Windows version before releasing the Mac version.
                                            Regards,
                                            Thomas
                                            • 4 / 6
