    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    707 Posts 163 Posters 752.1k Views 163 Watching
    • alsomarA Offline
      alsomar Extension Creator
      I tried to combine animations from SketchUp and ClockWorks with a rendered pic made with Thea Render. I used Photoshop to put them all together into a video file. The bust model is from Three D Scans.
      Alejandro Soriano Visuals · All my links
      • HieruH Offline
        Hieru
        @box said:
        ...notice how it stops when I orbit.
        Isn't that part of the functionality of the pugin (to prevent it from hanging up due to the extra computations required)?
        www.davidhier.co.uk
        • chippwaltersC Offline
          chippwalters
          Just so everyone understands, Anton's plugin is not intended as an animation tool. Animating cloth is part of the simulation to achieve proper draping and is used in pretty much all cloth draping toolsets I know of.
          So, if you've ever used Marvelous Designer, Blender, or even Poser, you'll find a similar workflow where you position the cloth and then let the affectors act on it (like gravity, wind, elasticity, density, etc..) until it comes to a final resting position (or before if you stop the simulation).
          The animations seen above are just screen captures of the simulation as it happens. Sometimes, depending on the complexity of the simulation, the frames go by very slow-- and in those cases the screen capture video is later sped up. Hope that helps.
          Currently working with Cross-Reality technologies
          • alsomarA Offline
            But it can generate animations! Once the simulation is done, you can export all the frames to files (like jpg, png, etc) and put them together into a video file. Have a look to the last video I've uploaded (a couple of posts above)
              chippwalters
              Thank you Alejandro, I stand corrected!
              Also, you can export frames as OBJ files for use in another program as well. Pretty snazzy.
              Still, animations are not the primary use of this tool. It is certainly not at this time worked into any sort of animation workflow within SketchUp, which is understandable given it's nature.
              • BoxB Offline
                Here's a bit of a mix with SUbD to make a rudimentary bed.
                  smashor
                  How can I create wrinkles? Like in a piece of cloth in a chair or bed, something like that
                  • BoxB Offline
                    Have you looked at any of the tutorial videos or the user manual in the first post of the thread!?
                      smashor
                      yes, but they dont teach that...
                      • BoxB Offline
                        Ok then, explain where you are having a problem and attach your model so we can see what the problem might be.
                          david harned
                          Hi Anton, Dave Harned here, friend of Pete Stoppel. Congratulations on Clothworks; phenomenal piece of work!
                          I have two quick questions:
                          • I can't seem to figure out how to drape a cloth so that it tucks into crevices fully, like a slip cover falling down "into" a sofa. I suspect the solution is to form a basic slip cover as opposed to draping a flat cloth, but wanted to ask.
                          • Kind of related to that ... could you envision a way to use Clothworks to make ocean waves? I would kill for the ability to create realistic waves hitting a beach, but so far I can't seem to manage it in SU. I tried draping cloth over "humps" that I've "Skattered" over a surface, but I haven't quite been able to achieve what I'm trying to.
                          Happy for any feedback. Thank you again for creating Clothworks for our community! Dave
                            The higher the resolution of the cloth the better the drape result. This does mean the simulation runs slower to compute the draping.
                            • HieruH Offline
                              Hieru
                              Very cool. Are those dimples made using pins on the underside of the cloth?
                              www.davidhier.co.uk
                              • BoxB Offline
                                not on the underside, right there on top, just with the pin layer turned off.
                                  Pins have a falloff range based on there size.
                                  Well worth playing around with the scale to get very interesting results and surprises.
                                    marvsweden
                                    @anton_s said:
                                    @marvsweden said:
                                    Purchased. It's going to be exciting using it.
                                    I'm on Mac/SU2018 and the toggle UI window/button doesn't work. It shows up once but if I toggle it by hitting the button it never shows up again until i shut down and restart SU.
                                    Thanks for an important report! I will fix this by as soon as tomorrow (if possible).
                                    Also found that I have to activate license on each SU restart.
                                      @mars
                                      A fix for that on Mac should come next. It occurs when you shutdown a Mac.
                                        smashor
                                        I was trying to make something like this, both cloths, but I cant quite the wrinkles and I dont know how I could do it like the part next to the pillow, thats folded up
                                        3D Warehouse
                                        (3dwarehouse.sketchup.com)
                                          Anton_S
                                          Thank you, Dave! This plugin needs improvement but overtime with a few releases it will be perfect.
                                          Drop cloth at an angle with the horizontal, so that more surface are of the cloth covers the part being draped. That way there will be more cloth in an area. Another thing you can do is initially drop cloth with high stiffness and then change it to low stiffness. That way it will reach the corners.
                                          It is not possible to do waves yet.
                                          The demand for waves and wrinkles is high. It seems that waves and wrinkles are in the same area, so adding one could fulfill the other. I will include this functionality in one of the next releases, which could be used to add linear/radial wave/wrinkle effect to the cloth. Shouldn't be to difficult (if not simple) to code.
                                            Anton_S
                                            Drop cloth at an angle. Say, 60 degrees with the horizontal. Could produce wrinkles. Then apply loop subdivision and follow with a couple iterations of Laplacian smoothing to eliminte self-overlaps and of course better the result.
                                            Edit: But yes, easy way to add waves and wrinkles will be added in the next release.
                                            • 35
                                            • 36
                                            • 7 / 36
