    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
    • O
      optimaforever
      @panixia said:
      I confirm this happens when you try to bridge 2 edges which are not coplanar.
      doesn't happen if they are more than 2 or if they are 2 but still coplnar.
      Ok, so a workaround would be to break/divide the vertices before doing bridge?
      • panixiaP
        panixia
        Honestly I wasn't trying to propose a workaround, just trying to better "isolate" the problem to give some more clue to Thomas. πŸ˜›
        • O
          optimaforever
          Honestly I'm wondering if Thomas actually reads this thread... πŸ˜‰
          • O
            optimaforever
            @thomthom @TIG
            I love TIG's drop vertice feature when I need to conform a quad web onto a given (usually triangulated) surface below for topography mesh for instance. It works but I lose the quad property of the net.
            Is it possible to adapt TIG's code to keep the "quad-ness" while dropping the vertices?
            • panixiaP
              panixia
              @optimaforever said:
              @thomthom @TIG
              If you triangulate the quadmesh (using the triangulate command in QFT) it will work like a charm. πŸ˜›
              This trick will work also for artisan brush and some other tools which don't "officially" support quads.
              • O
                optimaforever
                @thomthom @TIG
                triangulate the quad mesh prior to drop vertices to keep the quadness? interesting πŸ˜„
                • panixiaP
                  panixia
                  Yes, exactly. πŸ˜›
                  • O
                    optimaforever
                    Yes, exactly. πŸ˜›
                    You're a genius!
                    And you can keep the quads while using sculpt brush with Artisan!!! 😍
                    • panixiaP
                      panixia
                      Note that my meshes aren't perfectly quadbased; there are sometimes tris. I'm wondering how it will manage that ;D
                      It will work as expected: will create a proper diagoanl for each quad and will leave any other polygon (triangle or ngon) as it is.
                        I've always wondered why thomthom proposed the triangulate quads option. now it makes more sense.
                        I thought you lose the quad properties when triangulating but apparently not.
                        QuadFace Tools quads can be planar SketchUp quads, or they can be two triangle separated by an edge that is Soft+Smooth+Not Casting Shadows.
                        It's not intuitive, but it was the only way I could manage to sanely work with quad meshes in SU.
                        Quads are not a hard rule. Some times a tri or even n-gon in the right place makes the mesh simpler and easier to work with.
                        • O
                          optimaforever
                          Thanks Thomas for the reply! πŸ‘
                          • T
                            Tru-la-la
                            Super plugin. Thanks ❗ ❗ ❗
                              That's hilarious. I want a 3d print of that!
                              • panixiaP
                                panixia
                                LOL
                                  Wow! This is fantasticality surreal! πŸ˜†
                                  How did you manage to turn that profile photo into a 3D head sculpture?
                                  • 30
                                  • 31
                                  • 32
                                  • 33
                                  • 34
                                  • 34 / 34
