    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
      PVTech
      I have installed free Fredo6 V12.4a in SketchUp Pro 2018 on a Macbook. However, there are no toolbars. How does it work without toolbars? Is it because I use a free version? which version of Fredo6 can provide toolbars of animation on a Macbook?
        LibFredo is a shared dependency/library that many tools Fredo publishes use. On its own it does nothing. Without it any tools that depend on it will not work.
          LibFredo6 is mainly support files for many of Fredo6's extensions. It doesn't need a toolbar. This has nothing to do with your using a free version.
            As explained, the Lib is merely a collection of support files needed by many of Fredo's other extensions.
            On its own it does nothing...
            In your post you mention
            Fredo's extensions do include an animation toolset - you'll need to get and install that, AND remember you'll need the Fredo Lib as well...
            Search the PluginStore for it...
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v12.5a - 21 Feb 22
              LibFredo6 12.4a includes
              • Bug fixing, technical adjustments and support for future plugins
                ArmorBearer
                Fredo, I downloaded the 12.5a rbz from sketchUcation, but it does not install into SketchUp. I have SU 17.2.2555 64-bit. After I click Install Extension from the Extension Manager, I select the downloaded rbz (7.15MB) and click Open. My Extension Manager flickers a bit and then disappears. After reopening Extension Manager, I look at the LibFredo6 plugin information, and it still says the previous version.
                So I uninstalled the previous version and tried to install 12.5a again. This time, after reopening Extension Manager, I look and there is no LibFredo6 in the list.
                Is LibFredo6 no longer compatible with SU 2017? Or is there some other problem?
                • fredo6F Offline
                  LibFredo6 v12.5 is compatible with SU2017 (I use it on my Windows laptop and Mac). So, it must be something else...
                    Shridhar
                    How i can get v7.6 of this plugin
                      MACIEJka
                      Hello,
                      Probably my problem is an obvious thing, but every time I try to launch Fredo Corner, I got this messege: 'This version of Fredo Corner has expired. Please upgrade to the latest version'. I use paid licence of this plugin and before it worked without any problem. What should I do to fix it? Thank You for any help.
                      MF
                        Have you installed the latest SketchUcation Toolset, then restarted SketchUp ?
                        The licensing system was updated...
                          MACIEJka
                          Thank You TIG 👍 , I've checked all plugins and extentions. Everything is up to date. Is there any other way to check if SketchUcation Toolset is the right one?
                            Just get the latest one [v4.2.3] available form the PluginStore / ExtensionStore³...
                            • fredo6F Offline
                              @maciejka said:
                              Hello,
                              This message is about FredoCorner version (outdated), not about its license. Just upgrade FredoCorner to v2.5a (and LibFredo6 to v12.5a) and it should disappear.
                              • fredo6F Offline
                                NEW RELEASE: LibFredo6 v12.6b - 11 Mar 22
                                LibFredo6 12.6b includes
                                • Fix for alternate icon directories in Default Parameters
                                • Traces for tracking an issue with menu loading at startup (see this post)
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v12.5b - 07 Mar 22
                                  LibFredo6 12.5b includes
                                  • Updated translation to Chinese by Arc
                                  • fredo6F Offline
                                    NEW RELEASE: LibFredo6 v12.7a - 11 Mar 22
                                    LibFredo6 12.7a corrects problems introduced with v12.6 affecting some other plugins like JointPushPull. Sorry for inconvenience. For info, v12.6 includes:
                                    • pep75P Offline
                                      pep75
                                      I'm in Panic...
                                      After updating the plugins LibFredo/FredoScale) they don't work anymore! When I click on the icons they don't even show the handles...I can't do anything. I'm lost without Fredo's tools! Help!
                                      Is there a way to revert?
                                      • fredo6F Offline
                                        Can you open the Ruby console before launching FredoScale.
                                        Which version of Sketchup do you run?
                                        • pep75P Offline
                                          pep75
                                          • pep75P Offline
                                            pep75
                                            I deleted the Fredo plugins folder, temporary fils, re-installed all plugins but still have the same issue.
                                            • 108
                                            • 109
                                            • 3 / 109
