    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    439 Posts 152 Posters 548.3k Views 150 Watching
    • fredo6F Offline
      @pilou said:
      @Fredo : Pas de problème, d'ailleurs je n'avais même pas trouvé le fichier! 😄
      Windows est un tel labyrinthe ! 💚
      Actually, in my plugins, you translate from within the plugin, not from files: Menu "Language Translation".
      But don't worry I'll take care of French in due time.
        dihe
        Tank you Fredo,
        Variable offset is grate thing!
        Grate job!
        • fredo6F Offline
          NEW RELEASE: FredoCorner v1.1a - 06 Sep 18
          FredoCorner 1.1a is the first public release.
          Requirement: LibFredo6 8.6b
          Please note that:
          • there are known issues and likely bugs here and there
          • This concerns in particular the Collision, i.e. when the offset is too large.
          • Terminal corners (that is with a single edge) may present issues and bugs
          • Variable offset tools are experimental
          • No documentation yet, so watch the videos that I will publish.
          Please report issues, questions and any feedback in the present thread
          Home Page of FredoCorner for information and Download.
          Main post of this FredoCorner thread.
          • cmdC Offline
            cmd
            @fredo6 said:
            Reply to this post with what is displayed in the Ruby console
            Fredo,
            Your TestMacMouse.rb test results are below:
            MButton down flags = 33554432
            OnMouseMove flags = 33554432
            MButton Up flags = 0
            Also, after installing LibFredo6 8.6b, the Pan & Orbit bug appears to be fixed 😄
            I hope this helps
            CMD
            • CMD
            • fredo6F Offline
              I hope this helps
              CMD
              Many thanks. Very helpful indeed.
              • fredo6F Offline
                NEW RELEASE: FredoCorner v1.1b - 08 Sep 18
                FredoCorner 1.1b includes a fix for the orbiting on Mac platforms, as well as a first translation in Spanish by Oxer.
                Requirement: LibFredo6 8.6c
                Please note that:
                • This concerns in particular Collisions, i.e. when the offset is too large.
                • Terminal corners (that is ending on a single edge) may present issues and bugs
                • ArcA Offline
                  Arc
                  Thank you Fredo for your great work.
                  I created the Chinese simplified language file, here is:
                  FredoCorner_ZH.lang
                  • JQLJ Offline
                    JQL
                    Amazing work Fredo. It's really impressive how much you've put into it.
                    I always avoid using round corners just because of everything you've tried to circumvent with FredoCorner, so even if I'm already so used to avoid them I will definetely give this one a try.
                    Thanks for pushing the boundaries! (around corners)
                    PS: I hope this can open new paths to a lot of stuff being it at the core of Sketchup or only at plugin side of things… let's see what happens!
                    PS2: I'm not offering for a PT version because I'm out of time, but if you don't have someone else doing it and if you need it, then don't hesitate to ask and I will find the time.
                    www.casca.pt
                    Visit us on facebook!
                    • PixeroP Offline
                      Pixero
                      Would it be possible with some kind of Global on/off switch so we can keep SU light and just turn it on before rendering?
                      Maybe even some code that render engines could use to have it render even without turning it on in SU view?
                        rv1974
                        GhostComps?
                        • JQLJ Offline
                          JQL
                          +1 For the Toogle
                          +1 For the Render engine only corners
                          The preview mode is much faster than generating geometry. Would it be possible to send it to a render engine like Thea instead of the sketchup geometry?
                          A bit like Skatter does.
                          www.casca.pt
                          • fredo6F Offline
                            I can possibly implement a global switch. But again, you have to be extra careful with Undo / Redo.
                            I'll take an additional approach which may be safer.
                            • fredo6F Offline
                              NEW RELEASE: FredoCorner v1.1c - 11 Sep 18
                              FredoCorner 1.1c includes some bug fixing, a full French translation as well as a first partial translation in Chinese by Arc.
                              Requirement: LibFredo6 8.6d
                              Please note that:
                              • OxerO Offline
                                Oxer
                                There is a problem with the Ctrl key modifier on macOS, the Ctrl key on Mac is like a mouse right-click, it appears the Contextual Menu, generally the function assigned to the Ctrl key on Pc is the Alt Key on Mac.
                                Example: When I'm in selection mode, if I press Alt key = Single Edge, i.e., the Alt key replaces to the Ctrl key on Mac.
                                Fredo, is there a solution to this problem?
                                • fredo6F Offline
                                  Strange. Normally, Sketchup should take care of that, as it does on PC with the Alt toggle.
                                  By the way, my understanding, the mapping of modifiers between PC and Mac is
                                  • Shift on PC --> Shift
                                  • Ctrl on PC --> Command (i.e. the apple key)
                                  • Alt on PC --> Ctrl
                                  In edge selection, ALT is used for setting the 'all connected edges' mode
                                  1. as a toggle (press and release), to set/unset this mode as the current mode
                                  2. when clicking (keep pressed), to temporarily force the selection of all connected edges, regardless of the current mode
                                  Do you have a problem for 1) only, or for both usages?
                                  In any case, I am afraid that the keyboard is lacking modifier keys, on Mac (as for Windows too). So little hope for a solution, especially because I don't have a Mac to troubleshoot.
                                  • mvollrathM Offline
                                    mvollrath
                                    Fredo, you are the best! Thank you for yet another incredible tool! I use RoundCorner daily and am very excited for the changes that come with FredoCorner!
                                    -Michael Vollrath
                                    • ArcA Offline
                                      Arc
                                      This is full Chinese translation.
                                      FredoCorner_ZH.lang
                                      • fredo6F Offline
                                        Thank you very much. That's a big work.
                                        As you may know, part of the translation of my plugins is located in LibFredo6, where I define some of the common basic strings. So if you have time, it would be nice to complete the Chinese translation of LibFredo6 (it is already largely translated).
                                        Many thanks
                                          tiout
                                          Bonjour Fredo.
                                          Je crois que tu es français donc je me permet d'écrire en français...
                                          Je viens de télécharger la version v1.1c et j'obtiens un trou a chaque sommet de cube.
                                          Est-ce normal ?
                                          ...et j'en profite pour te remercier pour tout ce travail et ces plugins qui sont devenus des outils usuels indispensables au quotidien.
                                          Édit : finalement c’est bon après avoir remis les options par défaut...
                                          • ArcA Offline
                                            Arc
                                            Many thanks
                                            Yes, I am working on it.
                                            • 21
                                            • 22
                                            • 3 / 22
