    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 731.8k Views 151 Watching
    • fredo6F
      NEW RELEASE: FredoCorner v1.1b - 08 Sep 18
      FredoCorner 1.1b includes a fix for the orbiting on Mac platforms, as well as a first translation in Spanish by Oxer.
      Requirement: LibFredo6 8.6c
      Please note that:
      • there are known issues and likely bugs here and there
      • This concerns in particular Collisions, i.e. when the offset is too large.
      • Terminal corners (that is ending on a single edge) may present issues and bugs
      • Variable offset tools are experimental
      • No documentation yet, so watch the videos that I will publish.
      Please report issues, questions and any feedback in the present thread
      Home Page of FredoCorner for information and Download.
      Main post of this FredoCorner thread.
      • ArcA
        Arc
        Thank you Fredo for your great work.
        I created the Chinese simplified language file, here is:
        FredoCorner_ZH.lang
        • JQLJ
          JQL
          Amazing work Fredo. It's really impressive how much you've put into it.
          I always avoid using round corners just because of everything you've tried to circumvent with FredoCorner, so even if I'm already so used to avoid them I will definetely give this one a try.
          Thanks for pushing the boundaries! (around corners)
          PS: I hope this can open new paths to a lot of stuff being it at the core of Sketchup or only at plugin side of things… let's see what happens!
          PS2: I'm not offering for a PT version because I'm out of time, but if you don't have someone else doing it and if you need it, then don't hesitate to ask and I will find the time.
          www.casca.pt
          Visit us on facebook!
          • PixeroP
            Pixero
            Would it be possible with some kind of Global on/off switch so we can keep SU light and just turn it on before rendering?
            Maybe even some code that render engines could use to have it render even without turning it on in SU view?
              rv1974
              GhostComps?
              • JQLJ
                JQL
                +1 For the Toogle
                +1 For the Render engine only corners
                The preview mode is much faster than generating geometry. Would it be possible to send it to a render engine like Thea instead of the sketchup geometry?
                A bit like Skatter does.
                www.casca.pt
                • fredo6F
                  I can possibly implement a global switch. But again, you have to be extra careful with Undo / Redo.
                  I'll take an additional approach which may be safer.
                  • fredo6F
                    NEW RELEASE: FredoCorner v1.1c - 11 Sep 18
                    FredoCorner 1.1c includes some bug fixing, a full French translation as well as a first partial translation in Chinese by Arc.
                    Requirement: LibFredo6 8.6d
                    Please note that:
                    • OxerO
                      Oxer
                      There is a problem with the Ctrl key modifier on macOS, the Ctrl key on Mac is like a mouse right-click, it appears the Contextual Menu, generally the function assigned to the Ctrl key on Pc is the Alt Key on Mac.
                      Example: When I'm in selection mode, if I press Alt key = Single Edge, i.e., the Alt key replaces to the Ctrl key on Mac.
                      Fredo, is there a solution to this problem?
                      • fredo6F
                        Strange. Normally, Sketchup should take care of that, as it does on PC with the Alt toggle.
                        By the way, my understanding, the mapping of modifiers between PC and Mac is
                        • Shift on PC --> Shift
                        • Ctrl on PC --> Command (i.e. the apple key)
                        • Alt on PC --> Ctrl
                        In edge selection, ALT is used for setting the 'all connected edges' mode
                        1. as a toggle (press and release), to set/unset this mode as the current mode
                        2. when clicking (keep pressed), to temporarily force the selection of all connected edges, regardless of the current mode
                        Do you have a problem for 1) only, or for both usages?
                        In any case, I am afraid that the keyboard is lacking modifier keys, on Mac (as for Windows too). So little hope for a solution, especially because I don't have a Mac to troubleshoot.
                        • mvollrathM
                          mvollrath
                          Fredo, you are the best! Thank you for yet another incredible tool! I use RoundCorner daily and am very excited for the changes that come with FredoCorner!
                          -Michael Vollrath
                          • ArcA
                            Arc
                            This is full Chinese translation.
                            FredoCorner_ZH.lang
                            • fredo6F
                              Thank you very much. That's a big work.
                              As you may know, part of the translation of my plugins is located in LibFredo6, where I define some of the common basic strings. So if you have time, it would be nice to complete the Chinese translation of LibFredo6 (it is already largely translated).
                              Many thanks
                              • T
                                tiout
                                Bonjour Fredo.
                                Je crois que tu es français donc je me permet d'écrire en français...
                                Je viens de télécharger la version v1.1c et j'obtiens un trou a chaque sommet de cube.
                                Est-ce normal ?
                                ...et j'en profite pour te remercier pour tout ce travail et ces plugins qui sont devenus des outils usuels indispensables au quotidien.
                                Édit : finalement c’est bon après avoir remis les options par défaut...
                                • ArcA
                                  Arc
                                  Many thanks
                                  Yes, I am working on it.
                                  • OxerO
                                    Oxer
                                    ALT on PC --> CMD ⌘ on Mac
                                    CTRL on PC --> ALT on Mac
                                    If I use CMD instead of ALT, the 2) usage works fine.
                                    CTRL+Left-click on Mac it's like a right-click, it appears the contextual menu, press and release CTRL key on the Mac does nothing.
                                    I translated the last version on FredoCorner to Spanish language, here is the file:
                                    FredoCorner_ES.lang.zip
                                    • fredo6F
                                      Woooh. I thought the equivalent of CTRL on PC was Command⌘ on Mac.
                                      Then within FredoCorner, does the ⌘Z works as the shortcut for Undo (for instance an edge selection), or do you need to use ALT-Z?
                                      • OxerO
                                        Oxer
                                        I talking about the use of keys modifiers on FredoCorner.
                                        If I press ⌘Z or ALT-Z these modifiers don't work for Undo (for instance an edge selection), I can Undo the operations when I do click on curved arrow (left) of the palette.
                                        macOS 10.13.6
                                        SU2016
                                        • fredo6F
                                          NEW RELEASE: FredoCorner v1.1d - 19 Sep 18
                                          FredoCorner 1.1d includes bug fixing, as well as a full translation in Spanish by Oxer and in Chinese (by Arc).
                                          Requirement: LibFredo6 8.6e
                                          Please note that:
                                          • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
                                          • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
                                          • fredo6F
                                            Oxer,
                                            You are right. Actually, this is the Sketchup API doing this mapping of CTRL on PC toward ALT on Mac. I always thought it was CTRL on PC toward ⌘ on Mac!!
                                            I can indeed change the behavior.
                                            I just open a thread to get the opinions of Mac users.
                                            PS: by the way, in the native Push Pull tool, what is the modifier key on Mac to keep the original face?
                                            • 22
                                            • 23
                                            • 3 / 23
