    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    699 Posts 161 Posters 668.8k Views 161 Watching
    • alsomarA Offline
      alsomar Extension Creator
      @box said:
      Somewhat reminiscent of Priscilla queen of the desert......
      Anyway it's a good refecence, isn't it? ๐Ÿ˜„
      http://i.dailymail.co.uk/i/pix/2015/02/03/254C4B0D00000578-2938162-image-m-10_1422980924360.jpg
      Alejandro Soriano Visuals ยท All my links
      • BoxB Offline
        That's the one!
        Chris of the desert isn't quite the same somehow....
          So funny! ๐Ÿ˜Ž
          • BoxB Offline
            Party Time!
            https://i.imgur.com/FPx0XGD.gif
            • ntxdaveN Offline
              ntxdave
              Box, that is really intriguing! Can that be combined with other animations? As an example, could you rotate the base and streamers at the same time as the animation you did?
              I do car wash equipment and the brushes are a challenge. When the brush is not in action, the cloth strips just hang down when they go into action, they fly out somewhat similar to your animation except that the brush rotates and the pieces stand out similar to your animation and spin around as well.
              Watching the thing you guys are doing with this plugin make me wonder it it could also be used to produce some water effects by using the same techniques but with a water texture instead of cloth. If not, maybe this could be Anton's next challenge (developing a plugin for presenting water in some manners similar o this plugin).
              Press F1...thank me later
              • HornOxxH Offline
                HornOxx
                @box said:
                Party Time!
                ๐Ÿ˜ฎ ๐Ÿ˜ฎ astonishment time ๐Ÿ˜„ ๐Ÿ˜„
                just WOW !!! You're taking it to a new cool level ๐Ÿ‘ ๐Ÿ˜„
                never trust a skinny cook
                • HornOxxH Offline
                  HornOxx
                  just another test - here I condensed(?) the clothes surface by giving it a wavy shape first to receive more cloth materia density for more "crumpled" cloth on my collider... (what a complicated sentence ๐Ÿ˜„ )
                  I forgot to mention that I copied the final drop state of the cloth into a new skup instance, deleted the entire surface to get only the frame line with which I produced a follow-me figure to simulate a cloth border with thickness ...
                  • H Offline
                    huckrorick
                    I don't know if I'll have time to do a lot with this, but I just bought it because watching what people have done with it, or just playing with it, is more fun than the movies.
                    Great work Anton.
                    Can you post something that explains a bit of how it works? What are the factors that influence the simulation?
                    I was imagining using it in the design of tent structures and hanging structures. Knowing how it works would help in understanding how to use it and how good it would be for such structures.
                    Also, the "end" state would be most important in this case.
                    • BoxB Offline
                      You probably could but you would need some serious computing power. I edited my gif to give it some speed, here it is in real time on my ancient PC, notice how it stops when I orbit.
                      • alsomarA Offline
                        I tried to combine animations from SketchUp and ClockWorks with a rendered pic made with Thea Render. I used Photoshop to put them all together into a video file. The bust model is from Three D Scans.
                        • HieruH Offline
                          Hieru
                          @box said:
                          ...notice how it stops when I orbit.
                          Isn't that part of the functionality of the pugin (to prevent it from hanging up due to the extra computations required)?
                          www.davidhier.co.uk
                          • chippwaltersC Offline
                            chippwalters
                            Just so everyone understands, Anton's plugin is not intended as an animation tool. Animating cloth is part of the simulation to achieve proper draping and is used in pretty much all cloth draping toolsets I know of.
                            So, if you've ever used Marvelous Designer, Blender, or even Poser, you'll find a similar workflow where you position the cloth and then let the affectors act on it (like gravity, wind, elasticity, density, etc..) until it comes to a final resting position (or before if you stop the simulation).
                            The animations seen above are just screen captures of the simulation as it happens. Sometimes, depending on the complexity of the simulation, the frames go by very slow-- and in those cases the screen capture video is later sped up. Hope that helps.
                            Currently working with Cross-Reality technologies
                            • alsomarA Offline
                              But it can generate animations! Once the simulation is done, you can export all the frames to files (like jpg, png, etc) and put them together into a video file. Have a look to the last video I've uploaded (a couple of posts above)
                                chippwalters
                                Thank you Alejandro, I stand corrected!
                                Also, you can export frames as OBJ files for use in another program as well. Pretty snazzy.
                                Still, animations are not the primary use of this tool. It is certainly not at this time worked into any sort of animation workflow within SketchUp, which is understandable given it's nature.
                                • BoxB Offline
                                  Here's a bit of a mix with SUbD to make a rudimentary bed.
                                    smashor
                                    How can I create wrinkles? Like in a piece of cloth in a chair or bed, something like that
                                    • BoxB Offline
                                      Have you looked at any of the tutorial videos or the user manual in the first post of the thread!?
                                        smashor
                                        yes, but they dont teach that...
                                        • BoxB Offline
                                          Ok then, explain where you are having a problem and attach your model so we can see what the problem might be.
                                            david harned
                                            Hi Anton, Dave Harned here, friend of Pete Stoppel. Congratulations on Clothworks; phenomenal piece of work!
                                            I have two quick questions:
                                            • I can't seem to figure out how to drape a cloth so that it tucks into crevices fully, like a slip cover falling down "into" a sofa. I suspect the solution is to form a basic slip cover as opposed to draping a flat cloth, but wanted to ask.
                                            • Kind of related to that ... could you envision a way to use Clothworks to make ocean waves? I would kill for the ability to create realistic waves hitting a beach, but so far I can't seem to manage it in SU. I tried draping cloth over "humps" that I've "Skattered" over a surface, but I haven't quite been able to achieve what I'm trying to.
                                            Happy for any feedback. Thank you again for creating Clothworks for our community! Dave
                                            • 34
                                            • 35
                                            • 7 / 35
