    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • fredo6F
      NEW RELEASE: FredoScale v3.2a - 30 Jan 22
      Requirement: LibFredo6 12.4a.
      IMPORTANT: FredoScale is no longer supported for Sketchup versions lower than SU2017.
      FredoScale 3.2a provides a workaround to an annoying bug introduced by SU2022 which affects the dimension dialog box (called by TAB). Used this version, pending a fix by Sketchup.
      Home Page of FredoScale for information and Download.
      Main post of this FredoScale thread.
      • fredo6F
        NEW RELEASE: FredoScale v3.3a - 13 Feb 22
        FredoScale 3.3a provides compatibility with 3D mouse devices; in some cases, the visual display could be desynchronized from the view when set by the 3D mouse.
          jonorman
          When using the "Stretch to target tool" I get "invalid origin" no matter where i try to start from.. Is this a bug in the software or in the user ?? (read: Me)
          • fredo6F
            Obviously, there is a big bug here.
            I will have a closer look and try to fix.
            • fredo6F
              NEW RELEASE: FredoScale v3.4a - 15 Feb 22
              FredoScale 3.4a fixes a major bug whereby all tools 'To Target' were not usable and showed a message 'Invalid Origin'.
              • fredo6F
                @jonorman
                I normally fixed the bug in FredoScale v3.4a.
                Could you confirm this is OK with you.
                Many thanks
                  jonorman
                  Uppdated, and all is back to normal... Phew.. Thank you for this quick fix 👍
                  • W
                    Wantao
                    Windows 11
                    Stretch can't snap object outside group.
                    • fredo6F
                      @wantao said:
                      Windows 11
                      [attachment=0:2wnbpg4f]<!-- ia0 -->20220311215448.jpg<!-- ia0 -->[/attachment:2wnbpg4f]
                      Not related to Windows 11, but more to a limitation of the Ruby API unfortunately.
                        It does work for me.
                        Click on the picture
                        • fredo6F
                          I think the problem is when you are within the group.
                            Sorry. I forgot to open it. How about this?
                            click on the picture
                            • fredo6F
                              The inference with the small orange point does not force alignment.
                              I think that I did that to avoid that there are too many inferences when you work inside a container context.
                              I think I can enable it.
                              • fredo6F
                                NEW RELEASE: FredoScale v3.4b - 11 Mar 22
                                FredoScale 3.4b includes:
                                • Inferences outside current context (see video below)
                                • Updated Chinese translation by Arc
                                • pascal1964P
                                  pascal1964
                                  Bonjour J'ai acheté hier matin le plugin fredoscale et je n'ai toujours pas l'accès est-ce normal?
                                  Merci de me donner la marche à suivre. Bonne journée, Pascal (skp 21 pro)
                                    Go to https://sketchucation.com/webshop/my-licences.php to retrieve your license files if the email has not arrived or is sitting in Spam
                                    • pascal1964P
                                      pascal1964
                                      J'ai déjà vérifier il est nul part 😒
                                        There is no purchase history for your account. Can you send us info to support[at]sketchucation.com with Transaction ID, Username and Email associated to payment?
                                          S1919
                                          HI Fredo,
                                          I'm an extensive user of fredoscale box stretching with exact size input. 😄 Normal image (1)
                                          I sometime have an issue with the select box of geometry, I wonder if this is an error or a way how FredoScale works.
                                          When I select geometry the green selection box is not aligned with the axis of the geometry nor the model. It's wroke, box stretching does not work then... (2)
                                          Why is the divider wroke? (3)
                                          Here you can find the screen shots: https://postimg.cc/gallery/3wyH9rC
                                          Can you help me explaining? Is there a way to reset this behavior?
                                          Searchie
                                          [url=https://postimg.cc/SnNBjWhd:in8rql33]
                                          https://i.postimg.cc/SnNBjWhd/1.png
                                          [/url:in8rql33]
                                          [url=https://postimg.cc/21cPWVjD:in8rql33]
                                          https://i.postimg.cc/21cPWVjD/2.png
                                          [/url:in8rql33]
                                          [url=https://postimg.cc/1fHx9vL4:in8rql33]
                                          https://i.postimg.cc/1fHx9vL4/3.png
                                          [/url:in8rql33]
                                          • fredo6F
                                            There is a slight imprecision in the orientation of the bounding box....
                                            ...but you can realign the bounding box easily: just hover one edge of the solid. when it highlights in orange, just click on it to align the bounding box.
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 58
                                            • 59
                                            • 52 / 59
