    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 713.7k Views 151 Watching
      dihe
      Tank you Fredo,
      Variable offset is grate thing!
      Grate job!
      • fredo6F
        NEW RELEASE: FredoCorner v1.1a - 06 Sep 18
        FredoCorner 1.1a is the first public release.
        Requirement: LibFredo6 8.6b
        Please note that:
        • there are known issues and likely bugs here and there
        • This concerns in particular the Collision, i.e. when the offset is too large.
        • Terminal corners (that is with a single edge) may present issues and bugs
        • Variable offset tools are experimental
        • No documentation yet, so watch the videos that I will publish.
        Please report issues, questions and any feedback in the present thread
        Home Page of FredoCorner for information and Download.
        Main post of this FredoCorner thread.
        • cmdC
          cmd
          @fredo6 said:
          Reply to this post with what is displayed in the Ruby console
          Fredo,
          Your TestMacMouse.rb test results are below:
          MButton down flags = 33554432
          OnMouseMove flags = 33554432
          MButton Up flags = 0
          Also, after installing LibFredo6 8.6b, the Pan & Orbit bug appears to be fixed 😄
          I hope this helps
          CMD
          • CMD
          • fredo6F
            I hope this helps
            CMD
            Many thanks. Very helpful indeed.
            • fredo6F
              NEW RELEASE: FredoCorner v1.1b - 08 Sep 18
              FredoCorner 1.1b includes a fix for the orbiting on Mac platforms, as well as a first translation in Spanish by Oxer.
              Requirement: LibFredo6 8.6c
              Please note that:
              • This concerns in particular Collisions, i.e. when the offset is too large.
              • Terminal corners (that is ending on a single edge) may present issues and bugs
              • ArcA
                Arc
                Thank you Fredo for your great work.
                I created the Chinese simplified language file, here is:
                FredoCorner_ZH.lang
                • JQLJ
                  JQL
                  Amazing work Fredo. It's really impressive how much you've put into it.
                  I always avoid using round corners just because of everything you've tried to circumvent with FredoCorner, so even if I'm already so used to avoid them I will definetely give this one a try.
                  Thanks for pushing the boundaries! (around corners)
                  PS: I hope this can open new paths to a lot of stuff being it at the core of Sketchup or only at plugin side of things… let's see what happens!
                  PS2: I'm not offering for a PT version because I'm out of time, but if you don't have someone else doing it and if you need it, then don't hesitate to ask and I will find the time.
                  www.casca.pt
                  Visit us on facebook!
                  • PixeroP
                    Pixero
                    Would it be possible with some kind of Global on/off switch so we can keep SU light and just turn it on before rendering?
                    Maybe even some code that render engines could use to have it render even without turning it on in SU view?
                      rv1974
                      GhostComps?
                      • JQLJ
                        JQL
                        +1 For the Toogle
                        +1 For the Render engine only corners
                        The preview mode is much faster than generating geometry. Would it be possible to send it to a render engine like Thea instead of the sketchup geometry?
                        A bit like Skatter does.
                        www.casca.pt
                        • fredo6F
                          I can possibly implement a global switch. But again, you have to be extra careful with Undo / Redo.
                          I'll take an additional approach which may be safer.
                          • fredo6F
                            NEW RELEASE: FredoCorner v1.1c - 11 Sep 18
                            FredoCorner 1.1c includes some bug fixing, a full French translation as well as a first partial translation in Chinese by Arc.
                            Requirement: LibFredo6 8.6d
                            Please note that:
                            • OxerO
                              Oxer
                              There is a problem with the Ctrl key modifier on macOS, the Ctrl key on Mac is like a mouse right-click, it appears the Contextual Menu, generally the function assigned to the Ctrl key on Pc is the Alt Key on Mac.
                              Example: When I'm in selection mode, if I press Alt key = Single Edge, i.e., the Alt key replaces to the Ctrl key on Mac.
                              Fredo, is there a solution to this problem?
                              • fredo6F
                                Strange. Normally, Sketchup should take care of that, as it does on PC with the Alt toggle.
                                By the way, my understanding, the mapping of modifiers between PC and Mac is
                                • Shift on PC --> Shift
                                • Ctrl on PC --> Command (i.e. the apple key)
                                • Alt on PC --> Ctrl
                                In edge selection, ALT is used for setting the 'all connected edges' mode
                                1. as a toggle (press and release), to set/unset this mode as the current mode
                                2. when clicking (keep pressed), to temporarily force the selection of all connected edges, regardless of the current mode
                                Do you have a problem for 1) only, or for both usages?
                                In any case, I am afraid that the keyboard is lacking modifier keys, on Mac (as for Windows too). So little hope for a solution, especially because I don't have a Mac to troubleshoot.
                                • mvollrathM
                                  mvollrath
                                  Fredo, you are the best! Thank you for yet another incredible tool! I use RoundCorner daily and am very excited for the changes that come with FredoCorner!
                                  -Michael Vollrath
                                  • ArcA
                                    Arc
                                    This is full Chinese translation.
                                    FredoCorner_ZH.lang
                                    • fredo6F
                                      Thank you very much. That's a big work.
                                      As you may know, part of the translation of my plugins is located in LibFredo6, where I define some of the common basic strings. So if you have time, it would be nice to complete the Chinese translation of LibFredo6 (it is already largely translated).
                                      Many thanks
                                      • T
                                        tiout
                                        Bonjour Fredo.
                                        Je crois que tu es français donc je me permet d'écrire en français...
                                        Je viens de télécharger la version v1.1c et j'obtiens un trou a chaque sommet de cube.
                                        Est-ce normal ?
                                        ...et j'en profite pour te remercier pour tout ce travail et ces plugins qui sont devenus des outils usuels indispensables au quotidien.
                                        Édit : finalement c’est bon après avoir remis les options par défaut...
                                        • ArcA
                                          Arc
                                          Many thanks
                                          Yes, I am working on it.
                                          • OxerO
                                            Oxer
                                            ALT on PC --> CMD ⌘ on Mac
                                            CTRL on PC --> ALT on Mac
                                            If I use CMD instead of ALT, the 2) usage works fine.
                                            CTRL+Left-click on Mac it's like a right-click, it appears the contextual menu, press and release CTRL key on the Mac does nothing.
                                            I translated the last version on FredoCorner to Spanish language, here is the file:
                                            FredoCorner_ES.lang.zip
                                            • 22
                                            • 23
                                            • 3 / 23
