    Toposhaper Crashing
    23 Posts 11 Posters 5.1k Views 11 Watching
    • fredo6F Offline
      @aguadodaniel said:
      Hello, I am trying to create a mesh for my current project and it keeps giving me the pink ruby error window. Just wondering if there is something that I can change to allow it to work successfully.
      It may help to post or send me the corresponding model so that I can relate the errors to the geometry.
      Many thanks
        aguadodaniel
        That'll be great, what's your email?
          student moshe
          Hello friends
          I had a problem using toposhaper
          And I was wondering if anyone could help me figure out what the problem was,
          There is a report text document from toposhaper attached for explanation
          Ruby Error - CLEANSING - 24-Oct-21 11_10_51.txt
          • fredo6F Offline
            @student moshe said:
            Hello friends
            There is a problem in relation with layers in your model. If you could attach the skp file, it would help.
              suprabari Newcomers
              Hello friends
              There is a report text document from toposhaper attached for explanation and 1 attached file dwg
              Ruby Error - CALCULATING TERRAINS - 19-Dec-22 14_55_41.txt
              area_mess_detail.dwg
                suprabari Newcomers
                Hello friends
                There is a report text document from toposhaper attached for explanation and i attached file dwg
                  suprabari Newcomers
                  Hello friends
                    @suprabari said:
                    I had a problem using toposhaper...
                    What version of SketchUp are you using? There is no 2021 Free/Make version as you indicate in your profile.
                    Can you share the .skp file so we can see how you have the model set up?
                      suprabari Newcomers
                      My version of Sketchup is 2021, i use .dwg file. Here is my file.
                      I have another .dwg file and it is running normal, but this .dwg cant
                        I get the following when I try to run Toposhaper with your file. It may be that Fredo6 will have an idea of what might be changed to get it to work.
                        In the meantime, The From Contours option with the Sandbox tools seems todo a reasonable job.
                        • U Offline
                          upscalevalley Newcomers
                          TopoShaper is a software tool that is used to create three-dimensional models of terrain from digital elevation data. It is designed to work with large datasets and can handle terrain models with millions of points. However, the maximum size of a model that TopoShaper can complete depends on several factors, including the amount of available memory on the computer being used to run the software and the complexity of the terrain being modeled. In general, the larger the dataset, the more memory and processing power will be required to complete the model. If the computer being used does not have enough resources to handle the size of the dataset, the model may not be able to be completed. It is always a good idea to make sure that the computer being used has sufficient resources to handle the size of the dataset being processed. Additionally, the complexity of the terrain being modeled can also affect the maximum size of a model that TopoShaper can complete. If the terrain is very complex with a large number of features, it may require more resources to generate an accurate model. In such cases, it may be necessary to use a more powerful computer or to break the dataset into smaller pieces and process them separately in order to complete the model.
                            thiagotomazoli
                            Estou com o seguinte erro
                            Date: 17-Oct-23 14:21:14
                            An error occurred in CLEANSING
                            The operation is fully aborted
                            cannot hide layer that is a part of the active path
                            body_lib6tool.rbe: 2538 -- visible=
                            body_lib6tool.rbe: 2538 -- block in switch_to_temp_layer
                            body_lib6tool.rbe: 2537 -- each
                            body_lib6tool.rbe: 2537 -- switch_to_temp_layer
                            toposhapertool.rbe: 1391 -- change_view
                            toposhapertool.rbe: 1358 -- set_preview_working
                            toposhapertool.rbe: 544 -- cleansing_processing
                            toposhapertool.rbe: 523 -- after_selection
                            toposhapertool.rbe: 493 -- notify_edge_picked
                            body_lib6edgepicker.rbe: 539 -- call
                            body_lib6edgepicker.rbe: 539 -- notify_action
                            body_lib6edgepicker.rbe: 582 -- terminate_current_selection
                            toposhapertool.rbe: 658 -- execute_validate
                            toposhapertool.rbe: 387 -- handle_initial_selection
                            toposhapertool.rbe: 319 -- activate
                            toposhapertool.rbe: 133 -- select_tool
                            toposhapertool.rbe: 133 -- action__mapping
                            data6.rb: 65 -- call
                            data6.rb: 65 -- launch_action
                            lib6plugin.rbe: 240 -- launch_action
                            bootstrap_toposhaper.rbe: 83 -- launch_action
                            bootstrap_toposhaper.rbe: 149 -- block in startup
                            lib6plugin.rbe: 1469 -- command_invoke
                            lib6plugin.rbe: 1449 -- block (2 levels) in build_config_commands
                            lib6traductor.rbe: 1387 -- block in add_command
                              thiagotomazoli
                              01.pngOlá, estou com o seguinte erro.
                              Deu certo uma vez, apareceu a malha e tudo, más não gerou o terreno.
                              Mapeamento feito por drone, e feito limpeza manual aqui no sketchup.
                              Más não consigo, sempre aparece o erro
                              R04- Topografia Inicial.skp
                                The output can only be as good as the input and with this dataset you are probably asking too much.
                                If you set the Grid upper limit you will still not capture the complexity and hang SketchUp for huge amounts of time.
                                Break it up into manageable sections, simplify the contours and work through it. Maybe work a a smaller selection of contours in a separate file to dial in your ideal output and go from there.
                                But overall its a very complex dataset with many hard to find errors.
                                  cheekyky
                                  Hello, I'm having problems with the toposhaper extension tool.
                                  I'm running it on a very simple topography and it keeps crashing.
                                  I'm probably not using it well, I don't know... The tool 'from contours' seems to work perfectly but it's not as precise as toposhaper.
                                  If anyone could help me figure it out what's the problem it would be really useful.
                                  Thanks for the help,
                                  Ulysse
                                  HOUSE ASTHMA - TOPO - 2.skp
                                  Ruby Error - CLEANSING - 22-Nov-23 22_18_26.txt
                                  HOUSE ASTHMA - TOPO.skp
                                  Ruby Error - CLEANSING - 22-Nov-23 22_19_19.txt
                                  • fredo6F Offline
                                    It looks like you run TopoShaper from the inside of the Group or Component. Could you instead just seelct the Group / Component.
                                    • 2 / 2
