    2.2k Posts 487 Posters 933.2k Views 492 Watching
      @Darius
      Look in your licenses page at SketchUcation and see what's reported...
      Do you have any error messages to share ?
      • F Offline
        francisquitof
        @darius said:
        Hello,
        Bought a licenze for 3 seats and its stopped worked couples days ago. Two other seats are working just fine. What could be a problem ?
        Try validating your license, if it doesn’t allow you and asks you if you want to open the folder where the license are, choose yes, delete everything from there, even the folders that say do not delete, I did that a couple of days ago, then download again all your licenses from your license manager, save them on any place you want, then try to validate again your licenses using the new files you’ve downloaded. That worked for me, I couldn’t validate any license acquired on sketchucation, I asked for help for days but no one answered with a solution.
          ChrisTTSI
          I've recently had a new PC as the hard drive failed on the old one.
          I had purchased a copy of RoundCorner last year and have managed to activate a license on my new PC but cannot release the license attached to my old PC.
          Can anyone help with this? There does not seem to be an option anywhere to release or deactivate an old seat.
          Thanks in advance.
          • fredo6F Offline
            @christtsi said:
            Thanks in advance.
            I released the old seat (March 2022).
              ChrisTTSI
              Thank you 👍
                benjfabrique
                Hello fredo6,
                I bought a perpetual license for round corner plugin which doesn't seem to want to work anymore with the ERROR_F09. what should I do?
                  @benjfabrique
                  That error message shows an 'extension name mismatch'.
                  It has been seen with Fredo's RoundCorner and FredoCorner, they are not the same extension and need separate licenses.
                  Some users mistake the two.
                  Check that you have installed the correct extension and that you are trying to license it with the appropriate license...
                  If the problem continues please report back with details of the extensions and any error messages etc...
                    arnold247
                    I have fredo corner installed however the license does not allow it to enter.
                    It gives me an error code: Error_F09
                    I have purchased the license for fredo round corner however it just doesnt allow me to activate it. any help????????????
                      Please read the preceding two posts...
                      As I said that error message shows a discrepancy between the license and the extension's name.
                      It's usually connected to confusing Fredo's RoundCorner and his FredoCorner extensions.
                      They are not the same thing.
                      You need to install and open the appropriate extension's submenu, AND also have a matching license-file to validate it properly...
                        Please use the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support command in SketchUp and copy/paste the output into your reply
                        • N Offline
                          natejesus
                          SketchUp
                          Error in the License Validation
                          Request to Sketchucation: ERROR_A0B
                          OK
                          Why? ExtensionStore 4.3.1, the latest.
                          Why do you have such poor error messages? Write better code that explains what is wrong!
                          I hate your DRM. I want to use what I paid for! 😞 This isn't the first time I have problems. It needs to work smoothly or I won't want to use it again.
                          • N Offline
                            natejesus
                            Deleting this file made it work:
                            SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt
                            How counterintuitive is that? Please, please make the DRM more bulletproof, so I don't need to delete some file I don't understand, and have it give error messages that are meaningful.
                                chakieee
                                Hello Fredo. I want to buy your plugins today but I can't. I am from Turkey, we can't use PayPal here. I try to buy licence with credit card but it doesnt work either. Can I buy your plugins with credit card? Thank you a lot.
                                  The pay by PayPal and pay by card are powered by PayPal. If your country forbids PayPal then there's no other option at present.
                                  We are looking at Stripe but if you have friends outside of Turkey I would get them to purchase on your behalf.
                                  • N Offline
                                    natejesus
                                    I want to use the plugin I paid for. I activate it. Activation is successful. I try to use the plugin (round corners), it says not activated. This is a loop, no matter how many times I do it.
                                    I just want to round some corners. I hate all of this. I'll never buy a SketchUp plugin again. 😞
                                      Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support command in Sketchup and copy/paste the output here
                                        @natejesus
                                        Do what Rich advises...
                                        However, your issue might relate to a mismatch between the Extension and License.
                                        Fredo has two extensions - RoundCorner and FredoCorner.
                                        They are different and need the matching license to work...
                                        Please check your downloaded license's name and your installed extension's name - unless they match you can't validate...
                                          danygico
                                          Hi fredo6
                                          After having formatted the pc for SDD problems I can't free these licenses
                                          RoundCorner
                                          Seat ID: 33994; HW ID: ME1651994382.0W; Date of activation: 08/05/2022
                                          Curviloft
                                          Seat ID: 25877; HW ID: TN1648232773.0X; Date of activation: 25/03/2022
                                          VisuHole
                                          Seat ID: 25882; HW ID: TN1648232773.0X; Date of activation: 25/03/2022
                                          I would really appreciate it if you can remove them
                                          Thank you
                                            kmatloc
                                            I purchased the license for fredo plugings i used the for a bit in one of my laptops now its not leting me use the plugings and i try to put in the license but it says there is an error in the communication i have the latest version of sketchucation plugin i have a good wifi conection i think everything is right Help!
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 109
                                            • 110
                                            • 58 / 110
