    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 875.6k Views 144 Watching
    • T
      titusbiao Newcomers
      Hello Rich O Brien,
      Many thanks for your help.
      The Topo-sk8.skp works well with toposhaper v2.6a in SketchUp 2021 (Win10).
      I have tried some other skp files and find that if the geometry is rectangle, no errors will occur.
      So I guess that there might be 2 situations for toposhaper smoothly running without errors:
      1. the geometry is better in rectangle --- at least not too much acute or obtuse angles;
      2. Not too much tiny contour lines near the edge of the geometry.
        Is that true?
      Many thanks again!
      @rich o brien said:
      Try tidying up the border to help Toposhaper create a mesh...
      https://i.imgur.com/8s0IPHU.png
      [attachment=0:3akutcq8]<!-- ia0 -->Topo-sk8.skp<!-- ia0 -->[/attachment:3akutcq8]
      I removed your outline and some pointless small edges and the BugSplat stops.
      I also moved your raw geometry onto the default layer rather than your major/minor layers
      • fredo6F
          Is that true?
        Correct. You do not need too many contours, or too detailed contours, because TopoShaper is interpolating.
        When the terrain has an irregular contour, you may also get artefacts, because TopoShaper is based on quads.
        • volpino170790V
          volpino170790
          Hi !
          I have a problem with TopoShaper
          Buttons don't appear and if the terrain geometry is not at the top level, it crashes.
          I've had this problem before with other files.
          Lib Fredo6 13.4a
          Toposhaper 2.6a
          I send a picture and a file
          https://i.goopics.net/800/ck230g.jpg
          Thank's !
          2.1878.skp
            Works fine for me...
            https://i.imgur.com/iw9dhgV.png
            • fredo6F
              It works for me too.
              Could you open the Ruby Console before launching TopoShaper to see if there are error messages displayed.
              • volpino170790V
                volpino170790
                Hi !
                Here a link for a video
                https://e1.pcloud.link/publink/show?code=XZ44gQZpMbvTD07lPfKUOGY0zFTHRPYK5Ey
                Error in console
                https://i.goopics.net/800/pj3gjq.jpg
                • volpino170790V
                  volpino170790
                  Hi!
                  I all uninstall my extensions (just not uninstall 3dxSketchUp and the Sketchup extensions from sketchup) and reinstall this:
                  • LibFredo6, then close and reopen the file
                  • Toposhaper, then close and reopen the file
                  • Scf licence manager, then close and reopen the file
                  https://i.goopics.net/800/uhkap9.jpg
                  It is solved, but no idea why πŸ˜•
                  I think there is a conflict between Fredo 6 and an other extension but which one... THAT the question πŸ˜†
                  A video belove:
                  Share Anything with pCloud
                  With pCloud's unique Download Link feature you can share files with everyone. Click to download. Join pCloud.com and get up to 20GB FREE cloud storage.
                  pCloud (e1.pcloud.link)
                  • volpino170790V
                    volpino170790
                    Hi!
                    I think I've find the extension it cause a Bug
                    CleanUp3 3.4.3
                    I install juste TT lib, I test to make a terrain, no problem
                    I installCleanUp3 3.4.3, I test to make a terrain, problem with toposhaper
                    I uninstallCleanUp 3 3.4.3, I test to make a terrain, problem with toposhaper
                    I uninstallTT lib, I test to make a terrain, problem with toposhaper
                    I uninstallToposhaper and reinstall it, I test to make a terrain and it work great.
                    --> TT lib and CleanUp3 can cause issues
                    Before install TTLib and Cleanup3
                    https://i.goopics.net/800/ia4rm8.jpg
                    After install, but before close and reload the file
                    https://i.goopics.net/800/zv75yd.jpg
                    After reopen the file and test a terrain
                    https://i.goopics.net/800/vdylah.jpg
                    This time it's ok, but 5 minutes ago it didn't work... No idea
                    And I've make the same install 😲
                    I install Fredo6 Push Pull:
                    https://i.goopics.net/800/ucpyqz.jpg
                    and I close the file and reopen it:
                    https://i.goopics.net/800/vovqfk.jpg
                    and I test terrain Toposhaper:
                    https://i.goopics.net/800/4arqc1.jpg
                    • fredo6F
                      @volpino170790
                      Could you install LibFredo6 v13.5a to see if this improves the situation.
                      • volpino170790V
                        volpino170790
                        Hi!
                        It seems to be the LibFredo6 because (apart from basic SketchUp extensions) I only installed Fredo6 extensions and the bug occurs.
                        However, sometimes it resolves itself and the Toposhaper toolbar appears.
                        I haven't been able to find a routine that produces the bug for sure.
                        After installing Curviloft (same message as after installing FredoTools)
                        https://i.goopics.net/800/u2cqe8.jpg
                        https://i.goopics.net/800/sfevdc.jpg
                        Since installing version 13.5a, the bug no longer seems to occur but
                        there are always error messages for installations of extensions requiring a Fredo6 license.
                        After install of FredoSpline:
                        https://i.goopics.net/800/uyhh8m.jpg
                        Thanks a lot for your speed react πŸ˜„ πŸ˜„ πŸ˜„
                          shirokostup
                          hi. I'm in Russia now, PayPal is blocked here. I need a TopoShaper. How can I pay?
                            atoney
                            6132023.JPGHi..I purchased the toposhaper plugin. Installed and works..but I dont see the tool bar for it. I have to access it via the Menu bar? Can u suggest a solution?
                            Atoney
                              Did you restart SketchUp after installation?
                              Fredo's tools are comprehensive and some need a restart.
                              If you right click your toolbar zone is Topshaper checked?
                                Make sure you have the current version of LibFredo6 and the Sketchucation ExtensionStore tool installed. Then quit and restart SketchUp.
                                • C
                                  carlosmgilp
                                  Hello how are you.
                                  Is there a way to complete the mesh?
                                  It is that sometimes it has happened to me that it does not fully reach the edges.
                                  In this example, the top corner doesn't quite reach the edge.
                                  • C
                                    carlosmgilp
                                    Hello how are you.
                                    Any help, I would appreciate it.
                                    Selected contour
                                    Plan view
                                    • fredo6F
                                      @carlosmgilp said:
                                      Hello how are you.
                                      Would you have the model so that I can have a look.
                                      • C
                                        carlosmgilp
                                        Hi, thanks for your response.
                                        Here I attach the file.
                                        It's part of a building outline, so it won't have curves, but it's a green area.
                                        Prueba toposharpe.skp
                                          Roesmana Newcomers
                                          @menes said:
                                          Hello,
                                          I need help!
                                          I'm puzzled and I can't get on top of this issue
                                          this great plugin from the time I've installed the new 2020 SU it's not working as it was effectively before...
                                          I attach some files maybe someone understands what's going on
                                          thanks, everybody will be going to help
                                          Alberto
                                          • V
                                            vexxejr Newcomers
                                            I am looking at generating complex surfaces from 3d contours, which have a height difference of 0.3m. I notice on videos that the grid size seems to have a max, what is the max for the grid size to be? and will it give me the granularity to show contours 0.3m apart, across a model which could be 1km wide.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
