    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    554 Posts 119 Posters 1.8m Views 119 Watching
    • ntxdaveN Offline
      ntxdave
      Fredo,
      You should put a warning label on this plug-in.........its addictive. 😄
      Last one for today...........cargo drop via parachute.
      Pretty neat Charlie!!
      Press F1...thank me later
        Charlie__V
        Thanks all, it was/is fun. 😄
          db11
          When I click on airplane gif I get this each time:
          I've had a similar problem on one other site (The Verge - which fails to even load the home page), so it's likely browser related. Both these have happened since the latest Safari update, so not sure if it broke something.
          Anyone know what the issue might be? I'm running Safari on elCapitan (both with latest updates)
          • Rich O BrienR Online
            If you open this in a browser tab what happens?
            https://sketchucation.com/forums/download/file.php?id=147669%26amp;mode=view/rokbox.jpg
              db11
              Same error. It takes ~ 30 seconds for the tab to load, then it throws the error.
              I thought it might be my browser extensions, but the problem persists even with extensions off.
                Charlie__V
                I revised the length of the .gif as I experienced something similar on my Ipad.
                So this is a test to see if it is due to a time issue. (see attached)
                I will take down problem file if this resolves it.
                Charlie
                EDIT:
                This version works fine on my IPad.
                *Admin. Please let me know if you want problem file taken down or? (In case you want it to source problem)
                Flight path/cargo drop Rev1
                • F Offline
                  faust07
                  COOOL!
                    db11
                    It was only when I tried opening Rich's in a new tab that it took 30 seconds to fail. When I clicked on the gif (without opening a new tab), it threw the error immediately - and still does with the smaller file.
                    Not to worry... pretty sure the problem is with my browser
                      Charlie__V
                      fredo,
                      Per latest Beta release:
                      Cameras: Still views, Scene views, Tracking camera, all with "fade-out"
                      Q: Is the "fade out" camera related or content related? (Please indulge me as I am not well versed)
                      That said......and to attempt to further clarify.....what would "fade out".......items/content camera is "on" or would camera "fade out" or "close" focus in some way.
                      Again, many thanks for this awesome plug-in.
                      Best regards,
                      Charlie
                      • MALAISEM Offline
                        MALAISE
                        Hello
                        Some work in progress. Really useful.
                        Cheers Fredo .
                        Sample Handler
                        • fredo6F Offline
                          Pierre,
                          What a strange machine (a microscope?). I guess you have plenty of movements to demonstrate!
                            A lemon curd tartlet machine! 🤢
                            • MALAISEM Offline
                              MALAISE
                              It's a part of a sample handler for X-Ray analysis ( Copper industry, not lemon-cake... 😉)
                              • MALAISEM Offline
                                MALAISE
                                Hi Fredo,
                                Hereby, some small items I noticed using Animator V1.6a.
                                ( written in French)
                                Pierre
                                Maybe tiny improvments...
                                • fredo6F Offline
                                  Pierre,
                                  Thanks for signaling these problems. I already fixed them and will re-publish soon.
                                  Note that for time or duration setting, you should just enter the value, not keep the 's' for second .
                                  • MALAISEM Offline
                                    MALAISE
                                    Hello Fredo
                                    Question: is it possible to insert a dummy sequence in time line that shifts all the following step ?
                                    This could be usefull when some not shown process is working.
                                    Friendly
                                    Pierre
                                    some WIP
                                    • fredo6F Offline
                                      The animation made me understand the XRay Analyzer. And Pilou was wrong, not to do with pastry!
                                      I'll do the dummy sequence. I was thinking of it anyway, at least for forcing an adjustable quiet period at the beginning or the end of the clip.
                                        I was not too far away! 💚
                                        http://blog.cerfdellier.com/wp-content/uploads/2016/06/nebulacake.jpg
                                          Schicks
                                          Hi Fredo,
                                          Is there a way to resize the controls? Using a Macbook Pro Retina, the controls are tiny and hard to read. Probably something to do with the screen resolution...
                                          • fredo6F Offline
                                            New Release: Animator - v1.7a - 09 Jul 17
                                            Requirement: LibFredo6 v7.7a
                                            Major release
                                            • bug fixing and cosmetic changes
                                            • introduction of Visual Target, which is a visual effect forcing the camera to point to a given point in the model (possibly moving)
                                            • Support of high-resolution screens
                                            See main post for RBZ files
                                            • 11
                                            • 27
                                            • 28
                                            • 9 / 28
