    Wrap-R for SketchUp
    extensions
    191 Posts 43 Posters 200.8k Views 43 Watching
    • O Offline
      optimaforever
      Thanks for the interesting video showcasing your workflow.
      I have a pretty similar one (offset loop being a well hidden QFT feature only accessible by the shortcut or the menu 😄). I agree that Bridge loop tends to make mistake by offsetting some corresponding vertices (but again no biggie, Curviloft can help indeed). There is place for improvements here 😉
      But I'm amazed by your mastery of Wrap-R... With my meshes I can barely move vertices and it bugsplats (old SU acquaintance) often so I need to save all the time. The way you align the rims faces of the butterfly chair seems brute force... but it makes sense as you will later apply a parallel wood pattern in SBSPainter.
      BTW Do you have a particular technique to quadify an exported SU quad mesh in 3dsmax or Blender? Mines always import as tris and unwelded. I'm not an expert of Max and can't find any tuto on the web for this kind of case... When you model in Max, the mesh vertices are weld by default so Maxers don't understand my issue. I tried QFT's export as OBJ and it indeed LOOKS like a quad...
      OBJ as imported (3dsmax)
      but when I apply a turbosmooth (or a meshsmooth), it reveals that it's a tri...
      OBJ then turbosmoothed (3dsmax)
      Because of this, I can't use the Unwrap tools because it can't detect seams on TRI meshes...
      So according to you, one can Wrap-R a mesh in low poly, reload it in SU, then subD-it and it will keep the unwrapped status? I never tried this.
      This one for instane was a nightmare to WrapR...
      example of Wrap-R'd body
      • panixiaP Offline
        panixia
        Outastanding job on that car, I hope I'll be able to get near as goood results on my Ferrari F2004 model, whenever I eventually complete that WIP 😄
        Yes, that unwrapping tecnique works best for parallel patterns like that one or other similar things like stitching at borders, bricks and this kinda stuff.
        Honestly since I relased that video, I found a neat trick to perform that specific operation waaaaay faster and better.
        Yes it does something strange in the latest build of the quadface tools exporter. Older versions used to work better I hope that in the near future Thomas can take a look at this problem.
        Meanwile I've found a tricky and quite fast workaround in 3dsMax to fix that. (the actual quad clean geometry is still there you only need some brutal cleanup to get rid of the unwelded floating triangles).
        The other method to export a proper quad model to Max is to produce an obj with wrapr itself.
        This also can lead to some minor glitch in form of apparently missing geometry, but again, is quite easy to fix that.
        Yes, that's perfectly possible with some minor caveat.
        I'll try to do a short video as soon as possible demonstrating all of this, maybe could be useful both for existing users and for the developers to further improve the process. Stay tuned and forgive my bad english in advance.. 🤣
        • O Offline
          optimaforever
          Your Unity model and skills are impressive as well. I'm more a Lumion/Twinmotion guy than Unreal but there was a time when I modeled in Worldcraft (Half-Life modding tool) and had to scrutinize everything under the hood. Now, there are too many tools I need to master (from Sketchup to Allegorithmic tools, Fusion360, Blender, Zbrush, Resolve, After Effects, PS, Vray, Thea, Max, Wrap-R, Transmutr, Quixel Bridge, Megascan, etc. etc. once upon a time I was happy with just Sketchup and PS) and can't allow a lot of spare time on details (and god knows Unity and Unreal need a lot of things to be learnt)...
          Your bad english is way more understandale than mine 😄
          So yes, I'm curious to see that!
          BTW please place the text in a better position as it will be easier to read (in the video), as the bottom right isn't the best place as our eyes must continuously switch between the action (generally at the center of the frame) and the text.
          • panixiaP Offline
            panixia
            Work in progress..
            Sketchup (and of course QFT, VT2, SUbD, JointPushPull, Split Tools, Wrapr) + SculptGL + SUbstance Painter.
            I think I'll discuss this as an example for the video.. Stay tuned ☀
            • O Offline
              optimaforever
              Cute 😄
              • panixiaP Offline
                panixia
                That's Minilla from the 1967 film "Son of Godzilla".
                Originally made to be 3d printed as an x-mas gift for a 4 years old baby who really love that monster.
                Daddy will 3d print it and she will handpaint.
                Meanwhile "3d-uncle" himself, once finished the printable version, loved to "handpaint" it. 🤣
                • dereiD Offline
                  derei
                  Did anyone else experience that WrapR is deleting SubD edge creasing data?
                  DESIGNER AND ARTIST DEREI.UK
                  • O Offline
                    optimaforever
                    Personally I use WrapR on a subdivided geometry, so I don’t care but other users send a non subdivided mesh to wrapR and retrieve the wrapped skp and subD it afterwards, so I guess the creasing parameter can become an issue?
                    Recently I started exporting the mesh as obj via quadfacetools export feature to keep quads towards 3dsmax and use the unwrap modifier.
                    • panixiaP Offline
                      panixia
                      More Wrap-R stuff:
                      403 Forbidden
                      (sketchucation.com)
                        We have a WrapR build that supports keeping crease data. It has introduced some other issues we are trying to workaround.
                        But you will get support for creases sooner rather than later.
                          alpro
                          How bout textures over 512 ?
                            Non-square?
                            • panixiaP Offline
                              panixia
                              I believe I have used Wrapr with textures up to 4096 x 4096 or at least 2048 x 2048.
                                When it comes to creating UVs the image size is not important. What is important is support for non-square images which is in the works.
                                • F Offline
                                  fpsnyder
                                  Is anyone here using Wrap-R with SketchUp Pro 2021 and unable to open a .skp file in Wrap-R? I keep getting this error message when I try to do just that;
                                  “Could not open the model in LoadSketchupTextures: SU_ERROR_MODEL_VERSION” and “Sorry, we could not open the file. Error code: SU_ERROR_MODEL_VERSION in PreProcessModelGeometry”
                                  I've reached out to the developer and opened a support ticket, but the only suggestion they offered was to make sure I have the latest version of their Wrap-R software (2021.0) installed (which I do), and I've heard nothing since. I can't even use Wrap-R until this gets resolved, so I was curious if anyone else has experienced this issue.
                                  Frank
                                    Gábor
                                    @fpsnyder: Thank you for reporting this issue and sorry for the time it took to fix this issue. I believe in Wrap-R version 2021.1 we have fixed the issue.
                                    Please download the latest version from here: https://wrapr-download.s3.amazonaws.com/WrapR-installer_2021_1.exe
                                    • F Offline
                                      fpsnyder
                                      @Gabor - Thank you for resolving this issue...I was finally able to open up a file in Wrap-R using this new version you linked. I'm glad I checked back on this post today and discovered your reply. A direct email notification that you finally resolved this issue would've been appreciated. At least it works now, so all is well.
                                      Frank
                                        Sorry if this sounds daft but I'm knackered and extra thick, crispy today. Can this tool handle the texture mapping from say a 3ds max model?
                                          It can't open .max or .3ds files if that is your query?
                                          It can open .skp and .obj files and export to .obj, .dae and .skp and write the UVs for that file
                                            alpro
                                            Any update on this ?
                                            • 9 / 10
