    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
      ramonbastos
      @gd3design said:
      See if 'Fixit 101' will get you where you're going.
      Thanks! Great plugin by the way. It worked better than cleanup, but still left some coplanar edges, and looks random too, that will give me trouble when texturing. (See attachment)
      @builder54 said:
      @ramonbastos said:
      Any tips on how to optimize it?
      You could try tweaking with Vertex Tools Merging Close Vertices. It's demonstrated in this video
      Unfortunately didn't work, some edges that I did not want to merge, got merged.
      • B
        Builder54
        On a hot summer's night you may hear the buzzing sound produced by a cicada.
        Cicadas Brood X 2021
        Sketchup Pro 2017
        QuadFace Tools, Vertex tools, SUbD
        "Don't be afraid of working hard. There are No shortcuts to mastering something."
        Robh Ruppel
        • panixiaP
          panixia
          @ramonbastos said:
          Hello! I noticed that when I use SubD, it creates some polygons that are not really necessary, making the file bigger. You can see in the example below:
          [attachment=1:155faezl]<!-- ia1 -->panela 01.png<!-- ia1 -->[/attachment:155faezl]
          [attachment=0:155faezl]<!-- ia0 -->Screenshot_53.png<!-- ia0 -->[/attachment:155faezl]
          I tried using TT's cleanup, looks like it removes some "random" lines. Of course its not random, but it leaves a lot of lines that I can erase and keep the same geometry.
          The proper way to remove those quads triangulations when it is possible (for those quads which are coplanar, that's why you can erase them) would be, after you are done with modeling, to convert the mesh into "plain mesh" and then select all and run the "remove triangulation" command from QuadFaceTools.
          Please notice that you are visually erasing those triangulation at Sketchup interface level, but at "machine level" those triangles are still present, so the model will not perform any better in any render engine or game engine, because stuff need to be triangulated in GPU.
          What actually matters in therms of model performances are mainly the amount of vertices, the number of drawcalls, the size/compression of the textures, good UV's (if you have too many UV-islands the machine will see much more vertices than you see in the viewport).
          Actually I tend to keep those triangles, because they make for proper exporting files.
          If you don't triangulate, many external formats/engines/applications will triangulate them in some automated way and you can get weird results, in particular smoothing/texturing artifacts.
          If you are into unwrapping/game engine stuff, like I am, you have to love those triangulations and want to have full control over them, instead of having some weird algorithm doing unpredictable stuff in background.
          • panixiaP
            panixia
            Do you remember the quarantine Ferrari-WIP? 🀒
            Posted some progress here:
            403 Forbidden
            (sketchucation.com)
            • kimgaK
              kimga
              Why do I get a different tresult?
              @cotty said:
              [attachment=1:2r9ag3t8]<!-- ia1 -->SCF_Cotty_subd09_SUexport.png<!-- ia1 -->[/attachment:2r9ag3t8]
              MY ATTEMPT TO DO THE SAME
              • BoxB
                Looks like you have internal faces.
                • kimgaK
                  kimga
                  And I noticed that the "i" button hides some settings too... I am getting there...
                  I`ve seen a few of your renders and as many people before, I would like to ask you, which render are you using....
                  Just found it in the thread... "It is Brighter 3D done in about a minute with two su materials and lighting from the Sketchucation HDRI Studio Pack."
                  Thank you.
                  • kimgaK
                    kimga
                    @panixia said:
                    once you catch the basic trick, every plugin you are confortable with can be useful in the process..
                    (still missing a quad version of jointpushpull or any other very needed proper quad-shell IMHO)
                    here is point tools + voronoi + split tools + vertex tools + sub-d + beziere surface + flowify
                    This was a very nice, quick, and easy exercise...only missing the render - not quite started that topic yet.... I really enjoyed it.
                    A few years behind, but hopefully I will get there.
                    BTW
                    Are SubD2, Vertex2 very different from the first version?
                    • kimgaK
                      kimga
                      @thomthom said:
                      @jql said:
                      It would be cool to have render engines integrated in the workflow maybe Tomasz could be interested and I'll poke him!
                      There are talks going on with various render engines to allow for them to render high-poly variants from the low-polys.
                      Is there such thing no?
                      What render engine suits SketchUp quad best nowadays?
                      I just started to write a list with real-time integrated engines, extensions for SketchUp. The number is overwhelmingly high. Could some, please, give me a short intro to which one to use for a quick and painless render for a beginner?
                      I used Artlantis 15 years ago. I see lots of people using V-ray. I know Twinmotion and Lumion - not really what I am after, although both are very cool. Small space or object rendering, with a focus on the material. Is it possible to set up virtual studio in SketchUp, for example with lighting and camera and just pop in the main object and make the render quicker this way?
                      Sorry that I am posting this in the Quad thread, but as I am going through the posts, the idea came up.
                      • kimgaK
                        kimga
                        @thomthom said:
                        @ely862me said:
                        In the futures, if possible, Thomas would you add more geometry along the lines Crease is activated ?
                        I'm in the progress of implementing OpenSubdiv. It does has something called adaptive subdivision - that might do what you want. But I suspect it will be at the expense of live creasing (or any live editing of the subdivided mesh). So one would have to choose if you want uniform subd that us denser but allow tweaking of the subdivided results, or adaptive for optimal polycount.
                        Is SubD2 have any of these feauters?
                          None I know of provide support for SUbD. That is if you means rendering the final mesh while displaying only the proxy in SketchUp.
                          But if you mean support for final mesh only then all engines should support it as it is only mesh data.
                          As for the best render engine, that's impossible to answer. People get both astonishing and abysmal results with the same engine. It's ability and familiarity that tends to lend to good renders regardless of preference.
                          I would say use Blender Cycles/EEVEE as a starting point. SketchUp has good interoperability via Collada file format.
                          Or via OBJ if you go from Blender to SketchUp. QuadFace Tools has a BlenderOBJ Quads importer that I find very capable.
                          Plus Blender is free and Open Source so there's no hit on your wallet/purse etc.
                          • kimgaK
                            kimga
                            Thank you Rich,
                            Blender is on my list but was looking for real-time rendering - to eliminate the import-export time. Preferably a free extension....But I will give it a go. I am working on a lantern (very basic, but aged and batted, so would be good something that could handle glow and nice texture.) I guess it is better to show ageing at rendering level rather than modify the mesh every time...
                            • pbacotP
                              Programs like Twilight and Thea work within SketchUp, so it is an advantage in that way. You place lighting objects (provided by the renderer) in SketchUp and run the render. You can model studios and / or use image based lighting for your studio lighting and reflections. I like working this way as can work on the model over time and it's ready to render based on the scenes and settings that I have already developed, no export necessary. Blender is amazing though--it somehow does much more in terms of realtime / fast rendering on my limited system than these plugin renderers can. I suspect it helps in more advanced work, but I've not learned to use it efficiently yet.
                                Never underestimate the info you can pull from a model. Substance Painter is a good example of baking out various maps that feed their material layering system.
                                Things like curvature, AO and position maps can transform materials when used correctly. But this is higher level stuff. SketchUp at it core is generating mesh data and that is all you need in modern PBR workflows.
                                Realtime rendering, the likes of Lumion/Twinmotion are, tend to focus on ArchViz arena so their systems are optimized for those types of models. Whereas physically accurate render engines like TwiLight are suited to every scenario.
                                I think based on price and features TwiLight is probably the better choice for integrated rendering with SketchUp. Thea is a more professional tool with a less approachable workflow.
                                Horses for courses...there's no magic bullet.
                                • ely862meE
                                  ely862me
                                  Hi guys,
                                  Long time no see!
                                  How would one make a better/prettier transition here.
                                  When rendering, seems ok but I would like to have it a bit more cursive. I believe I should add another loop to the front and one near the intersection.
                                  Edit- I got it a little bit better but I am a bit unhappy with the smaller rings that will disrupt the flow a bit.
                                  Component_6.skp
                                  Elisei (sketchupper)
                                  Come and See EliseiDesign
                                    The problem is the pole happening on the prominent contour...
                                    https://i.imgur.com/EipPtTo.png
                                    ..I would refactor the geometry in this area so the RED edges are gone and the pole is pushed away [along BLUE] to a flatter area where pinching is less noticeable...
                                    https://i.imgur.com/6oC5JRV.png
                                      Like so....
                                      https://i.imgur.com/drtqZi2.png
                                      • N
                                        nlipovac
                                        I agree with Rich, and if you need to tighten curving you will have an easy flow for new loops.
                                        • kimgaK
                                          kimga
                                          @box said:
                                          Thomthom it's all your fault, I wander off to the pub with my tablet, I drink beer, I chat, I drink more beer, I doodle, I roughly render a few bits and pieces, I stagger home. While tucked up in bed 'she who must be obeyed' flicks through my doodles and now insists I must produce this hip bath in real life for her.
                                          A two beer doodle and a grainy render will drive me nuts for months.
                                          I wish I could render something like this in the PUB... I am after an easy to use SOFTWARE, still looking for ideas as I am haven`t yet downloaded any. I am a bit scared of the learning curve as well as I want to make sure it will be worth the time and effort.
                                          • BoxB
                                            Twilight Hobby is free and relatively easy to learn. It also has a good forum.
                                            As for time and effort, that is down to you.
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 83
                                            • 84
                                            • 75 / 84
