    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.4k Views 170 Watching
      stanka
      I have a small issue with clothworks. I purchased a licence 03.01.2022 and installed it according to your instructions. However, when I try to use a pin tool it seem not to be working. The arrows won´t simply occur.
      Would be very glad for any help you could provide.
      Thanks a lot,
        What are you doing when you try to insert them? I click once to place the pin, move the cursor up a little and click again. Click on the GIF. This is in SU 2021.
        • TutorialsUpT
          TutorialsUp
          [attachment=0:230xekdk]<!-- ia0 -->pins.gif<!-- ia0 -->[/attachment:230xekdk]
          Click -- Drag -- Click-Release
          • TutorialsUpT
            TutorialsUp
            @tutorialsup said:
            Can you please add that feature. that allow us to Scale the Cloth X Y and Z axis separately. Right now cloth Scale option scale uniformly from all axis.
            Hi, Anton_S I'm still waiting for this feature,
            have you planned to add this feature?
              Try doing it as I described.
              • TutorialsUpT
                TutorialsUp
                Yes! It's worked as well 😄
                • C
                  commasense
                  Hi there,
I hope this is the right place to find help for clothworks, if not please help showing me the correct channel.
I had been using clothworks with sketchup 2017 & 2018 in my old Mac a few years back.
And currently I have problem using it with my new map m1 2021 running skectup pro 2021.
I just couldn't select the pins at all during the animation.....
I have triple checked and its not a licence issue..
                  Much appreciate if anyone can help or share experience.
thanks many
wayne
                  • I
                    Indecrafts
                    Great Plugin for sketchup users!
                    I bought the plugin over a year now and it was all okay, but after the latest update; my activation key does not work anymore, also I tried reaching out via email for technical support but no reply. it's been a month now and I am not sure if it's only me or is there anyone else who has the same experience?
                      Have you updated to Sketchucation Tools 4.2.3?
                      Plugin Store Download | SketchUcation
                      Extending SketchUp has never been easier with a suite of tools that make installing and disabling plugins and extensions a one click operation.
                      (sketchucation.com)
                      • L
                        labaruss
                        Hello,
                        I use Clothworks to position objects by gravity on faces or in containers. Clothworks is unfortunately not designed for this and that's a shame.
                        Is an option of this type envisaged which as currently:
                        • would take into account the gravity and mass of objects, their collision etc.
                        • would not alter their geometry
                        • would not multiply the components
                        • would still include the "drag" option to modify the position of objects.
                        This is a derivative use of the plugin that's true. But an answer in terms of productivity.
                        Here is what can illustrate a use.
                        https://i.goopics.net/x58s7b.jpg
                        https://i.goopics.net/dy7wlh.jpg
                        A finished example of this work.
                        https://i.goopics.net/b5tlfy.jpg
                        I don't know if I can explain here the scope and interest of this type of extension. This is the missing extension in Sketchup today to give realism to images.
                        Bonjour,
                        J'utilise Clothworks pour positionner des objets par gravité sur des faces ou dans des contenants. Clothworks n'est malheureusement pas prévu pour cela et c'est dommage.
                        Est-il envisagé une option de ce type qui comme actuellement :
                        • tiendrait compte de la gravité et la masse des objets, leur collision etc.
                        • ne modifierait pas leur géométrie
                        • ne multiplierait pas les composants
                        • comporterait toujours l'option "drag" pour modifier la position d'objets.
                        C'est une utilisation dérivée du plugin c'est vrai. Mais une réponse en terme de productivité.
                        Voici ce qui peut illustrer un usage.
                        Un exemple fini de ce travail
                        Je ne sais pas si je peux bien faire comprendre ici la portée et l'intéret de ce type d'extension. C'est l'extension manquante a Sketchup aujourd'hui pour donner du réalisme aux images.
                        • T
                          tf3
                          Hi, I bought Clothworks in Belgium but my lisence doesn’t work in other countries, especially in France where I live half time with Belgium. I sent a request but no answer until now. Thank you for help
                            Licenses are not region restricted. So there's no reason why it can't work in France.
                            Send an email to support[at]sketchucation.com with your details.
                              Anton_S
                              Hello everyone,
                              If you are a Mac OS X user, please update to ClothWorks 1.7.6. For some reason, my xCode developer certificate was revoked. This prevents ClothWorks 1.7.5 from loading on Mac OS X (and throws an error). I have resigned with a new certificate. Hopefully, this one does not get revoked.
                              I appologize for the inconvenience!
                              Thanks,
                              Anton
                                Anton_S
                                Hello everyone,
                                Announcing version 1.7.7, which fixes a bug with self-collision dramatically slowing down SketchUp. Please update!
                                Thanks,
                                Anton
                                • Paul RussamP
                                  Paul Russam
                                  I've done the 1.7.7 through the Sketchucation Store twice now and each time Windows Defender is killing it as it sees part of it as a trojan.
                                  Paul Russam
                                  English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                                    atbstudio
                                    Hi, I'm getting a virus detection from windows 11 when I trying to install the latest clothwork plugin.
                                    one time did install but the defender stop it to run and put in quaratine. at that moment I have notice the name was ver. 1.7.7a instead of 1.7.7
                                    What I can do to solve the issue??
                                      The current version is indeed v1.7.7a
                                      I have it installed and get no virus/trojan messages.
                                      I've scanned its files in Avast, Malwarebytes and Windows Defender, which all give no messages...
                                      Perhaps Anton has ideas ??
                                        sashapepperspray
                                        I am also having this problem. any ideas?
                                        • Gus RG
                                          Gus R
                                          I got one too using Windows Defender. Might be a "false positive" bug. I don't know.
                                          That's from a direct Defender scan of the rbz. Was also giving the warning when installing from SU extension manager.
                                          www.instagram.com/gusrobatto/
                                          www.facebook.com/gusrobatto
                                            Similar result
                                            https://i.imgur.com/ewXVXpl.png
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 36
                                            • 37
                                            • 30 / 37
