    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 892.4k Views 144 Watching
      makover
      Installed Toposhaper (sketchup pro 2021) and when I start out with "cleansing contours it goes to a yellow square with the contours to the side and no toolbar to select the parameters from. seem to be able to work through it by right clicking and selecting "create preview". Ultimately what I'm hoping to do is to adjust the level of smoothing so that I get things like the sidewalks showing up in the examples below. Attaching below terrain done with native sandbox tools, and then done with toposhaper. hoping I can get something between the two in terms of terrain detail and most importantly eliminating the jagged geometry created with sandbox.
      created with toposhaper
      ![screen I get after "cleansing contours"](/uploads/imported_attachments/0pGM_ScreenShot2021-11-30at5.35.34AM.png "screen I get after "cleansing contours"")
      • fredo6F
        Could you send me the model with the isocontours. There may be a bug somewhere.
          josealmeidasantos
          I work with the plugin toposhaper in terrains
          I don’t understand why it doesn’t let the grid value change
          The plugin set limits min and max
          I wont a grid with 2 meters
          I did the same with the plugin Sandbox bonus tool and allowed
          can someone help me
          • fredo6F
            Sorry for that. TopoShaper manages a grid by number of rows and columns at the moment. So you have to figure out the right number to get close to your 2 meter.
            I'll probably improve that in the future.
            • mwdsM
              mwds
              I'm trying to use TS v2.6a. It is installed and the toolbar is showing. However, when I try to use the plugin nothing happens. Both icons can be selected, but no action takes place.
              I have un-installed the plugin, then re-installed it. The got the following error message;
              "TopoShaper 2.6a: Error starting up pi ugin (creating menus and icons)
              undefined method ''add_item' for nii:NiiCiass [in lib6traductor.rbe - #'add_command(): line 1391] c:jusers/mwds/appdatajroaming/sketchup/sketchup
              2022/sketchup/plug ins/fredo6_! I ibfredo6/li b6core.rbe:1 072:in 'rescue
              in block in effective_load_part2'"
              Any ideas?
                Have you installed the newest LibFredo available from the PluginStore ??
                • G
                  Garrieth
                  This fixed the "cannot hide layer that is a part of the active path" for me:
                  Make sure the selected contours or points are not in another group. Bring them out of all groups (except for the groups each contour may be in).
                  • V
                    varioushemrog
                    Bon Jour Fredo and TopoShaper users πŸ˜„
                    I am new. I only downloaded TopoShaper yesterday. I found it while looking for solutions for a DMG file with LiDAR contour lines for our 20 acre land. The DMG once opened in SketchUp shows almost 2 million edges 😲 πŸ˜†
                    At first when I tried working with it on Sketchup, either exploding it, or once in Edit Component trying to use the SketchUp From Contours tool. Sketchup crashed. I learned that if I isolated/selected small areas of a maximum 10,000 edges then I could work with the Sketchup tools, but that would take me too long.
                    So, looking for solutions, I found this great tool! That said, I have a couple of questions, I hope you can help me with. πŸ˜„
                    First, TopoShaper seems to have successfully exploded the DMG. It took a long time but it didn't crash!
                    QUESTIONS:
                    Since what I need is a terrain as precise as possible (hence the LiDAR) πŸ˜‰ , I want to preserve all the detail provided by the contours. Do you have any suggestions for the settings I should use to get these results?
                    In the SELECTION Stage:
                    Using Iso-Contours, I tried to "select", all the Contour lines in my Original but that crashed the program. So I am generating the terrain in "sections/groups" that I created from my original, far larger than what I could do with the native sketchup tools.
                    • How does the Maximum Edge Angle for Follow Mode work?
                    • because I am sectioning the whole terrain in chunks, should I Stop Prolongation at Edge Crossings? Or should I keep the Prolongation?
                    [pre:2p2bp0ts][/pre:2p2bp0ts]At present,
                    In the CLEANSING stage:
                    • I am not excluding contours
                    • I am accepting all simplification of the contours. The PDF says that TopoShaper uses an 8 degree angle automatically. Is this the same angle referred to in the SELECTION Stage - Maximum Edge Angle for Follow Mode in degree?
                    • I am not accepting the junctions, (My file does not have labels, so the few proposed junctions are on the perimeter of each section I am converting.
                    • I am not using Edit Altitude. If left untouched will TopoShaper keep the altitude for each point that was in the original DWG?
                    For the CALCULATING OF CONTOURS stage:
                    • Is there a way to edit out the extrapolation that takes place between a single contour and the hull border? Since I am doing this in sections, this creates flat surfaces in between SOME sections, not always. (I always choose the hilltop option FYI)
                    • I am using a grid of 100 for the X value and let TopoShaper calculate the Y. Will this give me enough "precision" or should I increase the value to 200?
                    In the GENERATION screen, There is a section for Altitude Labels. I have tried, the ALL option, and also the Filtering, but they never show. What should I do?
                    Once TopoShaper is active, **is there a way to pan and or orbit the view?**Every time I try, I am taken out of TopoShaper, so I cannot see, if the result is what I want before I generate it.
                    I know these are a lot of questions. Apologies. But I really need to understand how to use this great tool to produce the results I need.
                    Thanks for your time, energy and ingenious mind! πŸ˜„
                    Helena
                    • fredo6F
                      @varioushemrog
                      It seems you are pushing TopoShaper beyond natural limits.
                      I would suggest that you simplify the model. With IsoContours, it does not matter to have very close contours, because TopoShaper interpolates anyway between contours.
                      • V
                        varioushemrog
                        Merci, Fredo. πŸ˜„ Well, TopoShaper is amazing! Yes, my file has lots of edges but your Extension can handle it in the groups I have created. So that is not a problem. πŸ˜„
                        I am looking for other ways to open the dmg file (I don't have autocad) and try to reduce the edges. I even installed GRASS GIS in my Mac and it reduces the edges by 63% but it is not keeping the 3D. I am trying to find ways to fix that.
                        I really want to understand more how your extension works πŸ˜„ It would help me immensely, if you could answer my questions, please:
                        1. How does the Maximum Edge Angle for Follow Mode work?
                        2. Because I am sectioning the whole terrain in chunks, should I Stop Prolongation at Edge Crossings? Or should I keep the Prolongation?
                        3. If left untouched will TopoShaper keep the altitude for each point that was in the original DWG?
                        4. Is there a way to edit out the extrapolation that takes place between a single contour and the hull border?
                        5. Will a Grid of 200 X give me a MORE precise Terrain than a grid with 100 X ?
                        6.Is there a way to pan and or orbit the view? Every time I try to use the Orbit or Pan tools I am taken OUT of TopoShaper
                        I hope you don't mind my questions. I love your extension, and I would like to use it properly πŸ˜„
                        Have an excellent weekend!
                        Helena
                          duventdesvagues
                          where can i repor tan issue with the plugin toposhaper, please?
                          thank you
                            Post it here. Please also correct your profile. It says you are using SketchUp 2022 Free/Make but there is no such version. That information is important as it helps us help you.
                              RhayaderNL
                              Hey, i'm new to creating terrain in Sketchup, but following instructions using Fredotools and Toposhaper went relatively well, until the second step in Toposhaper: creating the mesh from isocontours. Toposhaper generates an error and the operation is fully aborted.
                              I am using Toposhaper v2.6a in Sketchup Pro 2021 in Windows 10 Pro 64bit
                              Date: 06-Jul-22 09:36:34
                              An error occurred in CLEANSING
                              The operation is fully aborted
                              body_lib6tool.rbe: 2538 -- visible=
                              body_lib6tool.rbe: 2538 -- block in switch_to_temp_layer
                              body_lib6tool.rbe: 2537 -- each
                              body_lib6tool.rbe: 2537 -- switch_to_temp_layer
                              toposhapertool.rbe: 1391 -- change_view
                              toposhapertool.rbe: 1358 -- set_preview_working
                              toposhapertool.rbe: 544 -- cleansing_processing
                              toposhapertool.rbe: 523 -- after_selection
                              toposhapertool.rbe: 493 -- notify_edge_picked
                              body_lib6edgepicker.rbe: 539 -- call
                              body_lib6edgepicker.rbe: 539 -- notify_action
                              body_lib6edgepicker.rbe: 595 -- terminate_current_selection
                              toposhapertool.rbe: 658 -- execute_validate
                              toposhapertool.rbe: 387 -- handle_initial_selection
                              toposhapertool.rbe: 319 -- activate
                              toposhapertool.rbe: 133 -- select_tool
                              toposhapertool.rbe: 133 -- action__mapping
                              lib6plugin.rbe: 142 -- call
                              lib6plugin.rbe: 142 -- launch_action
                              lib6plugin.rbe: 244 -- launch_action
                              bootstrap_toposhaper.rbe: 83 -- launch_action
                              bootstrap_toposhaper.rbe: 149 -- block in startup
                              lib6plugin.rbe: 1461 -- command_invoke
                              lib6plugin.rbe: 1441 -- block (2 levels) in build_config_commands
                              lib6traductor.rbe: 1378 -- block in add_command
                              I would be happy to see a solution to this!
                              • fredo6F
                                I think the problem is that you are inside the group of contours, and the group has itself a layer assigned.
                                In TopoShaper, you can select the group of isocontours and process it, rather than entering the group.
                                • T
                                  tofix1991
                                  Hi, I can't use toposhaper anymore because of trial period has expired, where i can find the free license.., πŸ˜„
                                    It's next to the free beer πŸ‘
                                      makover
                                      Trying to use Toposhaper but none of the dialog boxes open when attempting to generate from contours. Goes through "cleansing contours" progress bar and then a large yellow square appears. Is this due to using the trial version?
                                        Probably not. Might be an outdated LibFredo6 install, might be incorrect model setup. Share the .skp file so we can see what you are working with.
                                          Andres8659 Newcomers
                                          Hello Fredo Master! I have the same issue as somebody before:
                                          I'm running SU2021 on my Windows OS 11
                                          Helpp!! πŸ˜ƒ
                                          • fredo6F
                                            It looks like you selected the curves directly and they have some assigned layer.
                                            Can you try by selecting the group enclosing the curves (or create this group).
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
