    Wrap-R for SketchUp
    extensions
    191 Posts 43 Posters 181.7k Views 43 Watching
    • panixiaP Offline
      panixia
      That's Minilla from the 1967 film "Son of Godzilla".
      Originally made to be 3d printed as an x-mas gift for a 4 years old baby who really love that monster.
      Daddy will 3d print it and she will handpaint.
      Meanwhile "3d-uncle" himself, once finished the printable version, loved to "handpaint" it. 🤣
      • dereiD Offline
        derei
        Did anyone else experience that WrapR is deleting SubD edge creasing data?
        • O Offline
          optimaforever
          Personally I use WrapR on a subdivided geometry, so I don’t care but other users send a non subdivided mesh to wrapR and retrieve the wrapped skp and subD it afterwards, so I guess the creasing parameter can become an issue?
          Recently I started exporting the mesh as obj via quadfacetools export feature to keep quads towards 3dsmax and use the unwrap modifier.
          • panixiaP Offline
            panixia
            More Wrap-R stuff:
            https://sketchucation.com/forums/viewtopic.php?f=81&t=73991
              We have a WrapR build that supports keeping crease data. It has introduced some other issues we are trying to workaround.
              But you will get support for creases sooner rather than later.
                alpro
                How bout textures over 512 ?
                  Non-square?
                  • panixiaP Offline
                    panixia
                    I believe I have used Wrapr with textures up to 4096 x 4096 or at least 2048 x 2048.
                      When it comes to creating UVs the image size is not important. What is important is support for non-square images which is in the works.
                      • F Offline
                        fpsnyder
                        Is anyone here using Wrap-R with SketchUp Pro 2021 and unable to open a .skp file in Wrap-R? I keep getting this error message when I try to do just that;
                        “Could not open the model in LoadSketchupTextures: SU_ERROR_MODEL_VERSION” and “Sorry, we could not open the file. Error code: SU_ERROR_MODEL_VERSION in PreProcessModelGeometry”
                        I've reached out to the developer and opened a support ticket, but the only suggestion they offered was to make sure I have the latest version of their Wrap-R software (2021.0) installed (which I do), and I've heard nothing since. I can't even use Wrap-R until this gets resolved, so I was curious if anyone else has experienced this issue.
                        Frank
                          Gábor
                          @fpsnyder: Thank you for reporting this issue and sorry for the time it took to fix this issue. I believe in Wrap-R version 2021.1 we have fixed the issue.
                          Please download the latest version from here: https://wrapr-download.s3.amazonaws.com/WrapR-installer_2021_1.exe
                          • F Offline
                            fpsnyder
                            @Gabor - Thank you for resolving this issue...I was finally able to open up a file in Wrap-R using this new version you linked. I'm glad I checked back on this post today and discovered your reply. A direct email notification that you finally resolved this issue would've been appreciated. At least it works now, so all is well.
                            Frank
                              Sorry if this sounds daft but I'm knackered and extra thick, crispy today. Can this tool handle the texture mapping from say a 3ds max model?
                                It can't open .max or .3ds files if that is your query?
                                It can open .skp and .obj files and export to .obj, .dae and .skp and write the UVs for that file
                                  alpro
                                  Any update on this ?
                                    kinesis
                                    I recently purchase Wrap-R and faced several issues.
                                    *Wrap-R doesn't support none English language
                                    If I have file or file path using none English language, Wrap-R doesn't open or unwrap from sketchup. I had to work in the simple file path such my desktop and move to other place when I am done.
                                    *Wrap-R doesn't keep my work at saving 01
                                    After I finished seam work in SketchUp and unwrap from context menu, Wrap-R showed nice rather nice result, but when I save it suddenly some edges went crazy.
                                    *Wrap-R doesn't keep my work at saving 02
                                    After finishing welding edges, when I try to save, the work was undone.
                                    *Wrap-R duplicates at welding
                                    When I welded an edge, Wrap-R duplicated islands.
                                    https://youtube.com/shorts/2XuQBSPfB0I?feature=share
                                    I attached the file that has the issues.
                                    Any fix?
                                    Also a question.
                                    How do you move your Wrap-R license to your new computer?
                                    There is some issues when I first installed the program. I thought SketchUp version might be problem so I repeatedly installed and uninstalled Wrap-R several times. Then I can't license it any more. 3 seats came with the single purchase. So I wonder if I used them all.
                                    I have opened a ticket in Wrap-R support and emailed but no answer. I emailed to Gabor and he replied that he would come back with the fix last week. I am working on a time sensitive project and thought Wrap-R saved my ass. Now I started to think of refund which doesn't seem to be possible.
                                    Any answer, fix, or solution, please?
                                    taegukmoon.skp
                                      Can you share the file? To me it looks like the geometry is at fault.
                                        Gábor
                                        We are looking into the issues you have raised.
                                        @kinesis said:
                                        Also a question.
                                        About the licence. As I see your Wrap-R 2022 licence has been activated on 1 device. So you should be able to install it on 2 further devices.
                                          Ok, so as I suspected the input mesh is the primary issue.
                                          N-gons are not going to uv unwrap reliably. Triabgulate the mesh to give better results.
                                          Also your input has many strange artifacts. If you zoom to this area...
                                          https://i.imgur.com/7WqgYCi.png
                                          ...you will see the geometry is not closed...
                                          https://i.imgur.com/bGKoaMe.png
                                          It is also an area that if you triangulate properly WrapR will UV unwrap it but the geometry created by triangulating results in long narrow triangles.
                                          https://i.imgur.com/5fLSZ5r.png
                                          Based off of my detective work and forsenic examination I would deduce that the mesh is just messy. N-gons are not a good base for clean unwraps. Poor topology are not a good base for clean unwrap.
                                          But WrapR does unwrap it if you triangulate.
                                            kinesis
                                            @kinesis said:
                                            Also a question.
                                            Actually the license issue was about one of my colleague in our office. I will give you her email address for you to look at.
                                            Still the answer is how I can safely move the program to another device without spending the seat.
                                            Also if I try to reinstall the program, what is the proper procedure?
                                            • 9 / 10
