    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
    • BoxB
      There is a lot more skill involved in making a shape that matches something in the real world than there is in my random musings. πŸ‘
      • tuna1957T
        tuna1957
        Thanks Box . Your to kind. πŸ‘
        • HornOxxH
          HornOxx
          @tuna1957 said:
          ...SubD the best tool for the job...
          πŸ‘ which is absolutely right! Prima!
          never trust a skinny cook
          • tuna1957T
            tuna1957
            Thanks HornOxx. Fooled about trying some other approaches just for practice. Abandoned other ways for SubD and β€œbing bang” it was done. πŸ˜†
            • panixiaP
              panixia
              I believe I've found a fun retopolgy workaround in Sketchup 🀣
              Of course is not as powerful as some dedicated tools like Topogun, but it can get the job done on simple objects without switching to a different software.
                And what is exactly this workaround ? πŸ˜„
                • panixiaP
                  panixia
                  I simply smooth all edges from the triangulated mess, then I draw some pseudo-quad topology with TOS, extract that as a group, do a quick cleanup using VT2 "merge close vertices", and then use the most overlooked feature of QFT (convert wireframe into quads) to create a quadmesh to subdivide.
                  The smoothed mesh is just a tiny bit smaller of course because of the subdivision, so you may want to compensate for that with a little JPP.
                    Many thanks for the infos! 😎
                    • BoxB
                      Classic SUbD.
                      Some techniques I'm playing with for an upcoming project.
                      • HornOxxH
                        HornOxx
                        πŸ‘ πŸ‘ hey - this tentacle-like "suction cup(?)"-thing is extraordinarily promising and superbly textured already now! - I'm curious to see what follows here πŸ˜„
                        • tuna1957T
                          tuna1957
                          @hornoxx said:
                          :thumb: πŸ‘ hey - this tentacle-like "suction cup(?)"-thing is extraordinarily promising and superbly textured already now! - I'm curious to see what follows here πŸ˜„
                          Ditto πŸ‘ πŸ‘
                          • ntxdaveN
                            ntxdave
                            @tuna1957 said:
                            Ditto πŸ‘ πŸ‘
                            Ditto from me also......... πŸ‘ πŸ‘ πŸ‘
                            I wish SubD was/think it ought to be part of SketchUp.
                            Press F1...thank me later
                            • BoxB
                              Sorry, this isn't really a gallery thread, I should have added an unrendered image, so here it is.
                                Staying aquatic...
                                https://i.imgur.com/hN9s2lR.png
                                • HornOxxH
                                  HornOxx
                                  @rich o brien said:
                                  Staying aquatic...
                                  πŸ˜„ πŸ‘ what a beautiful example!
                                  (do you all also feel that this smoothing process still impresses you again and again?)
                                    There is always an unsustainable suspense with this sort of polys modeling before you press the button! πŸ’š
                                      Equal amounts of impressiveness and bitterness tend to wash over me depending on the outcome... 😳
                                      • BoxB
                                        Looks a mess...and then it resolves itself.
                                        https://i.imgur.com/VhbIrCx.gif
                                          That's yummy.
                                          Getting your scout badge for knots?
                                          • BoxB
                                            Cheers Rich.
                                            I remember being stunned by someone doing a knot way back when I was learning, so I like playing with them from time to time.
                                            I liked the idea of using subd for it to make it a bit more 'loose' rather than the perfectly straight ones done with perfect curves and lines.
                                            Renders nicely too.
                                            Reply Quote 2
                                            • 77
                                            • 78
                                            • 79
                                            • 80
                                            • 81
                                            • 82
                                            • 83
                                            • 84
                                            • 79 / 84
