    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
    • K
      karimtabbara
      fredo_error_plugin_license.jpgHello
      I read all, but still cannot find the answer to my problem.
      I have saved all my licenses file into a personal folder.
      When I click on "Validate a License" and choose the proper file, I get an error message "ERROR_F09".
      I have already used correctly those licenses.
      But last time there registration must have been "lost"
      I haven't been able t use these plugins for a long time because I found no way to validate them...
      As I really need them, It's now time for me to use them again.
      Could you please help?
      Print screen
        Your screenshot of the license window for FredoCorner shows an old, outdated version of the license manager. The current version is 5.7a - 50. Update the Sketchucation Extension Store and restart SketchUp.
        • K
          karimtabbara
          Hello
          Thank you for your answer but still the same problem even after updating ALL.
          I even downloaded my license again, though I had kept a copy of the file.
          More of all the dialog box searches for a "FredoCorner.scflicense" so called file.
          But the file name is SCF_Purchased_License_RoundCorner_NORMAL_20220417.scflicense
          Please see screen copy.
          I've been spending quite some time trying.
          I'm I the only one to be frustrated ?
          I have been using Fredo Corner for years for free with no problem.
          I'm happy to contribute.
          But now that I have (contributed), won't work...
          Many thanks for some help
            You are trying to apply the license for Round Corner to FredoCorner. They are two different extensions and require different licenses. The license for Round Corner doesn't work for FredoCorner.
            [Am] I the only one to be frustrated ?
            No. Others have made the same mistake. Not sure if it's a language translation problem or comprehension problem or what but the two extensions are just not the same and one license won't work for the other.
            Either install Round Corner and apply the license to it or get the license for FredoCroner. It's worth having both of them. There are some cases where one of them will work better than the other depending on the geometry you've modeled.
              jeon7373
              seek help!!
              I'm using sketchup version 2021.
              If you install and run FREDO6 LIBRARY, an error box appears.
              I don't know what went wrong
              Error Loading File Fredo6_!LibFredo6.rb
              Error: #<ArgumentError: invalid byte sequence in UTF-8>
              c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:821:in match' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:821:in block (2 levels) in load_from_config'
              c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in each' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in block in load_from_config'
              c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:818:in foreach' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:818:in load_from_config'
              c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1233:in block in load_all_plugins' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1233:in each'
              c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1233:in load_all_plugins' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:310:in startup'
              C:/Users/subin/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/subin/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
              C:/Users/subin/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
              • fredo6F
                This may be a problem of installation, with files which are left over.
                Could you go to the Plugin directory, delete the folder Fredo6_!LibFredo6 and then reinstall LibFredo6 from the RBZ.
                • G
                  glenn bradley
                  Trying to license FredoCorner. Everything works except my ability to pay in any format? When the mouse rolls over the Pay Pal, Pay Later or Credit/Debit buttons they change appearance but will not click. Right clicking the buttons shows them as images and not active. Any ideas?
                    @glenn bradley said:
                    Any ideas?
                    It could be for any amount of reasons from your browser, browser extensions, your javascript settings etc.
                    Try a different browser and see if that helps.
                    • JQLJ
                      JQL
                      Hi Fredo,
                      I've just installed a new SSD in my computer and wiped out the previous one where windows was installed.
                      Between my computer and my laptop, I had used two of the 3 licenses I have for several of your plugins. Now, on the same computer, but with a different SSD, I've used the third. I've tried releasing a license but it only releases current one, not the one from the disk I had wiped out.
                      How can a user set that old license free?
                      This isn't a problem for me, at the moment, of course, but it still feels like a different process should be considered, because releasing the license prior to cloning the drive never crossed my mind.
                      www.casca.pt
                      Visit us on facebook!
                        You should be able to release the license if you have the current version of the Sketchucation ExtensionStore tool.
                        • JQLJ
                          JQL
                          Thanks Dave!
                          I tried that but got the impression that the Release License Button only releases current version. As I wiped the disk where both windows and Sketchup with the previous version was installed, I can't activate that license anymore in order to Release it.
                          I will try it again though.
                          EDIT: I did it again and I can confirm that I can release license on current installation but it doesn't release the previous installation on the previous disk of this computer. I'd have to go back in time, use the previous disk to startup windows and sketchup, and release the license from there. Unfortunately as the disk is already wiped, I can't boot windows from it anymore.
                          www.casca.pt
                            Send the device HW ID you want released to support@sketchucation.com and we'll take a look
                            • JQLJ
                              JQL
                              Hi Rich,
                              How can I find it? Is it in my Sketchucation account?
                              www.casca.pt
                                'HW ID' is shown on each extension's license dialog...
                                Use that...
                                  @jql said:
                                  Hi Rich,
                                  Visit https://sketchucation.com/webshop/my-licences.php
                                  https://i.imgur.com/aRgNr78.png
                                    Also make sure that your current device can release via the https://sketchucation.com/webshop/my-licences.php
                                    Make sure you are using https://sketchucation.com/plugin/696-sketchucationtools latest along with latest extensions
                                    If you are running the latest bleeding edge tech that is v4.2.9 you should be able to online release your current device.
                                    • N
                                      novarider
                                      Bonjour,
                                      Je cherche Γ  utiliser FredoScale, mais impossible.
                                      J'ai bien suivi les instruction, mais le soucis est que je ne trouve pas comment acheter une licence.
                                      Parlez vous de licence SketchUp ou licence SketchUcation ? Pouvez vous m'aider ? Merci
                                        Hello I'm looking to use FredoScale, but impossible. I followed the instructions well, but the problem is that I can't figure out how to buy a license. Are you talking about a SketchUp license or SketchUcation license? Can you help me? Thank you
                                        SketchUcation | List of Plugin Licences
                                        (sketchucation.com)
                                        or...
                                        https://i.imgur.com/NQF4gnP.png
                                        https://i.imgur.com/NHJYK0U.png
                                        • F
                                          freeABC Newcomers
                                          δΈ‹θ½½ι€ŸεΊ¦ε’‹θΏ™δΉˆιΎŸι€Ÿε‘’οΌŸ
                                          • fredo6F
                                            NEW RELEASE: LibFredo6 v13.1a - 12 Sep 22
                                            LibFredo6 13.1a includes:
                                            • Various fixes for my plugins
                                            • Support for future plugins
                                            • 91
                                            • 92
                                            • 93
                                            • 94
                                            • 95
                                            • 113
                                            • 114
                                            • 93 / 114
