    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 911.4k Views 166 Watching
    • TutorialsUpT
      TutorialsUp
      @dave r said:
      @tutorialsup said:
      Click -- Drag -- Click-Release
      Try doing it as I described.
      Yes! It's worked as well 😄
      • C
        commasense
        Hi there,
I hope this is the right place to find help for clothworks, if not please help showing me the correct channel.
I had been using clothworks with sketchup 2017 & 2018 in my old Mac a few years back.
And currently I have problem using it with my new map m1 2021 running skectup pro 2021.
I just couldn't select the pins at all during the animation.....
I have triple checked and its not a licence issue..
        Much appreciate if anyone can help or share experience.
thanks many
wayne
        • I
          Indecrafts
          Great Plugin for sketchup users!
          I bought the plugin over a year now and it was all okay, but after the latest update; my activation key does not work anymore, also I tried reaching out via email for technical support but no reply. it's been a month now and I am not sure if it's only me or is there anyone else who has the same experience?
            Have you updated to Sketchucation Tools 4.2.3?
            Plugin Store Download | SketchUcation
            Extending SketchUp has never been easier with a suite of tools that make installing and disabling plugins and extensions a one click operation.
            (sketchucation.com)
            • L
              labaruss
              Hello,
              I use Clothworks to position objects by gravity on faces or in containers. Clothworks is unfortunately not designed for this and that's a shame.
              Is an option of this type envisaged which as currently:
              • would take into account the gravity and mass of objects, their collision etc.
              • would not alter their geometry
              • would not multiply the components
              • would still include the "drag" option to modify the position of objects.
              This is a derivative use of the plugin that's true. But an answer in terms of productivity.
              Here is what can illustrate a use.
              https://i.goopics.net/x58s7b.jpg
              https://i.goopics.net/dy7wlh.jpg
              A finished example of this work.
              https://i.goopics.net/b5tlfy.jpg
              I don't know if I can explain here the scope and interest of this type of extension. This is the missing extension in Sketchup today to give realism to images.
              Bonjour,
              J'utilise Clothworks pour positionner des objets par gravité sur des faces ou dans des contenants. Clothworks n'est malheureusement pas prévu pour cela et c'est dommage.
              Est-il envisagé une option de ce type qui comme actuellement :
              • tiendrait compte de la gravité et la masse des objets, leur collision etc.
              • ne modifierait pas leur géométrie
              • ne multiplierait pas les composants
              • comporterait toujours l'option "drag" pour modifier la position d'objets.
              C'est une utilisation dérivée du plugin c'est vrai. Mais une réponse en terme de productivité.
              Voici ce qui peut illustrer un usage.
              Un exemple fini de ce travail
              Je ne sais pas si je peux bien faire comprendre ici la portée et l'intéret de ce type d'extension. C'est l'extension manquante a Sketchup aujourd'hui pour donner du réalisme aux images.
              • T
                tf3
                Hi, I bought Clothworks in Belgium but my lisence doesn’t work in other countries, especially in France where I live half time with Belgium. I sent a request but no answer until now. Thank you for help
                  Licenses are not region restricted. So there's no reason why it can't work in France.
                  Send an email to support[at]sketchucation.com with your details.
                    Anton_S
                    Hello everyone,
                    If you are a Mac OS X user, please update to ClothWorks 1.7.6. For some reason, my xCode developer certificate was revoked. This prevents ClothWorks 1.7.5 from loading on Mac OS X (and throws an error). I have resigned with a new certificate. Hopefully, this one does not get revoked.
                    I appologize for the inconvenience!
                    Thanks,
                    Anton
                      Anton_S
                      Hello everyone,
                      Announcing version 1.7.7, which fixes a bug with self-collision dramatically slowing down SketchUp. Please update!
                      Thanks,
                      Anton
                      • Paul RussamP
                        Paul Russam
                        I've done the 1.7.7 through the Sketchucation Store twice now and each time Windows Defender is killing it as it sees part of it as a trojan.
                        Paul Russam
                        English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                          atbstudio
                          Hi, I'm getting a virus detection from windows 11 when I trying to install the latest clothwork plugin.
                          one time did install but the defender stop it to run and put in quaratine. at that moment I have notice the name was ver. 1.7.7a instead of 1.7.7
                          What I can do to solve the issue??
                            The current version is indeed v1.7.7a
                            I have it installed and get no virus/trojan messages.
                            I've scanned its files in Avast, Malwarebytes and Windows Defender, which all give no messages...
                            Perhaps Anton has ideas ??
                              sashapepperspray
                              I am also having this problem. any ideas?
                              • Gus RG
                                Gus R
                                I got one too using Windows Defender. Might be a "false positive" bug. I don't know.
                                That's from a direct Defender scan of the rbz. Was also giving the warning when installing from SU extension manager.
                                www.instagram.com/gusrobatto/
                                www.facebook.com/gusrobatto
                                  Similar result
                                  https://i.imgur.com/ewXVXpl.png
                                    Anton is aware of the issue. So expect some type of fix.
                                    For now I would recommend a full scan of your system to ensure Windows Defenders quarantines the suspicious file.
                                      This is weird, because I have just completed scans using three different apps on that same RBZ [and also my whole PC]... and there were no problems reported at all !
                                      • Paul RussamP
                                        Paul Russam
                                        It’s an odd one for sure.
                                        It seems Windows Defender keeps a local history of its scans/results and for some reason it can (in my words) add 2 or more past results and produce a false positive. I think this is why some of us are seeing the results above whilst others aren’t. I’m 99% sure it’s a false positive.
                                        Paul Russam
                                          Anton_S
                                          Hi, is this still an issue? Windows Defender for some reason stopped finding threats in my software after I tried scanning the binary multiple times and reporting it (assuming I reported it correctly). Let me know if Windows defender is still blocking this.
                                            atbstudio
                                            it worked. No more issue. 👍
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 31 / 36
