    • Log Masuk
    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    Scheduled Pinned Kunci Moved Plugins
    619 Kiriman 156 Posters 659.0k Lihat 155 Watching
    Memuatkan lagi kiriman
    • Lama ke Baru
    • Baru ke Lama
    Balas
    Log masuk untuk balas
    Topik ini telah dipadam. Hanya pengguna dengan kuasa pengurusan boleh melihatnya.
    • T Luar talian
      theVonZipper
      It's a fantastic plugin. Can it be made to inherit the layers it's push/pulling from like the classic version?
      The VonZipper
      1 Reply Last reply Balas Petikan 0
      • P Luar talian
        pel_MEN
        Date: 13-Oct-17 23:26:00
        An error occurred in Round Push Pull
        Error in generation of the geometry
        undefined method `reverse=' for nil:NilClass
        jointpushpullgeometry.rbe: 1473 -- geometry_rounding_mesh
        jointpushpullgeometry.rbe: 1277 -- block in geometry_create_roundings
        jointpushpullgeometry.rbe: 1276 -- each
        jointpushpullgeometry.rbe: 1276 -- geometry_create_roundings
        jointpushpullgeometry.rbe: 262 -- geometry_robot_prepare_mesh
        jointpushpullgeometry.rbe: 206 -- robot_call_action
        jointpushpullgeometry.rbe: 177 -- geometry_robot_exec
        jointpushpullgeometry.rbe: 160 -- geometry_robot
        jointpushpullgeometry.rbe: 75 -- block in geometry_execute
        lib6operation.rbe: 332 -- call
        lib6operation.rbe: 332 -- step_geometry
        lib6operation.rbe: 374 -- start_execution
        jointpushpullgeometry.rbe: 75 -- geometry_execute
        jointpushpulltool.rbe: 892 -- go_preview_or_geom
        jointpushpulltool.rbe: 698 -- dragging_stop
        jointpushpulltool.rbe: 1320 -- onLButtonUp
        I Wish it`s will help you
        • fredo6F Luar talian
          @pel_MEN
          Thanks. I fixed it and will republish in JPP4
            NEW RELEASE: JointPushPull Interactive v4.1a - 23 Oct 17
            JointPushPull Interactive 4.1a is a refresh of the previous version, with evolution in 2 main areas:
            • Face selection process is now more natural, in the spirit of what is used for the native Sketchup Push Pull.
            • The button palettes have been redesigned, with 2 levels of functionality
            JointPushPull 4.1a requires LibFredo6 7.8 or above
            For those who are familiar with JointPushPull, the main changes are reviewed in the video below
            See plugin home page of JointPushPull for Download of JointPushPull.
            Main Post of the JointPushPull thread on this forum
            • panixiaP Luar talian
              panixia
              following from: https://sketchucation.com/forums/viewtopic.php?f=323&t=68433&p=626632#p626632
              I took some time to explain why I think adding a "preserve quads" method could make sense to have in both JPP and NPP. I added in attachment the example .skp, in case this can be helpful.
              I suppose there are quite a lot of people out there that uses JPP in combination with quad-friendly tools (Sub-d, QFT, VT, Curviloft, TIG extrude, Trupaint, and so on..)
              I'm curious if someone else has encountered similar problems and if, maybe they found better/alternative/faster workarounds for theese situations.
              I've created a basic quad topolgy example, in which I extrude a faceloop with Regular JPP (both with borders = "contours" and border = "each face") and Normal JPP, to show you when it would make sense to have a "preserve quads" option.
              QuadFaceTools live mesh analysis is activated, so you can see that when quad (not shadow casting) diagonals are present, all the three methods produces triangles instead of preserving the "diagonal" behaviour.
              Below you can see why this is not ideal for subdivision, as the triangles produces bad topology and smoothing artifacts.
              Here you can see an orthographic top view of the same stuff, with monocrome style and edge visibility turned off, to emphatyze the smoothing artifacts.
              With normal push pull you got an option to keep triangles, but still that doesn't preserve the "do not cast shadow" property, so that, even if the artifacts are less evident than the other methods, you can tell that the topology is slightly distorted. It's rather easy to fix this manually, just filtering selection for smooth edge (i use TT selection toys in order to do this quickly) then i check/uncheck smooth-soft/cast shadow in "entity info" dialog.
              As you previously said, hopefully this is a rather simple (but effective) option to add, in order to automate the cleanup.
              What I'm not sure is easy to fix at all, would be the quad-managing behaviour of regular JPP, as you can see below, there are a few more problems, with both methods.
              "Create borders for each face" also produces inner faces, wich completely screw the subdivisions.
              Notice that in addition to smoothing artifacts, you get messed UV, due to the topology distorsion and the presence of triangles would cause, for instance, Trupaint "quad" method to fail.
              Moreover selection of rings/loop is screwed and you'll have problems if you need to do furter modifications to the mesh or manually unwrap it, and so on..
              What I've found that DOES preserve the diagonals (at least in my experience) is regular JPP with "No Borders" option ticked.
              Unfortunately, as you can see, it destroyes the surronding edges, so that some faces are lost.
              Nevertheless, i think this method, is the best starting point for my manual workaround, which I'll try my best to show you, hoping that there's some little chance to automate/incorporate it in future developements of JPP.
              The fact wich gives me some sort of hope, is that I use your brilliant Curvyloft to fix this, so maybe you could integrate some code from that.
              Let's start with fresh geometry: to prevent missing faces, I select the geometry I need to JPP->invert selection->include inner (hole) loop in selection!!->make first group.
              Triple click the remaining loose geometry and make a second group.
              Perform JPP "No Tickening - No Borders" (diagonals preserved-live mesh analysis ok!)
              Select both groups->explode
              Pick the outer loops and run regular curviloft (lowered from default 5 segments to only 1 segment)
              Do exactly the same for inner loops
              Final cleanup: Select both curviloft groups->explode->orient faces->run ThomThom QFT"UnsmoothQuads"
              Not sure it easy/possible to replicate such operation in JPP but that would be a MAJOR improvement to the usability of JPP in organic/subdivision modelling.
              But if it's not possible we have to tank you anyway because, as you can see, with some minor tricks and workarounds JPP and Curviloft togheter have tons of usefulness in this kind of modelling! πŸ‘
              JPPquadExample.skp
                Panixia,
                1. I guess this is possible for the offset quad-face pairs to keep them coplanar when JPP-ing them.
                  However, this is more difficult for the border faces. Anyway, not a piece of cake.
                2. Incidently, I relalized I have a strange problem in SU2016 and 2017. Basically, I don't see the "hidden" and "Cast Shadow" flags in the Entity Info.
                In SU2015, this is fine
                In SU2016 and SU2017, the flags are missing.
                  panixia
                  I suspected that! 😒
                  You need to click the "+" icon on EntityInfo upper right corner to visualize those additional flags. πŸ‘
                  • thomthomT Luar talian
                    Let me know if there's anything I can help with in supporting quads.
                      @panixia said:
                      I suspected that! 😒
                      Somehow, this is equivalent to writing a Quadify surface algorithm (i.e. turn a triangular mesh into a real quad mesh). So, an optimization algorithm, with tricky topological situations.
                      By the way, this could be done independently of JPP.
                        panixia
                        Not sure I understood 100% of what you said 😍
                        But if you say it's difficult, I trust you.
                        Thank you anyway for your outstanding works. πŸ‘
                          In the initial surface, each quad is composed of 2 co-planar triangles.
                          If I understood well, you would like that in the offset surface, each quad is also composed of 2 co-planar triangles, whereas JPP does not make the triangles co-planar for each quad.
                          If so, then the problem is equivalent to take a triangulated surface where you can group triangles by pair to form quads, and then make it truly 'quadified', that is, each pair of triangles is co-planar for each quad.
                          This algorithm is complex and does not have a unique solution, only 'good-enough' solutions.
                          PS: Normal Push Pull does not have the problem, because the offset of a face is always parallel to the initial face. So the offset of 2 co-planar triangles gives the same co-planar triangles moved by the offset.
                            panixia
                            No sir, I don't need them to be coplanar: I mean they preserve pseudo/non-planar quads as per Thomthom's Quadface Tools definition.
                            https://sketchucation.com/forums/viewtopic.php?f=323&t=39442
                            That very same standard is found in Curviloft and in Trupaint "Quad Mapping Method", you added it at some point and works 100% bulletproof, whereas in JPP offsetted pseudo-quad faces are preserved, while extruded borders create "broken quads" with shadow-casting diagonals.. I suppose Thom is able to explain this better than me.. πŸ€“
                              NEW RELEASE: JointPushPull Interactive v4.2a - 12 Nov 17
                              JointPushPull Interactive 4.2a is a maintenance release:
                              • Diagonals for faces and borders are now created with the quad convention for diagonals, that is: Soft, Smooth, Hidden and NOT casting shadows
                              • Shading of the wireframe preview, based on a suggestion and code from Eneroth3
                              JointPushPull 4.1a requires LibFredo6 8.0 or above
                                panixia
                                @fredo6 said:
                                [*]Diagonals for faces and borders are now created with the quad convention for diagonals, that is: Soft, Smooth, Hidden and NOT casting shadows
                                Thank you sooooo much!!! πŸŽ‰
                                I don't have sketchup on this pc but I'll try this as soon as possible.
                                  Thank you very much for these updates Fredo!
                                  • boofredlayB Luar talian
                                    boofredlay
                                    Thank you Fredo!
                                    • T Luar talian
                                      tomaszdrgas
                                      I have little bug for JPP. Seems to be related to different matherials used for fases and edges since clearing all the materials to default helps..
                                      I often use different material for edges to make them look lighter on jpgs,so it actually happens a lot..
                                      I gave to it all default mat. and tried to replicate the error. (I marked the selection in red copied in front of it.) I added again different material to the 2 middle horizontal edges (everything else default). Still working. I added different mat. for fases sorrounding edges and it still worked. I added more mat. to all faces neighbouring with the selection to be pushedpull. Erra..
                                      I attached file..
                                      J-Fredo cleared.skp
                                      • E Luar talian
                                        Einstein
                                        Is it possible to perform Joint Push Pull on both sides (positive + negative offset) in one go?
                                        Every time I have to exit tool, select faces again and again run the tool typing opposite value.
                                        • E Luar talian
                                          Einstein
                                          @fredo6 said:
                                          @dtrarch said:
                                          Dear Fredo
                                          If it is at all possible please make the old JPP version work in SU2014?
                                          The old version was so elegant and simple and while the new and improved will do more, for me it just crashes, loses object elements and the settings do not do what they are told to do.
                                          I will be pleased to the first to add to your cookie jar if we could have the option to choose the JPP version to install.
                                          SU user since V2 and honestly I did install the new JPP properly too.
                                          I cleaned out the old version (.....roaming/sketchup and such as well)
                                          Thanks and please
                                          dtr
                                          The old version (v2.1a) is still available at the following post.
                                          It is compatible with SU2014.
                                          You can run the new and old versions concurrently.
                                          PS: do you get bugsplats or intercepted crashes (with a clean dialog box)? And If so, is it during the geometry generation?
                                          Hi!
                                          Sorry for bringing up oldish answers but the problem still remains. I have exactly the same problem as Xiombarg - cannot pushpull faces along group's local direction (X,Y,Z). I did what Dave suggested - "removed" all plugins (by renaming Plugins folder and creating a new one only for LibFredo ad JointPushPull) to see if any plugin influences behaviour of JPP - none of them does, I assume. (Only v-ray, laubwerk and adv camera tools remained) Then tried to use link you gave to download an old version of JPP - "the requested topis does not exis", says sketchucation.
                                            @Einstein
                                            I am not clear with your request.
                                            But if you look for the old Joint Push Pull, here it is.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 30
                                            • 31
                                            • 14 / 31
