    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 892.4k Views 144 Watching
      @duventdesvagues said:
      where can i repor tan issue with the plugin toposhaper
      Post it here. Please also correct your profile. It says you are using SketchUp 2022 Free/Make but there is no such version. That information is important as it helps us help you.
        RhayaderNL
        Hey, i'm new to creating terrain in Sketchup, but following instructions using Fredotools and Toposhaper went relatively well, until the second step in Toposhaper: creating the mesh from isocontours. Toposhaper generates an error and the operation is fully aborted.
        I am using Toposhaper v2.6a in Sketchup Pro 2021 in Windows 10 Pro 64bit
        Date: 06-Jul-22 09:36:34
        An error occurred in CLEANSING
        The operation is fully aborted
        cannot hide layer that is a part of the active path
        body_lib6tool.rbe: 2538 -- visible=
        body_lib6tool.rbe: 2538 -- block in switch_to_temp_layer
        body_lib6tool.rbe: 2537 -- each
        body_lib6tool.rbe: 2537 -- switch_to_temp_layer
        toposhapertool.rbe: 1391 -- change_view
        toposhapertool.rbe: 1358 -- set_preview_working
        toposhapertool.rbe: 544 -- cleansing_processing
        toposhapertool.rbe: 523 -- after_selection
        toposhapertool.rbe: 493 -- notify_edge_picked
        body_lib6edgepicker.rbe: 539 -- call
        body_lib6edgepicker.rbe: 539 -- notify_action
        body_lib6edgepicker.rbe: 595 -- terminate_current_selection
        toposhapertool.rbe: 658 -- execute_validate
        toposhapertool.rbe: 387 -- handle_initial_selection
        toposhapertool.rbe: 319 -- activate
        toposhapertool.rbe: 133 -- select_tool
        toposhapertool.rbe: 133 -- action__mapping
        lib6plugin.rbe: 142 -- call
        lib6plugin.rbe: 142 -- launch_action
        lib6plugin.rbe: 244 -- launch_action
        bootstrap_toposhaper.rbe: 83 -- launch_action
        bootstrap_toposhaper.rbe: 149 -- block in startup
        lib6plugin.rbe: 1461 -- command_invoke
        lib6plugin.rbe: 1441 -- block (2 levels) in build_config_commands
        lib6traductor.rbe: 1378 -- block in add_command
        I would be happy to see a solution to this!
        • fredo6F
          I think the problem is that you are inside the group of contours, and the group has itself a layer assigned.
          In TopoShaper, you can select the group of isocontours and process it, rather than entering the group.
          • T
            tofix1991
            Hi, I can't use toposhaper anymore because of trial period has expired, where i can find the free license.., πŸ˜„
              It's next to the free beer πŸ‘
                makover
                Trying to use Toposhaper but none of the dialog boxes open when attempting to generate from contours. Goes through "cleansing contours" progress bar and then a large yellow square appears. Is this due to using the trial version?
                  Probably not. Might be an outdated LibFredo6 install, might be incorrect model setup. Share the .skp file so we can see what you are working with.
                    Andres8659 Newcomers
                    Hello Fredo Master! I have the same issue as somebody before:
                    I'm running SU2021 on my Windows OS 11
                    Helpp!! πŸ˜ƒ
                    • fredo6F
                      It looks like you selected the curves directly and they have some assigned layer.
                      Can you try by selecting the group enclosing the curves (or create this group).
                        makover
                        Thanks! Attaching the modelled contours
                        00.10_NW_DWG Contours.skp
                          You've got several groups nested with the loose geometry of the countours in the model. Explode the group representing the perimeter of the contours and cut the other stuff down at the bottom of the group out so the group only contains the geometry for your terrain. There's a lot of edges to deal with in the contours so be patient when you run TopoShaper. Might not hurt to simplify the contours first.
                          • T
                            titusbiao Newcomers
                            Hello,
                            I am now using Sketchup Pro 2021, with TopoShaper v2.6a. Following the instructions to TopoShaper::IsoContours, when I try to generate terrain as Step 4, SketchUp crashed! No matter the grid set as default 50x48, or 200x198, crashed all the same!
                            I don't know why, and could anyone tell me if there is anything wrong?
                            My file Topo.skp is here (uploaded to Microsoft OneDrive for download):
                            https://1drv.ms/u/s!AvaTfkcj2ZSTijSdm9cz1fsnQNFr?e=gUdSXs
                            Please help and many thanks!
                              Try tidying up the border to help Toposhaper create a mesh...
                              https://i.imgur.com/8s0IPHU.png
                              Topo-sk8.skp
                              I removed your outline and some pointless small edges and the BugSplat stops.
                              I also moved your raw geometry onto the default layer rather than your major/minor layers
                              • T
                                titusbiao Newcomers
                                Hello Rich O Brien,
                                Many thanks for your help.
                                The Topo-sk8.skp works well with toposhaper v2.6a in SketchUp 2021 (Win10).
                                I have tried some other skp files and find that if the geometry is rectangle, no errors will occur.
                                So I guess that there might be 2 situations for toposhaper smoothly running without errors:
                                1. the geometry is better in rectangle --- at least not too much acute or obtuse angles;
                                2. Not too much tiny contour lines near the edge of the geometry.
                                  Is that true?
                                Many thanks again!
                                [attachment=0:3akutcq8]<!-- ia0 -->Topo-sk8.skp<!-- ia0 -->[/attachment:3akutcq8]
                                • fredo6F
                                    Is that true?
                                  Correct. You do not need too many contours, or too detailed contours, because TopoShaper is interpolating.
                                  When the terrain has an irregular contour, you may also get artefacts, because TopoShaper is based on quads.
                                  • volpino170790V
                                    volpino170790
                                    Hi !
                                    I have a problem with TopoShaper
                                    Buttons don't appear and if the terrain geometry is not at the top level, it crashes.
                                    I've had this problem before with other files.
                                    Lib Fredo6 13.4a
                                    Toposhaper 2.6a
                                    I send a picture and a file
                                    https://i.goopics.net/800/ck230g.jpg
                                    Thank's !
                                    2.1878.skp
                                      Works fine for me...
                                      https://i.imgur.com/iw9dhgV.png
                                      • fredo6F
                                        It works for me too.
                                        Could you open the Ruby Console before launching TopoShaper to see if there are error messages displayed.
                                        • volpino170790V
                                          volpino170790
                                          Hi !
                                          Here a link for a video
                                          https://e1.pcloud.link/publink/show?code=XZ44gQZpMbvTD07lPfKUOGY0zFTHRPYK5Ey
                                          Error in console
                                          https://i.goopics.net/800/pj3gjq.jpg
                                          • volpino170790V
                                            volpino170790
                                            Hi!
                                            I all uninstall my extensions (just not uninstall 3dxSketchUp and the Sketchup extensions from sketchup) and reinstall this:
                                            • LibFredo6, then close and reopen the file
                                            • Toposhaper, then close and reopen the file
                                            • Scf licence manager, then close and reopen the file
                                            https://i.goopics.net/800/uhkap9.jpg
                                            It is solved, but no idea why πŸ˜•
                                            I think there is a conflict between Fredo 6 and an other extension but which one... THAT the question πŸ˜†
                                            A video belove:
                                            Share Anything with pCloud
                                            With pCloud's unique Download Link feature you can share files with everyone. Click to download. Join pCloud.com and get up to 20GB FREE cloud storage.
                                            pCloud (e1.pcloud.link)
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
