    [Plugin Library] LibFredo6 - v15.9d - 09 Jul 26
    2.2k Posts 580 Posters 5.7m Views 582 Watching
      ArmorBearer
      Fredo, I downloaded the 12.5a rbz from sketchUcation, but it does not install into SketchUp. I have SU 17.2.2555 64-bit. After I click Install Extension from the Extension Manager, I select the downloaded rbz (7.15MB) and click Open. My Extension Manager flickers a bit and then disappears. After reopening Extension Manager, I look at the LibFredo6 plugin information, and it still says the previous version.
      So I uninstalled the previous version and tried to install 12.5a again. This time, after reopening Extension Manager, I look and there is no LibFredo6 in the list.
      Is LibFredo6 no longer compatible with SU 2017? Or is there some other problem?
      • fredo6F Offline
        LibFredo6 v12.5 is compatible with SU2017 (I use it on my Windows laptop and Mac). So, it must be something else...
          Shridhar
          How i can get v7.6 of this plugin
            MACIEJka
            Hello,
            Probably my problem is an obvious thing, but every time I try to launch Fredo Corner, I got this messege: 'This version of Fredo Corner has expired. Please upgrade to the latest version'. I use paid licence of this plugin and before it worked without any problem. What should I do to fix it? Thank You for any help.
            MF
              Have you installed the latest SketchUcation Toolset, then restarted SketchUp ?
              The licensing system was updated...
                MACIEJka
                Thank You TIG 👍 , I've checked all plugins and extentions. Everything is up to date. Is there any other way to check if SketchUcation Toolset is the right one?
                  Just get the latest one [v4.2.3] available form the PluginStore / ExtensionStore³...
                  • fredo6F Offline
                    @maciejka said:
                    Hello,
                    This message is about FredoCorner version (outdated), not about its license. Just upgrade FredoCorner to v2.5a (and LibFredo6 to v12.5a) and it should disappear.
                    • fredo6F Offline
                      NEW RELEASE: LibFredo6 v12.6b - 11 Mar 22
                      LibFredo6 12.6b includes
                      • Fix for alternate icon directories in Default Parameters
                      • Traces for tracking an issue with menu loading at startup (see this post)
                      • fredo6F Offline
                        NEW RELEASE: LibFredo6 v12.5b - 07 Mar 22
                        LibFredo6 12.5b includes
                        • Updated translation to Chinese by Arc
                        • fredo6F Offline
                          NEW RELEASE: LibFredo6 v12.7a - 11 Mar 22
                          LibFredo6 12.7a corrects problems introduced with v12.6 affecting some other plugins like JointPushPull. Sorry for inconvenience. For info, v12.6 includes:
                          • pep75P Offline
                            pep75
                            I'm in Panic...
                            After updating the plugins LibFredo/FredoScale) they don't work anymore! When I click on the icons they don't even show the handles...I can't do anything. I'm lost without Fredo's tools! Help!
                            Is there a way to revert?
                            • fredo6F Offline
                              Can you open the Ruby console before launching FredoScale.
                              Which version of Sketchup do you run?
                              • pep75P Offline
                                pep75
                                • pep75P Offline
                                  pep75
                                  I deleted the Fredo plugins folder, temporary fils, re-installed all plugins but still have the same issue.
                                  • pep75P Offline
                                    pep75
                                    I'm working with SU 22.0.216. Latest version.
                                    • fredo6F Offline
                                      It looks like it is a problem of access rights.
                                      When upgrading Sketchup 2022, did you install with 'Run As Administrator'?
                                        @pep75 said:
                                        ...re-installed all plugins but still have the same issue.
                                        The permission denied message would imply to me that SketchUp 2022 has not been installed correctly. Close SketchUp, find the downloaded installer, right click on it, and choose Run as administrator. When offered the options, choose Repair.
                                        • pep75P Offline
                                          pep75
                                          Thanks for a the help but I'm a bit embarassed to say that I didn't know the updates are not free anymore. I ordered the package deal, installed the updated Extension Store and now everything works like a charm....
                                          Excuser moi!
                                          • V Offline
                                            virolan
                                            After LibFredo6 v12.4a, many fredo plugins no longer work at all (FredoSpline, FredoScale, JointPushPull, etc.). When I click the plugin icon, nothing happens anymore. When I reinstall the old version (12.4a) back, everything works greate.
                                            I have licenses for these plugins, so what happened to these LibFredo6 updates? I'm still using sketchup version 2019 because it worked fine for me so far. What could be the problem?
                                            • 88
                                            • 89
                                            • 90
                                            • 91
                                            • 92
                                            • 111
                                            • 112
                                            • 90 / 112
