    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    699 Posts 161 Posters 669.1k Views 161 Watching
    • H Offline
      hydboxhydbox
      Hello Anton,
      I purchased the license the day before. But I am having some problems validating the license.
      Please help.
      system: OS X 10.11.6
      SketchUp: SketchUp 2017 pro
      Cloth works: ClothWorks_v1.7.4
      SketchUcationTools_v4.1.1
      I have been trying since yesterday. No any luck.
      By the way, I am not able to load the SketchUcation Plugin store in the extension, either.
        Anton_S
        @hydboxhydbox Your Mac OS is 10.11. Is it possible for you to upgrade to 10.13? I presume that could be conflicting with SketchUcation extension. Alternatively, it could be thata SCF 4.0 is not compatible with SU2017 but he details indicate that it is compatible with SU2017 and later.
        • 1 Offline
          13thRebel
          Привет. А есть ли иные способы оплатить лицензию, кроме PayPal?
          Hi. Are there any other ways to pay for the license besides PayPal?
          • H Offline
            hydboxhydbox
            Hi Anton,
            It's sorted.
            I updated my system to MacOS 10.13. and tried again. The validating message went through.
            Maybe there should be some reminder on the download page for those who still using the older macOS system.
            Thanks again.
              Anton_S
              When you purchase, PayPal is not required. You can pay with your credit/debit card directly. As far as additional payment alternatives, that is for SketchUcation to decide upon and integrate. What payment option do you have in mind?
                Anton_S
                @hydboxhydbox said:
                Hi Anton,
                It's sorted.
                Thanks again.
                Interesting case. I will inform SketUcation team about this incompatibility issue. Thank you for your test and patience!
                • 1 Offline
                  13thRebel
                  Hi. Yes, I meant a credit / debit card. When I check out, I end up always being redirected to PayPal. How exactly can I pay by card without using PayPal in any form?
                    Anton_S
                    Have you seen this option? See attached screenshot.
                    • 1 Offline
                      13thRebel
                      Yes. I attached a few screenshots.
                      As a result, payment by card, but through the PayPal service =(
                      • H Offline
                        hydboxhydbox
                        Hi Anton,
                        It's sorted.
                        Thanks again.[/quote]
                        Interesting case. I will inform SketUcation team about this incompatibility issue. Thank you for your test and patience![/quote]
                        NO problem. Thanks for the great extension.
                        I am now following the menu to give it a try and I got this exposed table edge.
                        The parameter setting is exactly the same as the ones on the example in the menu.
                          Try the settings shown here.
                          Correct the face orientation first, though. Make sure the front faces are up.
                          • H Offline
                            hydboxhydbox
                            Thanks, it fixed it.
                            Is that because I use Quadrilateral Grid + adaptive remeshing? But that is what is said in the menu. Or in simpler cases, the Quadrilateral Grid will be enough?
                              I doubt it. At least I don't get the same result you show when I use those settings.
                                s870887s
                                已購買ClothWorks的授權,但始終沒有收到許可信件
                                [mod=:15j0fr8j]Translated by Google:
                                I have purchased a license for ClothWorks, but never received a license letter[/mod:15j0fr8j]
                                  s870887s
                                  已購買ClothWorks 的授權,但始終沒有收到授權信件,
                                  我的收件信箱是hengzuan168@gmail.com,
                                  請看到回覆後,寄授權檔給我,謝謝,
                                  因為已經超過24小時了 😢
                                    gazzato70
                                    Hi, I have a licensing problem with ClothWorks. I had to format the pc without being able to release the license. After the new installation I entered the licenses of the paid plugins and ClothWorks tells me that I am using 3 licenses while in fact I only use 1 license. I don't have other PCs where I use ClothWorks. I need help resetting the licensing situation. Thank you very much
                                      請看到回覆後,寄授權檔給我,謝謝,
                                      因為已經超過24小時了 😢
                                      Check inbox for email from support@sketchucation.com
                                      https://i.imgur.com/IYTDuIm.png
                                        The license logs show 3 devices in use with the most recent validation occurring 8 days ago...
                                        https://i.imgur.com/QgKtExV.png
                                          請看到回覆後,寄授權檔給我,謝謝,
                                          因為已經超過24小時了 😢
                                          https://i.imgur.com/8JpztAy.png
                                            rodman100
                                            Email address?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 34
                                            • 35
                                            • 15 / 35
