    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 11.0m Views 589 Watching
    • pep75P
      pep75
      • pep75P
        pep75
        I deleted the Fredo plugins folder, temporary fils, re-installed all plugins but still have the same issue.
        • pep75P
          pep75
          I'm working with SU 22.0.216. Latest version.
          • fredo6F
            It looks like it is a problem of access rights.
            When upgrading Sketchup 2022, did you install with 'Run As Administrator'?
              @pep75 said:
              ...re-installed all plugins but still have the same issue.
              The permission denied message would imply to me that SketchUp 2022 has not been installed correctly. Close SketchUp, find the downloaded installer, right click on it, and choose Run as administrator. When offered the options, choose Repair.
              • pep75P
                pep75
                Thanks for a the help but I'm a bit embarassed to say that I didn't know the updates are not free anymore. I ordered the package deal, installed the updated Extension Store and now everything works like a charm....
                Excuser moi!
                • V
                  virolan
                  After LibFredo6 v12.4a, many fredo plugins no longer work at all (FredoSpline, FredoScale, JointPushPull, etc.). When I click the plugin icon, nothing happens anymore. When I reinstall the old version (12.4a) back, everything works greate.
                  I have licenses for these plugins, so what happened to these LibFredo6 updates? I'm still using sketchup version 2019 because it worked fine for me so far. What could be the problem?
                    Anne O Grady
                    After more than ten years of free distribution, some of Fredo's plugins have become paid extensions.
                    Precisely, these are:
                    RoundCorner
                    JointPushPull
                    Curviloft
                    FredoScale
                    ToolsOnSurface
                    TopoShaper
                    Curvizard
                    VisuHole
                    The transition will take place as of March 1st, 2022.
                    After a 30-day free-trial period, these extensions will require a Sketchucation license.
                    Price is USD 12 per plugin, or USD 40 for the bundle of all 8 plugins. Sketchucation Premium members have a significant discount on this pricing.
                    IMPORTANT: You need to install or upgrade to Sketchucation Extension Store v4.2.4 or above.
                    This is the original post on 27th Feb 2022
                    http://sketchucation.com/forums/viewtopic.php?p=677933#p677933
                    • V
                      virolan
                      Oh... My Sketchucation Extension Store seemed to be old version, so I upgraded it, then plugins started working again. I thought this update would show up in that Sketchup Extension Manager as well, but no.
                      Thank you!
                        The SketchUp Extension Manager only shows available updates for extensions from the SketchUp Extensions Warehouse.
                        • fredo6F
                          NEW RELEASE: LibFredo6 v12.8a - 17 Mar 22
                          LibFredo6 12.8a tentatively corrects problems related to the creation of menus for my plugins. Some users experience an error preventing the plugins to load correctly. Since I am not able to reproduce, I made some changes 'blindly', hoping this would improve the situation.
                          • qwertyasQ
                            qwertyas
                            all fredo6 plugins stopped to work after last fredo6 lib update. Sketchup 2020.
                            To test if the problem is related to other plugins, I removed all my plugins from the plugin folder, and installed only sketchucation. From sketchucation plugin I installed fredo cuviloft and fredo6 lib (newest = 12.8a) and restarted Sketchup. Curviloft does not work. You can click on any of the icons but the tool does not initialize (standard cursor and prompt still visible)
                            https://ibb.co/QN3Dyb0
                              What operating system? I'm not seeing any problems with amy of Fredo6's extensions after the latest update.
                              • fredo6F
                                Could you open the Ruby Console before lunching Curviloft
                                • qwertyasQ
                                  qwertyas
                                  is there a place where I can download previous versions of the plugins (and not the very old ones - for 2017 and earlier)? Thanks
                                  • qwertyasQ
                                    qwertyas
                                    Windows 10 Home 21H1
                                    • qwertyasQ
                                      qwertyas
                                      yes, here you are:
                                      Error: #<NoMethodError: undefined method visual_version' for SCFLicense:Module> c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1733:in tem_context'
                                      c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1709:in tem_launcher' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:119:in launch_action'
                                      c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:in launch_action' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action'
                                      c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:93:in block in startup' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1460:in command_invoke'
                                      c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1441:in block (2 levels) in build_config_commands' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1378:in block in add_command'
                                      fredo6-console hosted at ImgBB
                                      Image fredo6-console hosted on ImgBB
                                      ImgBB (ibb.co)
                                      • fredo6F
                                        @qwertyas
                                        You need to upgrade to the latest version of Sketchucation ExtensionStore v4.2.4.
                                        Apparently, you have an old version.
                                          @qwertyas said:
                                          Windows 10 Home
                                          Please complete your profile with that and the SketchUp version after you update the Sketchucation Extension Store as Fredo6 directed.
                                          • qwertyasQ
                                            qwertyas
                                            @dave r said:
                                            @qwertyas said:
                                            Windows 10 Home
                                            done.
                                            Curviloft plugin is working now. Thanks!
                                            • 89
                                            • 90
                                            • 91
                                            • 92
                                            • 93
                                            • 113
                                            • 114
                                            • 91 / 114
