[Plugin Library] LibFredo6 - v14.4d - 20 May 24
@dcdp said:
I installed the latest version of LibFredo6. But Curviloft does not work and I can't open any setup window (Purge; Check for updates).
What I must to do ? Must I uninstall all your plugins and reinstall them ?
Before launching Curviloft, could you open the Ruby Console. Then Launch Curviloft, and what the console for any error message.
By the way, do you have a Mac M1?
Problem: bith FredoTools and JointPushPull don't do anything when launched. I see the toolbars, and the button (for example ther "J" pushpull icon) stays grey, but I don't get the parameters window, nor can I do any pushing/pulling on my model (no group or component, just a simple shape)
Working on a M1 macbook pro. All plugins and lib updated, licenses paid for and validated.. frustrating!
Here's the ruby console feedback: the first part is for trying to launch FredoTools, and after that the JPP
Error: #<NoMethodError: undefined method
wdlg_from_key' for Traductor::Wdlg:Class> /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:36:in
check_instance_displayed'
/users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:ininvoke' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_fredotools/fredotools.rbe:233:in
invoke_quick_launcher'
/users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_fredotools/fredotools.rbe:268:inblock in startup' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1465:in
command_invoke'
/users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1445:inblock (2 levels) in build_config_commands' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in
block in add_command'
ORIGINAL LAUNCH ACTION
LAUNCHER TEM 9168209029.82654
Error: #<NameError: undefined methodnotify_by_otpicker' for class
Traductor::FaceSelector'>
/users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe:66:inmethod' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe:66:in
initialize__'
/users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6faceselector.rbe:35:ininitialize' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:409:in
new'
/users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:409:ininit_face_selector' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:151:in
initialize'
/users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:85:innew' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:85:in
action__mapping'
/users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:144:incall' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:144:in
launch_action'
/users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:241:inlaunch_action' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:87:in
launch_action'
/users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:135:inblock in declare_command' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1465:in
command_invoke'
block in add_command' -
There are problems which seems to be exclusive to the MacOS M1 platforms.
So, I published a Rollback to
I hope this will be temporary, although I don't know yet what is the problem.
For users of other Platforms (Windows and Mac non-M1), you can safely keep LibFredo6 v13.1 and JointPushPull v4.6a.
Sorry for inconvenience.
No, I'm working on iMac with Intel Processor.
But today everything is ok. It seems that the computer relaunch did be more efficient than a simple Sketchup relaunch.Thanks for your help (even by mind)
There may be problems when you install LibFredo6 and have several instances of Sketchup open. You need to close them all.
NEW RELEASE: LibFredo6 v13.2a - 16 Sep 22
LibFredo6 13.2a includes:
- Various fixes for my plugins
- Support for future plugins
Note that the problem with Mac M1 platform, present in v13.1a, has been solved.
Fredo,
When I click on check for updates nothing happens.
Window: Libfredo6 Setting: Check Fredo6 Plugins for Updates. Nothing under there works until I click on Default Parameters and then is starts working.
This is the error from the Ruby Console:
c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:36:incheck_instance_displayed' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:58:in
top_dialog'
c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:336:inblock in populate_support_menu' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in
block in add_command'` -
Fredo,
Never mind. I uninstalled and reinstalled the Fredo6 library and it's all back to normal.
Fredo,
This is happening again with the same Ruby console errors and work around only this time uninstalling and reinstalling LibFredo didn't work. The rest of your plugins are working fine.
@gus r said:
Fredo,
top_dialog'
This bug is normally fixed in LibFredo6 v13.3a, just published.
NEW RELEASE: LibFredo6 v13.3a - 27 Sep 22
LibFredo6 13.3a includes:
- Major bug fixing (error about wdlg_from_key undefined)
- Bug fixing for FredoSpline (when drawing splines over an image)
Thanks Fredo.
@fredo6 said:
LibFredo6 See plugin home page of LibFredo6 for Download of LibFredo6.
The download link seems to be broken for me, for the latest update. When I click on download, I get this error:
/pluginrepo/rbz/
/var/www/html/pluginrepo/rbz/LibFredo6.rbz
File does not exist. Make sure you specified correct file name. -
That link is not a direct download link, but it takes you to a page explaining what LibFredo is...
from where you can then download its RBZ.
It's perhaps more sensible to go directly through the PluginStore, via two clicks...
https://sketchucation.com/pluginstore?pln=LibFredo6
Or even easier... use the SketchUcation Toolset's ExtensionStore³ ?? -
NEW RELEASE: LibFredo6 v13.4a - 30 Sep 22
LibFredo6 13.4a includes:
- bug fixing
- Support for ThruPaint v2.1a
I have issues when i upgrade to libfredo6 my jointpushpull and my roundcorner doesn't do anything when i click. is there anyway that i could download to the previous version, like version 12.9a i think that is the last one that is working
well never mind, it works now i just needed to restart my computer i guess..
The LibFredo6 update from Sept 22 just won't update. So I deleted it to try to reinstall. It simply does nothing when I use extension manger to install it.
Help!
NEW RELEASE: LibFredo6 v13.5a - 10 Nov 22
LibFredo6 13.5a includes:
- bug fixing for potential problems at startup
- support for future compatibility
