    [Plugin][$] TopoShaper - v2.7a - 01 Apr 24
    451 Posts 143 Posters 669.3k Views 142 Watching
      makover
      Trying to use Toposhaper but none of the dialog boxes open when attempting to generate from contours. Goes through "cleansing contours" progress bar and then a large yellow square appears. Is this due to using the trial version?
        Probably not. Might be an outdated LibFredo6 install, might be incorrect model setup. Share the .skp file so we can see what you are working with.
          Andres8659 Newcomers
          Hello Fredo Master! I have the same issue as somebody before:
          An error occurred in CLEANSING
          The operation is fully aborted
          cannot hide layer that is a part of the active path
          I'm running SU2021 on my Windows OS 11
          Helpp!! πŸ˜ƒ
          • fredo6F Offline
            It looks like you selected the curves directly and they have some assigned layer.
            Can you try by selecting the group enclosing the curves (or create this group).
              makover
              Thanks! Attaching the modelled contours
              00.10_NW_DWG Contours.skp
                You've got several groups nested with the loose geometry of the countours in the model. Explode the group representing the perimeter of the contours and cut the other stuff down at the bottom of the group out so the group only contains the geometry for your terrain. There's a lot of edges to deal with in the contours so be patient when you run TopoShaper. Might not hurt to simplify the contours first.
                  titusbiao Newcomers
                  Hello,
                  I am now using Sketchup Pro 2021, with TopoShaper v2.6a. Following the instructions to TopoShaper::IsoContours, when I try to generate terrain as Step 4, SketchUp crashed! No matter the grid set as default 50x48, or 200x198, crashed all the same!
                  I don't know why, and could anyone tell me if there is anything wrong?
                  My file Topo.skp is here (uploaded to Microsoft OneDrive for download):
                  https://1drv.ms/u/s!AvaTfkcj2ZSTijSdm9cz1fsnQNFr?e=gUdSXs
                  Please help and many thanks!
                  • Rich O BrienR Online
                    Try tidying up the border to help Toposhaper create a mesh...
                    https://i.imgur.com/8s0IPHU.png
                    Topo-sk8.skp
                    I removed your outline and some pointless small edges and the BugSplat stops.
                    I also moved your raw geometry onto the default layer rather than your major/minor layers
                      titusbiao Newcomers
                      Hello Rich O Brien,
                      Many thanks for your help.
                      The Topo-sk8.skp works well with toposhaper v2.6a in SketchUp 2021 (Win10).
                      I have tried some other skp files and find that if the geometry is rectangle, no errors will occur.
                      So I guess that there might be 2 situations for toposhaper smoothly running without errors:
                      1. the geometry is better in rectangle --- at least not too much acute or obtuse angles;
                      2. Not too much tiny contour lines near the edge of the geometry.
                        Is that true?
                      Many thanks again!
                      [attachment=0:3akutcq8]<!-- ia0 -->Topo-sk8.skp<!-- ia0 -->[/attachment:3akutcq8]
                      • fredo6F Offline
                          Is that true?
                        Correct. You do not need too many contours, or too detailed contours, because TopoShaper is interpolating.
                        When the terrain has an irregular contour, you may also get artefacts, because TopoShaper is based on quads.
                        • volpino170790V Offline
                          volpino170790
                          Hi !
                          I have a problem with TopoShaper
                          Buttons don't appear and if the terrain geometry is not at the top level, it crashes.
                          I've had this problem before with other files.
                          Lib Fredo6 13.4a
                          Toposhaper 2.6a
                          I send a picture and a file
                          https://i.goopics.net/800/ck230g.jpg
                          Thank's !
                          2.1878.skp
                            Works fine for me...
                            https://i.imgur.com/iw9dhgV.png
                            • fredo6F Offline
                              It works for me too.
                              Could you open the Ruby Console before launching TopoShaper to see if there are error messages displayed.
                                volpino170790
                                Hi !
                                Here a link for a video
                                https://e1.pcloud.link/publink/show?code=XZ44gQZpMbvTD07lPfKUOGY0zFTHRPYK5Ey
                                Error in console
                                https://i.goopics.net/800/pj3gjq.jpg
                                  volpino170790
                                  Hi!
                                  I all uninstall my extensions (just not uninstall 3dxSketchUp and the Sketchup extensions from sketchup) and reinstall this:
                                  • LibFredo6, then close and reopen the file
                                  • Toposhaper, then close and reopen the file
                                  • Scf licence manager, then close and reopen the file
                                  https://i.goopics.net/800/uhkap9.jpg
                                  It is solved, but no idea why πŸ˜•
                                  I think there is a conflict between Fredo 6 and an other extension but which one... THAT the question πŸ˜†
                                  A video belove:
                                  Share Anything with pCloud
                                  With pCloud's unique Download Link feature you can share files with everyone. Click to download. Join pCloud.com and get up to 20GB FREE cloud storage.
                                  pCloud (e1.pcloud.link)
                                    volpino170790
                                    Hi!
                                    I think I've find the extension it cause a Bug
                                    CleanUp3 3.4.3
                                    I install juste TT lib, I test to make a terrain, no problem
                                    I installCleanUp3 3.4.3, I test to make a terrain, problem with toposhaper
                                    I uninstallCleanUp 3 3.4.3, I test to make a terrain, problem with toposhaper
                                    I uninstallTT lib, I test to make a terrain, problem with toposhaper
                                    I uninstallToposhaper and reinstall it, I test to make a terrain and it work great.
                                    --> TT lib and CleanUp3 can cause issues
                                    Before install TTLib and Cleanup3
                                    https://i.goopics.net/800/ia4rm8.jpg
                                    After install, but before close and reload the file
                                    https://i.goopics.net/800/zv75yd.jpg
                                    After reopen the file and test a terrain
                                    https://i.goopics.net/800/vdylah.jpg
                                    This time it's ok, but 5 minutes ago it didn't work... No idea
                                    And I've make the same install 😲
                                    I install Fredo6 Push Pull:
                                    https://i.goopics.net/800/ucpyqz.jpg
                                    and I close the file and reopen it:
                                    https://i.goopics.net/800/vovqfk.jpg
                                    and I test terrain Toposhaper:
                                    https://i.goopics.net/800/4arqc1.jpg
                                    • fredo6F Offline
                                      @volpino170790
                                      Could you install LibFredo6 v13.5a to see if this improves the situation.
                                        volpino170790
                                        Hi!
                                        It seems to be the LibFredo6 because (apart from basic SketchUp extensions) I only installed Fredo6 extensions and the bug occurs.
                                        However, sometimes it resolves itself and the Toposhaper toolbar appears.
                                        I haven't been able to find a routine that produces the bug for sure.
                                        After installing Curviloft (same message as after installing FredoTools)
                                        https://i.goopics.net/800/u2cqe8.jpg
                                        https://i.goopics.net/800/sfevdc.jpg
                                        Since installing version 13.5a, the bug no longer seems to occur but
                                        there are always error messages for installations of extensions requiring a Fredo6 license.
                                        After install of FredoSpline:
                                        https://i.goopics.net/800/uyhh8m.jpg
                                        Thanks a lot for your speed react πŸ˜„ πŸ˜„ πŸ˜„
                                          shirokostup
                                          hi. I'm in Russia now, PayPal is blocked here. I need a TopoShaper. How can I pay?
                                            atoney
                                            6132023.JPGHi..I purchased the toposhaper plugin. Installed and works..but I dont see the tool bar for it. I have to access it via the Menu bar? Can u suggest a solution?
                                            Atoney
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
