    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
    • C
      Charlie__V
      Fredo,
      You should put a warning label on this plug-in.........its addictive. 😄
      Last one for today...........cargo drop via parachute.
      Cargo drop
      • fredo6F
        Charlie,
        Great job. I guess you used the Easing for simulating the take off. And nice utilization of the scaling for the parachute.
        One small thing: you could center the plane on the runway by moving the point of contact to be in the middle of the two wheels.
        Now you just have to build the landscape and include some views from the cockpit!
        • C
          Charlie__V
          @fredo6 said:
          Charlie,
          Thanks Fredo, I am truly honored!& yes I used easing. (see settings attachment)
          But this is some form of magic that you do, so all credit to you!
          Hard to tell but path was in the center....I may have inadvertently moved it though.
          I know.....but have to stop for today.
          Easing....polynom
          • chriC
            chri
            Magnificent job CHARLIE 👍
            Thanks for sharing
            Thanks to Fredo
            • ntxdaveN
              ntxdave
              Fredo,
              Pretty neat Charlie!!
              Press F1...thank me later
              • C
                Charlie__V
                Thanks all, it was/is fun. 😄
                  db11
                  When I click on airplane gif I get this each time:
                  I've had a similar problem on one other site (The Verge - which fails to even load the home page), so it's likely browser related. Both these have happened since the latest Safari update, so not sure if it broke something.
                  Anyone know what the issue might be? I'm running Safari on elCapitan (both with latest updates)
                    If you open this in a browser tab what happens?
                    403 Forbidden
                    (sketchucation.com)
                      db11
                      Same error. It takes ~ 30 seconds for the tab to load, then it throws the error.
                      I thought it might be my browser extensions, but the problem persists even with extensions off.
                      • C
                        Charlie__V
                        I revised the length of the .gif as I experienced something similar on my Ipad.
                        So this is a test to see if it is due to a time issue. (see attached)
                        I will take down problem file if this resolves it.
                        Charlie
                        EDIT:
                        This version works fine on my IPad.
                        *Admin. Please let me know if you want problem file taken down or? (In case you want it to source problem)
                        Flight path/cargo drop Rev1
                        • F
                          faust07
                          COOOL!
                            db11
                            It was only when I tried opening Rich's in a new tab that it took 30 seconds to fail. When I clicked on the gif (without opening a new tab), it threw the error immediately - and still does with the smaller file.
                            Not to worry... pretty sure the problem is with my browser
                            • C
                              Charlie__V
                              fredo,
                              Per latest Beta release:
                              Cameras: Still views, Scene views, Tracking camera, all with "fade-out"
                              Q: Is the "fade out" camera related or content related? (Please indulge me as I am not well versed)
                              That said......and to attempt to further clarify.....what would "fade out".......items/content camera is "on" or would camera "fade out" or "close" focus in some way.
                              Again, many thanks for this awesome plug-in.
                              Best regards,
                              Charlie
                              • MALAISEM
                                MALAISE
                                Hello
                                Some work in progress. Really useful.
                                Cheers Fredo .
                                Sample Handler
                                • fredo6F
                                  Pierre,
                                  What a strange machine (a microscope?). I guess you have plenty of movements to demonstrate!
                                    A lemon curd tartlet machine! 🤢
                                    • MALAISEM
                                      MALAISE
                                      It's a part of a sample handler for X-Ray analysis ( Copper industry, not lemon-cake... 😉)
                                      • MALAISEM
                                        MALAISE
                                        Hi Fredo,
                                        Hereby, some small items I noticed using Animator V1.6a.
                                        ( written in French)
                                        Pierre
                                        Maybe tiny improvments...
                                        • fredo6F
                                          Pierre,
                                          Thanks for signaling these problems. I already fixed them and will re-publish soon.
                                          Note that for time or duration setting, you should just enter the value, not keep the 's' for second .
                                          • MALAISEM
                                            MALAISE
                                            Hello Fredo
                                            Question: is it possible to insert a dummy sequence in time line that shifts all the following step ?
                                            This could be usefull when some not shown process is working.
                                            Friendly
                                            Pierre
                                            some WIP
                                            • 11
                                            • 29
                                            • 30
                                            • 9 / 30
