    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 657.5k Views 155 Watching
    • I Offline
      iggi
      how do you report a bug?
      (well, I believe that what I see is a bug, not a feature πŸ˜ƒ
      version 4.4e, Sk Pro
      Regards,
      • fredo6F Offline
        @iggi,
        Can you send me the model.
        I think it has to do with the original circular profile sections, which are not generated parallel to the axes.
          rv1974
          Fredo wouldn't it be fantastic to add context-free JPP mode for edges? It would demand some smart path selection tool similar to the one in profile builder.
          http://www.scriptspot.com/files/straightencorners_cmprspd.gif
          • fredo6F Offline
            That's a different plugin, because the extrusion is based on contour lines, not faces.
            Interesting anyway.
            Which software is it?
              rv1974
              some script for Max. If you could develop it for SU.. it'd have a huge advantage because
              SU allows to 'hack' the context hierarchy.
              • panixiaP Offline
                panixia
                Which script is that? Is free?
                In Max I'm able to do 99% of that stuff without any script at all just using regular editpoly edge mode (just select the loop, set "normal" constraint, extrude/scale and then pull up and down without constraints).
                But that corner options look intriguing btw.. ❓
                I did a similar request to Thomas, because I feel that normal constraint is one of the few mayor tool still missing in the QFT/VT/SubD workflow.
                Not sure this edge job is suitable for JPP itself which is more of a shell/push/face extrude tool.
                But never put limits to the Fredo power.. Maybe some normal face extrude logic is reusable on edges? πŸ˜„
                  rv1974
                  https://www.scriptspot.com/3ds-max/scripts/extend-borders
                  Yes it'd be natural to expect tool like this from Fredo or TT. I also saw Whaat is working on all-quad Artisan 2.
                  • panixiaP Offline
                    panixia
                    Thank you. Too bad the download link doesn't work anymore. πŸ˜•
                      rv1974
                      works perfectly here.
                      try direct:
                      https://www.racoon-artworks.de/resource_extendborders.php
                      p.s. his ShapeConnect is also interesting:
                      • panixiaP Offline
                        panixia
                        @rv1974 said:
                        try direct:
                        Yes, the page works, but the download button does nothing. πŸ˜•
                          rv1974
                          Everything works here, maybe its your ad blocker- try DL via smart phone. Let's discuss it in PMs, not in the thread
                          • BoxB Offline
                            Hi Fredo
                            There seems to be an issue with JPP Normal.
                            It doesn't produce sides.
                            This is running 2021.1.299 on Win 7 with Lib 11.9c and JPP 4.4e
                            • boofredlayB Offline
                              boofredlay
                              I just tested it with 2018 Pro and it works fine. Must be something with the newer SU version.
                              • panixiaP Offline
                                panixia
                                @box said:
                                Hi Fredo
                                That's 100% because you set "borders" to "none". πŸ‘
                                • BoxB Offline
                                  I was sure I had checked that, in fact I'm still sure that I changed to to None while trying to make it work.
                                  But you are absolutely correct, as soon as I set it to Contour or Grid it works perfectly.
                                  Sorry Fredo, all good.
                                  • panixiaP Offline
                                    panixia
                                    Glad that it helped.
                                    • BoxB Offline
                                      One for the D'oh book.
                                      • panixiaP Offline
                                        panixia
                                        Lol! 🀣
                                          @evilboris said:
                                          Can anybody help, I get this error with any object using round
                                          This is in SketchUp 8 as your profile indicates you are using?
                                          • E Offline
                                            EvilBoris
                                            Can anybody help?, I get this error with any object using round
                                            Date: 13-Oct-21 15:39:35
                                            An error occurred in Round Push Pull
                                            Error in Analysis of model
                                            undefined method `normalize' for nil:NilClass
                                            jointpushpullalgo.rbe: 1408 -- block in round_compute_direction
                                            jointpushpullalgo.rbe: 1406 -- each
                                            jointpushpullalgo.rbe: 1406 -- round_compute_direction
                                            jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
                                            jointpushpullalgo.rbe: 1353 -- each
                                            jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
                                            jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
                                            jointpushpullalgo.rbe: 1111 -- each
                                            jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
                                            jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
                                            jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
                                            jointpushpulltool.rbe: 837 -- dragging_start
                                            jointpushpulltool.rbe: 1527 -- onLButtonDown
                                            I can do this with a new document and a cube and I get this error or in an existing model.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 30
                                            • 31
                                            • 14 / 31
