    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • E
      Einstein
      Then would it be possible for the plugin to skip the ill-formed faces, leave them unextruded and proceed?
      Ok, some of the faces are broken but most of them are OK. Why break entire operation due to a few wicked faces?
        Why not clean up the model before you add more geometry and potentially make more problems for yourself?
        • fredo6F
          I concur with Dave. Better clean up the model if you wish to do something with it.
          Detecting and cleaning the problem is a whole big task in itself. It could deserve a plugin. This is not like Sketchup tells you the face is ill-formed or not. Actually, these faces are toplogically valid for Sketchup but they won't work with many transformations and operations.
          So, using a detection and fixing before operating JPP would be counterproductive and a big hit to performance in 99.9% of cases where the geometry is OK.
            Thom Thom's CleanUp3 could remove coplanar edges to merge faces although it may not remove the correct edges. In this particular model it would be difficult for an extension to identify which edges should be removed.
            • E
              Einstein
              That's weird. I actually did a cleanup using ThomThom's plugin and JPP first threw an error. Then did a cleanup again and JPP worked fine.
              I don't know why it happened but sorry for bothering you.
                jpaine
                Hi everyone,
                Is project shape on a plane possible on a Mac? I can't seem to find this option.
                • I
                  iggi
                  how do you report a bug?
                  (well, I believe that what I see is a bug, not a feature πŸ˜ƒ
                  version 4.4e, Sk Pro
                  Regards,
                  • fredo6F
                    @iggi,
                    Can you send me the model.
                    I think it has to do with the original circular profile sections, which are not generated parallel to the axes.
                      rv1974
                      Fredo wouldn't it be fantastic to add context-free JPP mode for edges? It would demand some smart path selection tool similar to the one in profile builder.
                      http://www.scriptspot.com/files/straightencorners_cmprspd.gif
                      • fredo6F
                        That's a different plugin, because the extrusion is based on contour lines, not faces.
                        Interesting anyway.
                        Which software is it?
                          rv1974
                          some script for Max. If you could develop it for SU.. it'd have a huge advantage because
                          SU allows to 'hack' the context hierarchy.
                          • panixiaP
                            panixia
                            Which script is that? Is free?
                            In Max I'm able to do 99% of that stuff without any script at all just using regular editpoly edge mode (just select the loop, set "normal" constraint, extrude/scale and then pull up and down without constraints).
                            But that corner options look intriguing btw.. ❓
                            I did a similar request to Thomas, because I feel that normal constraint is one of the few mayor tool still missing in the QFT/VT/SubD workflow.
                            Not sure this edge job is suitable for JPP itself which is more of a shell/push/face extrude tool.
                            But never put limits to the Fredo power.. Maybe some normal face extrude logic is reusable on edges? πŸ˜„
                              rv1974
                              https://www.scriptspot.com/3ds-max/scripts/extend-borders
                              Yes it'd be natural to expect tool like this from Fredo or TT. I also saw Whaat is working on all-quad Artisan 2.
                              • panixiaP
                                panixia
                                Thank you. Too bad the download link doesn't work anymore. πŸ˜•
                                  rv1974
                                  works perfectly here.
                                  try direct:
                                  https://www.racoon-artworks.de/resource_extendborders.php
                                  p.s. his ShapeConnect is also interesting:
                                  • panixiaP
                                    panixia
                                    @rv1974 said:
                                    try direct:
                                    Yes, the page works, but the download button does nothing. πŸ˜•
                                      rv1974
                                      Everything works here, maybe its your ad blocker- try DL via smart phone. Let's discuss it in PMs, not in the thread
                                      • BoxB
                                        Hi Fredo
                                        There seems to be an issue with JPP Normal.
                                        It doesn't produce sides.
                                        This is running 2021.1.299 on Win 7 with Lib 11.9c and JPP 4.4e
                                        • boofredlayB
                                          boofredlay
                                          I just tested it with 2018 Pro and it works fine. Must be something with the newer SU version.
                                          • panixiaP
                                            panixia
                                            @box said:
                                            Hi Fredo
                                            That's 100% because you set "borders" to "none". πŸ‘
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 30
                                            • 31
                                            • 24 / 31
