    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 593 Posters 13.7m Views 595 Watching
      As explained, the Lib is merely a collection of support files needed by many of Fredo's other extensions.
      On its own it does nothing...
      In your post you mention
      which version of Fredo6 can provide toolbars of animation on a Macbook?
      Fredo's extensions do include an animation toolset - you'll need to get and install that, AND remember you'll need the Fredo Lib as well...
      Search the PluginStore for it...
      • fredo6F
        NEW RELEASE: LibFredo6 v12.5a - 21 Feb 22
        LibFredo6 12.4a includes
        • Bug fixing, technical adjustments and support for future plugins
          ArmorBearer
          Fredo, I downloaded the 12.5a rbz from sketchUcation, but it does not install into SketchUp. I have SU 17.2.2555 64-bit. After I click Install Extension from the Extension Manager, I select the downloaded rbz (7.15MB) and click Open. My Extension Manager flickers a bit and then disappears. After reopening Extension Manager, I look at the LibFredo6 plugin information, and it still says the previous version.
          So I uninstalled the previous version and tried to install 12.5a again. This time, after reopening Extension Manager, I look and there is no LibFredo6 in the list.
          Is LibFredo6 no longer compatible with SU 2017? Or is there some other problem?
          • fredo6F
            LibFredo6 v12.5 is compatible with SU2017 (I use it on my Windows laptop and Mac). So, it must be something else...
              Shridhar
              How i can get v7.6 of this plugin
                MACIEJka
                Hello,
                Probably my problem is an obvious thing, but every time I try to launch Fredo Corner, I got this messege: 'This version of Fredo Corner has expired. Please upgrade to the latest version'. I use paid licence of this plugin and before it worked without any problem. What should I do to fix it? Thank You for any help.
                MF
                  Have you installed the latest SketchUcation Toolset, then restarted SketchUp ?
                  The licensing system was updated...
                    MACIEJka
                    Thank You TIG 👍 , I've checked all plugins and extentions. Everything is up to date. Is there any other way to check if SketchUcation Toolset is the right one?
                      Just get the latest one [v4.2.3] available form the PluginStore / ExtensionStore³...
                      • fredo6F
                        @maciejka said:
                        Hello,
                        This message is about FredoCorner version (outdated), not about its license. Just upgrade FredoCorner to v2.5a (and LibFredo6 to v12.5a) and it should disappear.
                        • fredo6F
                          NEW RELEASE: LibFredo6 v12.6b - 11 Mar 22
                          LibFredo6 12.6b includes
                          • Fix for alternate icon directories in Default Parameters
                          • Traces for tracking an issue with menu loading at startup (see this post)
                          • fredo6F
                            NEW RELEASE: LibFredo6 v12.5b - 07 Mar 22
                            LibFredo6 12.5b includes
                            • Updated translation to Chinese by Arc
                            • fredo6F
                              NEW RELEASE: LibFredo6 v12.7a - 11 Mar 22
                              LibFredo6 12.7a corrects problems introduced with v12.6 affecting some other plugins like JointPushPull. Sorry for inconvenience. For info, v12.6 includes:
                              • pep75P
                                pep75
                                I'm in Panic...
                                After updating the plugins LibFredo/FredoScale) they don't work anymore! When I click on the icons they don't even show the handles...I can't do anything. I'm lost without Fredo's tools! Help!
                                Is there a way to revert?
                                • fredo6F
                                  Can you open the Ruby console before launching FredoScale.
                                  Which version of Sketchup do you run?
                                  • pep75P
                                    pep75
                                    • pep75P
                                      pep75
                                      I deleted the Fredo plugins folder, temporary fils, re-installed all plugins but still have the same issue.
                                      • pep75P
                                        pep75
                                        I'm working with SU 22.0.216. Latest version.
                                        • fredo6F
                                          It looks like it is a problem of access rights.
                                          When upgrading Sketchup 2022, did you install with 'Run As Administrator'?
                                            @pep75 said:
                                            ...re-installed all plugins but still have the same issue.
                                            The permission denied message would imply to me that SketchUp 2022 has not been installed correctly. Close SketchUp, find the downloaded installer, right click on it, and choose Run as administrator. When offered the options, choose Repair.
                                            • 88
                                            • 89
                                            • 90
                                            • 91
                                            • 92
                                            • 115
                                            • 116
                                            • 90 / 116
