    [Plugin Library] LibFredo6 - v16.0a - 08 Aug 26
    2.2k Posts 580 Posters 6.2m Views 582 Watching
      jeon7373
      seek help!!
      I'm using sketchup version 2021.
      If you install and run FREDO6 LIBRARY, an error box appears.
      I don't know what went wrong
      Error Loading File Fredo6_!LibFredo6.rb
      Error: #<ArgumentError: invalid byte sequence in UTF-8>
      c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:821:in match' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:821:in block (2 levels) in load_from_config'
      c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in each' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in block in load_from_config'
      c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:818:in foreach' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:818:in load_from_config'
      c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1233:in block in load_all_plugins' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1233:in each'
      c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1233:in load_all_plugins' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:310:in startup'
      C:/Users/subin/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/subin/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
      C:/Users/subin/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
      • fredo6F Offline
        This may be a problem of installation, with files which are left over.
        Could you go to the Plugin directory, delete the folder Fredo6_!LibFredo6 and then reinstall LibFredo6 from the RBZ.
          glenn bradley
          Trying to license FredoCorner. Everything works except my ability to pay in any format? When the mouse rolls over the Pay Pal, Pay Later or Credit/Debit buttons they change appearance but will not click. Right clicking the buttons shows them as images and not active. Any ideas?
            @glenn bradley said:
            Any ideas?
            It could be for any amount of reasons from your browser, browser extensions, your javascript settings etc.
            Try a different browser and see if that helps.
            • JQLJ Offline
              JQL
              Hi Fredo,
              I've just installed a new SSD in my computer and wiped out the previous one where windows was installed.
              Between my computer and my laptop, I had used two of the 3 licenses I have for several of your plugins. Now, on the same computer, but with a different SSD, I've used the third. I've tried releasing a license but it only releases current one, not the one from the disk I had wiped out.
              How can a user set that old license free?
              This isn't a problem for me, at the moment, of course, but it still feels like a different process should be considered, because releasing the license prior to cloning the drive never crossed my mind.
              www.casca.pt
              Visit us on facebook!
                You should be able to release the license if you have the current version of the Sketchucation ExtensionStore tool.
                • JQLJ Offline
                  JQL
                  Thanks Dave!
                  I tried that but got the impression that the Release License Button only releases current version. As I wiped the disk where both windows and Sketchup with the previous version was installed, I can't activate that license anymore in order to Release it.
                  I will try it again though.
                  EDIT: I did it again and I can confirm that I can release license on current installation but it doesn't release the previous installation on the previous disk of this computer. I'd have to go back in time, use the previous disk to startup windows and sketchup, and release the license from there. Unfortunately as the disk is already wiped, I can't boot windows from it anymore.
                  www.casca.pt
                    Send the device HW ID you want released to support@sketchucation.com and we'll take a look
                    • JQLJ Offline
                      JQL
                      Hi Rich,
                      How can I find it? Is it in my Sketchucation account?
                      www.casca.pt
                        'HW ID' is shown on each extension's license dialog...
                        Use that...
                          @jql said:
                          Hi Rich,
                          Visit https://sketchucation.com/webshop/my-licences.php
                          https://i.imgur.com/aRgNr78.png
                            Also make sure that your current device can release via the https://sketchucation.com/webshop/my-licences.php
                            Make sure you are using https://sketchucation.com/plugin/696-sketchucationtools latest along with latest extensions
                            If you are running the latest bleeding edge tech that is v4.2.9 you should be able to online release your current device.
                            • N Offline
                              novarider
                              Bonjour,
                              Je cherche Γ  utiliser FredoScale, mais impossible.
                              J'ai bien suivi les instruction, mais le soucis est que je ne trouve pas comment acheter une licence.
                              Parlez vous de licence SketchUp ou licence SketchUcation ? Pouvez vous m'aider ? Merci
                                Hello I'm looking to use FredoScale, but impossible. I followed the instructions well, but the problem is that I can't figure out how to buy a license. Are you talking about a SketchUp license or SketchUcation license? Can you help me? Thank you
                                https://sketchucation.com/plugin-list.php
                                or...
                                https://i.imgur.com/NQF4gnP.png
                                https://i.imgur.com/NHJYK0U.png
                                • F Offline
                                  freeABC Newcomers
                                  δΈ‹θ½½ι€ŸεΊ¦ε’‹θΏ™δΉˆιΎŸι€Ÿε‘’οΌŸ
                                  • fredo6F Offline
                                    NEW RELEASE: LibFredo6 v13.1a - 12 Sep 22
                                    LibFredo6 13.1a includes:
                                    • Various fixes for my plugins
                                    • Support for future plugins
                                      DCDP
                                      Hello Fredo
                                      I installed the latest version of LibFredo6. But Curviloft does not work and I can't open any setup window (Purge; Check for updates).
                                      What I must to do ? Must I uninstall all your plugins and reinstall them ?
                                      Thanks for your help.
                                      • fredo6F Offline
                                        Before launching Curviloft, could you open the Ruby Console. Then Launch Curviloft, and what the console for any error message.
                                        By the way, do you have a Mac M1?
                                        • H Offline
                                          hyver
                                          Problem: bith FredoTools and JointPushPull don't do anything when launched. I see the toolbars, and the button (for example ther "J" pushpull icon) stays grey, but I don't get the parameters window, nor can I do any pushing/pulling on my model (no group or component, just a simple shape)
                                          Working on a M1 macbook pro. All plugins and lib updated, licenses paid for and validated.. frustrating!
                                          Here's the ruby console feedback: the first part is for trying to launch FredoTools, and after that the JPP
                                          Error: #<NoMethodError: undefined method wdlg_from_key' for Traductor::Wdlg:Class> /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:36:in check_instance_displayed'
                                          /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:in invoke' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_fredotools/fredotools.rbe:233:in invoke_quick_launcher'
                                          /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_fredotools/fredotools.rbe:268:in block in startup' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1465:in command_invoke'
                                          /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1445:in block (2 levels) in build_config_commands' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in block in add_command'
                                          ORIGINAL LAUNCH ACTION
                                          LAUNCHER TEM 9168209029.82654
                                          Error: #<NameError: undefined method notify_by_otpicker' for class Traductor::FaceSelector'>
                                          /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe:66:in method' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe:66:in initialize__'
                                          /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6faceselector.rbe:35:in initialize' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:409:in new'
                                          /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:409:in init_face_selector' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:151:in initialize'
                                          /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:85:in new' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:85:in action__mapping'
                                          /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:144:in call' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:144:in launch_action'
                                          /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:241:in launch_action' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:87:in launch_action'
                                          /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:135:in block in declare_command' /users/wouterdewinter/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1465:in command_invoke'
                                          • fredo6F Offline
                                            There are problems which seems to be exclusive to the MacOS M1 platforms.
                                            So, I published a Rollback to
                                            • LibFredo6 v12.9a
                                            • JointPushPull v4.4e
                                            I hope this will be temporary, although I don't know yet what is the problem.
                                            For users of other Platforms (Windows and Mac non-M1), you can safely keep LibFredo6 v13.1 and JointPushPull v4.6a.
                                            Sorry for inconvenience.
                                            • 91
                                            • 92
                                            • 93
                                            • 94
                                            • 95
                                            • 111
                                            • 112
                                            • 93 / 112
