[Plugin] ThruPaint - v2.4a - 02 Apr 24
I can`t start the plagin from today 31.10.2022. It asks to upgrade? but its up to date.
Whats the problem may be and How fix it. Thanks.
NEW RELEASE: ThruPaint v2.2a - 31 Oct 22
ThruPaint 2.2a is for extension of validity.
Home Page of ThruPaint for information and Download.
Hi Fredo,
I love this tool and couldn't work without it. However, it takes a very long time to load the materials. Is there a way to speed it up or revert back to the old way using the Sketchup selected material?
This is a great tool. Thank you. Any chance of being able to pick colors from the default "Materials" color wheel or incorporate one of your own? Will the color picker only select color from the canvas?
J -
Normally, if you create a material in the Sketchup native material browser, it should appear in the ThruPaint browser under the Model tab.
This is why ThruPaint has not material creation and edition capability. -
Good afternoon, I faced a problem: when start the plugin, the button lights up in blue, saying that the plugin is active, but the window for working as usual does not appear, how to fix it?Thanks.
Any update to have NCS colors implemented?
Hi Fredo,
I'm having an issue with Thrupaint where I can't use the gizmo to move textures around.
Here's a gif:
Can you open the Ruby Console to see if there are errors
Nothing showing in the console
Does the Gizmo works on other faces?
I'm having an issue where the Paint Face toolbar won't load. I've attached a screenshot and the console log. Thanks in advance for any help.
I think you probably need to reboot your PC and tell me if this make it work.
Hi Fredo,
The gizmo works sometimes but not on others. I can't seem to find a pattern.
I also have an issue that I didn't have with the prior version of thrupaint.
When I try to paint a texture continually on surfaces I can't see the red/green axis anymore, as I used to be able with Thrupaint 1.
I notice that things are working, but that visual cue isn't there.
Thanks,
João
With ThruPaint 2, the axes are now triggered when you are close to an edge. Otherwise, if you are in the middle of a face, the direction of axes is the one that the Paint Bucket would take.
Even so, this is also very random. Sometimes I see it, but most of the times I don't. Do you think this might be related to dpi?
Can you keep the Ruby console opened to check for errors.
I will.
I got one but things were actually working:
Error; #<TypeError; nil can't be coerced into Integer> c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;1336;in `-' c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;1336;in `handle_move' c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;4200;in `onMouseMove'
