Toposhaper Crashing
Hello friends
I had a problem using toposhaper
And I was wondering if anyone could help me figure out what the problem was,
There is a report text document from toposhaper attached for explanation and 1 attached file dwg
Ruby Error - CALCULATING TERRAINS - 19-Dec-22 14_55_41.txt
Hello friends
There is a report text document from toposhaper attached for explanation and i attached file dwg
Hello friends
@suprabari said:
I had a problem using toposhaper...
What version of SketchUp are you using? There is no 2021 Free/Make version as you indicate in your profile.
Can you share the .skp file so we can see how you have the model set up?
My version of Sketchup is 2021, i use .dwg file. Here is my file.
I have another .dwg file and it is running normal, but this .dwg cant
I get the following when I try to run Toposhaper with your file. It may be that Fredo6 will have an idea of what might be changed to get it to work.
In the meantime, The From Contours option with the Sandbox tools seems todo a reasonable job.
TopoShaper is a software tool that is used to create three-dimensional models of terrain from digital elevation data. It is designed to work with large datasets and can handle terrain models with millions of points. However, the maximum size of a model that TopoShaper can complete depends on several factors, including the amount of available memory on the computer being used to run the software and the complexity of the terrain being modeled. In general, the larger the dataset, the more memory and processing power will be required to complete the model. If the computer being used does not have enough resources to handle the size of the dataset, the model may not be able to be completed. It is always a good idea to make sure that the computer being used has sufficient resources to handle the size of the dataset being processed. Additionally, the complexity of the terrain being modeled can also affect the maximum size of a model that TopoShaper can complete. If the terrain is very complex with a large number of features, it may require more resources to generate an accurate model. In such cases, it may be necessary to use a more powerful computer or to break the dataset into smaller pieces and process them separately in order to complete the model.
Estou com o seguinte erro
Date: 17-Oct-23 14:21:14
An error occurred in CLEANSING
The operation is fully abortedcannot hide layer that is a part of the active path
body_lib6tool.rbe: 2538 -- visible=
body_lib6tool.rbe: 2538 -- block in switch_to_temp_layer
body_lib6tool.rbe: 2537 -- each
body_lib6tool.rbe: 2537 -- switch_to_temp_layer
toposhapertool.rbe: 1391 -- change_view
toposhapertool.rbe: 1358 -- set_preview_working
toposhapertool.rbe: 544 -- cleansing_processing
toposhapertool.rbe: 523 -- after_selection
toposhapertool.rbe: 493 -- notify_edge_picked
body_lib6edgepicker.rbe: 539 -- call
body_lib6edgepicker.rbe: 539 -- notify_action
body_lib6edgepicker.rbe: 582 -- terminate_current_selection
toposhapertool.rbe: 658 -- execute_validate
toposhapertool.rbe: 387 -- handle_initial_selection
toposhapertool.rbe: 319 -- activate
toposhapertool.rbe: 133 -- select_tool
toposhapertool.rbe: 133 -- action__mapping
data6.rb: 65 -- call
data6.rb: 65 -- launch_action
lib6plugin.rbe: 240 -- launch_action
bootstrap_toposhaper.rbe: 83 -- launch_action
bootstrap_toposhaper.rbe: 149 -- block in startup
lib6plugin.rbe: 1469 -- command_invoke
lib6plugin.rbe: 1449 -- block (2 levels) in build_config_commands
lib6traductor.rbe: 1387 -- block in add_command
Olá, estou com o seguinte erro.
Deu certo uma vez, apareceu a malha e tudo, más não gerou o terreno.
Mapeamento feito por drone, e feito limpeza manual aqui no sketchup.Más não consigo, sempre aparece o erro
The output can only be as good as the input and with this dataset you are probably asking too much.
If you set the Grid upper limit you will still not capture the complexity and hang SketchUp for huge amounts of time.
Break it up into manageable sections, simplify the contours and work through it. Maybe work a a smaller selection of contours in a separate file to dial in your ideal output and go from there.
But overall its a very complex dataset with many hard to find errors.
Hello, I'm having problems with the toposhaper extension tool.
I'm running it on a very simple topography and it keeps crashing.I'm probably not using it well, I don't know... The tool 'from contours' seems to work perfectly but it's not as precise as toposhaper.
If anyone could help me figure it out what's the problem it would be really useful.
Thanks for the help,
Ulysse
Ruby Error - CLEANSING - 22-Nov-23 22_18_26.txt
It looks like you run TopoShaper from the inside of the Group or Component. Could you instead just seelct the Group / Component.
