    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
      And what is exactly this workaround ? πŸ˜„
      • panixiaP
        panixia
        I simply smooth all edges from the triangulated mess, then I draw some pseudo-quad topology with TOS, extract that as a group, do a quick cleanup using VT2 "merge close vertices", and then use the most overlooked feature of QFT (convert wireframe into quads) to create a quadmesh to subdivide.
        The smoothed mesh is just a tiny bit smaller of course because of the subdivision, so you may want to compensate for that with a little JPP.
          Many thanks for the infos! 😎
          • BoxB
            Classic SUbD.
            Some techniques I'm playing with for an upcoming project.
            • HornOxxH
              HornOxx
              πŸ‘ πŸ‘ hey - this tentacle-like "suction cup(?)"-thing is extraordinarily promising and superbly textured already now! - I'm curious to see what follows here πŸ˜„
              never trust a skinny cook
              • tuna1957T
                tuna1957
                @hornoxx said:
                :thumb: πŸ‘ hey - this tentacle-like "suction cup(?)"-thing is extraordinarily promising and superbly textured already now! - I'm curious to see what follows here πŸ˜„
                Ditto πŸ‘ πŸ‘
                • ntxdaveN
                  ntxdave
                  @tuna1957 said:
                  Ditto πŸ‘ πŸ‘
                  Ditto from me also......... πŸ‘ πŸ‘ πŸ‘
                  I wish SubD was/think it ought to be part of SketchUp.
                  Press F1...thank me later
                  • BoxB
                    Sorry, this isn't really a gallery thread, I should have added an unrendered image, so here it is.
                      Staying aquatic...
                      https://i.imgur.com/hN9s2lR.png
                      • HornOxxH
                        HornOxx
                        @rich o brien said:
                        Staying aquatic...
                        πŸ˜„ πŸ‘ what a beautiful example!
                        (do you all also feel that this smoothing process still impresses you again and again?)
                          There is always an unsustainable suspense with this sort of polys modeling before you press the button! πŸ’š
                            Equal amounts of impressiveness and bitterness tend to wash over me depending on the outcome... 😳
                            • BoxB
                              Looks a mess...and then it resolves itself.
                              https://i.imgur.com/VhbIrCx.gif
                                That's yummy.
                                Getting your scout badge for knots?
                                • BoxB
                                  Cheers Rich.
                                  I remember being stunned by someone doing a knot way back when I was learning, so I like playing with them from time to time.
                                  I liked the idea of using subd for it to make it a bit more 'loose' rather than the perfectly straight ones done with perfect curves and lines.
                                  Renders nicely too.
                                  Reply Quote 2
                                    If you tilt your head to the left you see a guy playing a saxophone!
                                    • BoxB
                                      A little more knotting.
                                      https://i.imgur.com/y44HEPy.gif
                                      Reply Quote 2
                                      • HornOxxH
                                        HornOxx
                                        klasse!
                                        • tuna1957T
                                          tuna1957
                                          Another SubD chair for the parts file. 😎
                                          • HornOxxH
                                            HornOxx
                                            ...prima Tuna1957 πŸ‘ not to forget this "rounded seam" (is there any term for this?) on the edges of the upholstery makes such a furniture model so much better πŸ‘
                                            • 78
                                            • 79
                                            • 80
                                            • 81
                                            • 82
                                            • 83
                                            • 84
                                            • 80 / 84
