    How to make this (loft section along a helix)
    17 Posts 7 Posters 4.3k Views 7 Watching
    • BoxB Offline
      Here's another.
        Thanks Box, I will try that as I see some issues including Mapping and faceting due to the amount of segments I used. Couls somebody please exlain how to control the amount of line segments in curvmaker?
        Also is there a plugin so I can fix the mapping?
        Cheers
        • BoxB Offline
          Have a look at Fredo's Thrupaint.
          https://i.imgur.com/xqmHv48.gif
            Thanks Box, I will do that. I ran the model through a Ray trace engine as opposed to the prior real time renderer. I was pleasently suprised at the outcome. With a bit of tweeking it will look cool if I have some luck with True paint. I bow to plugin developers πŸ˜‰
              I just did a search in Sketchucation for "Thrupaint" ..............nothing, any ideas as to why?
              Cheers
              • BoxB Offline
                It's part of Fredo Tools.
                • GD3DesignG Offline
                  GD3Design
                  Cheers[/quote]
                  It is actually found in a suite of Fredo's plugins called, 'FredoTools'. https://sketchucation.com/plugin/907-fredotools
                    @gd3design said:
                    Cheers
                    It is actually found in a suite of Fredo's plugins called, 'FredoTools'. https://sketchucation.com/plugin/907-fredotools[/quote]
                    Thanks GD3 and box. Can you or anyone please suggest another plugin other than Fredo? I am sure its good but I downloaded 4 plugins today without any brainwork or problems. I would just like a plugin that is simple and easy to instal.
                      GD3Design
                      I honestly can't recommend any other plugin besides ThruPaint for this job, it is indispensable....I use it daily. Although, I remember ThomThom had a UV plugin that could get you there, but it wasn't as intuitive and always seemed a bit difficult to use for me. Also, Whaat has a UV plugin that can apply some different projection UV mapping that could possibly work here. I still prefer ThruPaint, it gives you much more power and control over your final product. But no matter how tired you are, you are still going to have to install a plugin and learn it to get this task finished.....so might as well use the best one. (ThruPaint) πŸ˜„
                        Thanks GD3, after contacting support @ Raylectron (Render engine) I was told to right click on the texture box and click on "recreate UV map" worked perfectly πŸ‘
                          I was just experimenting and kind of liked the render.
