    2.2k Posts 487 Posters 930.7k Views 492 Watching
      Do you have the latest version of the Sketchucation Tool installed?
      • fredo6F Offline
        Could you upgrade to LibFredo6 v13.5a and Sketchucation ExtensionStore v4.2.9.
          minamino27
          Hi Fredo06,
          I already purchased most of your plugins. I validated it and successfully used it, But suddenly all of my licenses are invalid and it says that trial version has ended. I tried to revalidate but to know avail. what seems to be the problem? PLEASE FIX THIS. THanks
            Kalusialolek
            Hello,
            I bought a license and now just out of the blue an error occured. HELP!
              csilverman
              Having the same issue as other users. Purchased licenses. They worked for a long time, now suddenly not. Sketchucation extension and LibFredo6 are both up to date. Error image attached...
              • H Offline
                hongjianqin7
                I bought the perpetual license for round corner a while ago and it was working fine till now, It stopped working entirely today, so I updated all the plugins including libfredo6, sketchucation, to make sure they are up to date. I also reinstalled roundcorner, and I validated my perpetual license, which worked initially, after I used it for one minute though, it told me i need to validate it again, but then it wouldn't validate successfully, it keeps on telling me "error, wrong license id", so now I can't use the plugin at all. please refer to the screenshot attached.
                • F Offline
                  FRANCK007
                  HELLO, I PURCHASED MY FREDO SCALE PLUGIN, BUT THE LICENSE THAT YOU SEND ME SAID THAT IS A WRONG LICENSE ID PLEASE HELP
                    janot10
                    Same here!
                      janot10
                      Same here!
                        I appears there's an issue with the server. Have patience. It'll be fixed as soon as possible.
                          mavie
                          Ditto to all the above. Ha. I only need to use 4 of Fredo's extensions this morning. 😞
                          Hoping server error is fixed soon, good luck!!
                          • Rich O BrienR Online
                            We're working on it. Sorry for inconvenience. 😳 😳 😳
                            • E Offline
                              estraulino
                              Hi, I also having problems with the license, getting notifications of an expired trial, Wrong license ID, etcetera...
                              But another weird thing that has been happening is that the UI of round corner is incomplete, the background appears, but no info or buttons or icons appears, and there is no way to change the values.
                              I really hope the server is back up again soon, because I use this extensions everyday. I don't really get why would this extension need to phone home, just to end up broken.
                                So it looks like an increase in server load is causing the issue.
                                You can validate but at times it fails. So give it an hour to settle while we fine tune things
                                  Looks to be resolved.
                                    mavie
                                    Yay!! Thanks, guys! 😄
                                      Digdaman
                                      Dear Fredo
                                      I had a problem that my license seats filling because it's recognizede as a different PC when I restarted sketchup.
                                      The problem seems to be resolved for now.
                                      It was causede by sketchup floating license.
                                      Once I checked out the sketchup floating license when validate Fredo6 license, even if I restart sketchup, the plugin worked correctly as the same PC.
                                      So, Please release all my seats from all computers so I can start the process from scratch.
                                        Gábor
                                        Have you tried to release your seats at https://sketchucation.com/webshop/my-licences.php ? If you used the latest SketchUcation Tools for activation, you should be able to release them there.
                                          Digdaman
                                          Thank you for your reply.
                                          But, there were only current releasable licenses.
                                          I want to release a seat that cannot be released beccause it was recognizede as a different PC due to a problem when sketchup restarted.
                                          releasable
                                          not releasable
                                          • fredo6F Offline
                                            @digdaman
                                            Could you indicate which seats (or HWID) would wish to release.
                                            I noticed that you validated licenses on 3 different computers on 14-15 November for RoundCorner and JointPushPull.
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 109
                                            • 110
                                            • 56 / 110
