    How to make this (loft section along a helix)
    17 Posts 7 Posters 4.4k Views 7 Watching
      Since there's always more than one way, you could use the Helix tool from Curve Maker, Adebeo Pushline, and Joint Push/Pull.
      Click on the picture
        • L
          Thanks for your help guys πŸ‘ I used Daves method, it was both easy and did the job πŸ‘ πŸ‘ One hint to others though, make sure you explode the helix before using adebo_pushline.
          • BoxB
            Here's another.
            • L
              Thanks Box, I will try that as I see some issues including Mapping and faceting due to the amount of segments I used. Couls somebody please exlain how to control the amount of line segments in curvmaker?
              Also is there a plugin so I can fix the mapping?
              Cheers
              • BoxB
                Have a look at Fredo's Thrupaint.
                https://i.imgur.com/xqmHv48.gif
                • L
                  Thanks Box, I will do that. I ran the model through a Ray trace engine as opposed to the prior real time renderer. I was pleasently suprised at the outcome. With a bit of tweeking it will look cool if I have some luck with True paint. I bow to plugin developers πŸ˜‰
                  • L
                    I just did a search in Sketchucation for "Thrupaint" ..............nothing, any ideas as to why?
                    Cheers
                    • BoxB
                      It's part of Fredo Tools.
                      • GD3DesignG
                        GD3Design
                        Cheers[/quote]
                        It is actually found in a suite of Fredo's plugins called, 'FredoTools'. https://sketchucation.com/plugin/907-fredotools
                        • L
                          @gd3design said:
                          Cheers
                          It is actually found in a suite of Fredo's plugins called, 'FredoTools'. https://sketchucation.com/plugin/907-fredotools[/quote]
                          Thanks GD3 and box. Can you or anyone please suggest another plugin other than Fredo? I am sure its good but I downloaded 4 plugins today without any brainwork or problems. I would just like a plugin that is simple and easy to instal.
                          • GD3DesignG
                            GD3Design
                            I honestly can't recommend any other plugin besides ThruPaint for this job, it is indispensable....I use it daily. Although, I remember ThomThom had a UV plugin that could get you there, but it wasn't as intuitive and always seemed a bit difficult to use for me. Also, Whaat has a UV plugin that can apply some different projection UV mapping that could possibly work here. I still prefer ThruPaint, it gives you much more power and control over your final product. But no matter how tired you are, you are still going to have to install a plugin and learn it to get this task finished.....so might as well use the best one. (ThruPaint) πŸ˜„
                            • L
                              Thanks GD3, after contacting support @ Raylectron (Render engine) I was told to right click on the texture box and click on "recreate UV map" worked perfectly πŸ‘
                              • L
                                I was just experimenting and kind of liked the render.
