    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 630.6k Views 155 Watching
    • BoxB Offline
      @panixia said:
      That's 100% because you set "borders" to "none". πŸ‘
      I was sure I had checked that, in fact I'm still sure that I changed to to None while trying to make it work.
      But you are absolutely correct, as soon as I set it to Contour or Grid it works perfectly.
      Sorry Fredo, all good.
      • panixiaP Offline
        panixia
        Glad that it helped.
        • BoxB Offline
          One for the D'oh book.
          • panixiaP Offline
            panixia
            Lol! 🀣
              @evilboris said:
              Can anybody help, I get this error with any object using round
              This is in SketchUp 8 as your profile indicates you are using?
              • E Offline
                EvilBoris
                Can anybody help?, I get this error with any object using round
                Date: 13-Oct-21 15:39:35
                An error occurred in Round Push Pull
                Error in Analysis of model
                undefined method `normalize' for nil:NilClass
                jointpushpullalgo.rbe: 1408 -- block in round_compute_direction
                jointpushpullalgo.rbe: 1406 -- each
                jointpushpullalgo.rbe: 1406 -- round_compute_direction
                jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
                jointpushpullalgo.rbe: 1353 -- each
                jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
                jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
                jointpushpullalgo.rbe: 1111 -- each
                jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
                jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
                jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
                jointpushpulltool.rbe: 837 -- dragging_start
                jointpushpulltool.rbe: 1527 -- onLButtonDown
                I can do this with a new document and a cube and I get this error or in an existing model.
                • JQLJ Offline
                  JQL
                  Cheers,
                  I just found out about JPP Thickening. I use JPP for ages and never noticed it there and now it just solved an issue I had. Great! Just great!
                  www.casca.pt
                  Visit us on facebook!
                  • fredo6F Offline
                    JPP Thickening is just Joint Push Pull without a button palette. Which issue did it solve?
                    • JQLJ Offline
                      JQL
                      I was trying to offset all faces of a surface exactly 20cm and both the regular JPP and Normal JPP failed while thickening seemed to work.
                      www.casca.pt
                      • Peter CzyP Offline
                        Peter Czy
                        Hello, I've been working with this plugin for a long time.
                        This question comes up in our German forum:
                        Almost all surfaces (objects) can be thickened.
                        Is it also possible to make an object thinner
                        without leaving the side edges and surfaces remaining? If it is possible, please write us how it works.
                        Many Thanks
                        Peter
                        • BoxB Offline
                          One of the setting with JPP is the second face, if you untick the that then moving inward will make things 'thinner' if that's what you mean.
                          If not, you need to show an example of what you mean.
                            Peter Czy
                            It's right, the objects get thinner when I push inward. However, edges and surfaces remain that have to be laboriously erased on a complicated object.
                            I mean those edges and lines marked with red arrows.
                            Peter
                            • BoxB Offline
                              Many questions, many possibilities.
                              Can you not Scale the object or Move the face.
                              The problem with questions like this is there is no single answer, so much depends on the shape and what you want the result to be.
                              Attaching a model would help.
                                Peter Czy
                                Its only a simple testfileIt's just one question.
                                Use Joint Push Pull to thin an object without creating edges and faces.
                                If I just move the face, the thickness won't stay even. The same applies to scaling.
                                • BoxB Offline
                                  Often the tool you think you need isn't, a simple offset and follow me is another way to do what you want, PP to correct the ends if necessary.
                                  The main point being that there are many ways to do things and some times it pays to think simply.
                                  https://i.imgur.com/gKWTSDP.gif
                                    Peter Czy
                                    Ok, thanks for the other option to change a model. That was of course a very simple test model.
                                    The time required for your option is similar to that of deleting these surfaces / edges according to JPP.
                                    In principle, we don't have an exact answer as to why these edges and faces remain when the object is thinned.
                                    I am sure that only the developer fredo6 can answer that.
                                    I will post this result in our German forum.
                                    Thanks again.
                                    Peter
                                    • BoxB Offline
                                      The reason the edges and faces exist is the nature of the tool, it is pushing back following the face and therefore creating extra geometry.
                                      This is not a bug of a fault in the software, it is doing what is expected.
                                      Use the undo option and jpp less.
                                        Pay attention to what is actually happening when you use JPP. It's extruding in the direction of the normals of the faces as it is designed to do. As Box indicates, it's doing what it is supposed to do even though that's not what you want. If you must use JPP to add the thickness and you want a different thickness, the easy thing to do would be to copy the original surface and run JPP to extrude to the desired thickness.
                                          Peter Czy
                                          Hello Dave and Box,
                                          Yes, I think the best option is to erase the face that has already been made too thick and recreate the reduced thickness.
                                          Thank you!
                                          Peter
                                          • javadvklJ Offline
                                            javadvkl
                                            How can I purchase the plugin when my country is under U. S. sanctions? 😞
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 30
                                            • 31
                                            • 23 / 31
