    Smit Panther ASD Tug
    58 Posts 18 Posters 37.5k Views 18 Watching
    • Bryan KB Offline
      Superb work.
      Where do you get your references?
      Also, how did you create the hull?
      • axeonaliasA Offline
        axeonalias
        Thanks Bryan, its an interesting process that ive tried to explain as best I could here:
        ERROR: The request could not be satisfied
        (sketchfab.com)
        I can give you a specific rundown on this hull if needed?
        https://sketchfab.com/Axeonalias
        • Mike AmosM Online
          "I can give you a specific rundown on this hull if needed"?
          That would be really cool and helpful.
            axeonalias
            Step 1: Gathering info
            https://www.dropbox.com/s/7u6tb1wfy7a8p4w/Hull1.jpg?raw=1
            So step 1 is to be sure you have decent drawings (Side View and Front view is a must, top view is a bonus), rib plans are always the best but in the case I had a fairly simple hull with enough information on the drawings to create it, of course go searching for the images of the real ship out the water if you can find any!
            Step 2: Subdiv Mesh
            https://www.dropbox.com/s/ha2i1ulccsshtu7/Hull2.jpg?raw=1
            Creating the subdiv mesh is always fun, in this case I hard a few hard chine lines to deal with so I was sure to mark them out, I should have added the keel in at this stage, it would have made for a better looking mesh but with higher poly count for no reason apart from a better looking mesh.
            https://www.dropbox.com/s/g7ae1sd52xfaafr/Hull3.jpg?raw=1
            Step 3. Seperating mesh for smoothing
            https://www.dropbox.com/s/zyiotevz5jpw2tl/Hull4.jpg?raw=1
            This step is really quite dependent on the type of hull you are creating, a wooden ship for instance will not need this, to preserve the hard chine when smoothing is applied, I separate the meshs in their smoothing groups so that when it goes to blender for mapping and smoothing, it wont smoothen out the areas near the bow and stern that have less than a 35Β° angle. the tradeoff with this method is you will have separated areas on the UV for something that is essentially joined.
            Hope this helps!
              axeonalias
              The Exterior for the most part is complete, the text will probably be removed later and replaced with textures, the Poly count currently is at 438k
              https://www.dropbox.com/s/zbe35uwp7jn32l0/66.jpg?raw=1
              https://www.dropbox.com/s/8ttim7nr54w4eia/67.jpg?raw=1
              https://www.dropbox.com/s/ngx0q1sb66bqgae/68.jpg?raw=1
              https://www.dropbox.com/s/939e9cgox1p2ukp/69.jpg?raw=1
              https://www.dropbox.com/s/ryltgrcxns5rsaj/70.jpg?raw=1
              Currently 110 Hours 46 Minutes in
              • Mike AmosM Online
                Thanks very much for the TUT, looking fantastic.
                • DanielD Offline
                  Daniel
                  I'm blown away by your modeling. And inspired. Hardly touched SU in two years, but I'm starting to get the itch again.
                  My avatar is an anachronism.
                  • Bryan KB Offline
                    Thanks axeonalias.
                    That was a good explanation of your hull modeling.
                    When you subdivide and smooth, what are you using?
                      axeonalias
                      Alright I dragged my feet abit with this one, but shes finally done, the lack of accurate info for the interior left me demotivated, but after the birth of my first son I decided, I better get this one out while he is asleep!, it still took another 3 weeks to complete the exterior but im happy with the result, im going to fiddle with getting it into VSF but I have my doubts, she has 53 separate 4k textures ( made up of Diffuse, AO, Rough, Metallic, Spec and normals ) so I have my doubts that VSF will be able to render her correctly
                      If you want to have a look at her in 3d, heres the link : https://skfb.ly/6WAyG
                      Sorry for the oversize images, just zoom out with your browser to 75% and you will see the whole image.
                      https://live.staticflickr.com/65535/50625353491_a87120cb75_k.jpg
                      71R by mariusmoolman, on Flickr
                      https://live.staticflickr.com/65535/50624605458_deed8595c0_h.jpg
                      72R by mariusmoolman, on Flickr
                      https://live.staticflickr.com/65535/50625352646_e101d933fd_h.jpg
                      73R by mariusmoolman, on Flickr
                      https://live.staticflickr.com/65535/50624604533_a1b5fef404_h.jpg
                      74R by mariusmoolman, on Flickr
                      https://live.staticflickr.com/65535/50625351851_952bfa1447_h.jpg
                      75R by mariusmoolman, on Flickr
                      https://live.staticflickr.com/65535/50625351271_b3acd50715_k.jpg
                      76R by mariusmoolman, on Flickr
                      https://live.staticflickr.com/65535/50624602993_c92185557d_h.jpg
                      77 by mariusmoolman, on Flickr
                      [url=https://flic.kr/p/2k8A9Xj:1m0fwj62]
                      https://live.staticflickr.com/65535/50625350536_4956bb8a7a_h.jpg
                      [/url:1m0fwj62][url=https://flic.kr/p/2k8A9Xj:1m0fwj62]78[/url:1m0fwj62] by mariusmoolman, on Flickr
                      [url=https://flic.kr/p/2k8A9Rx:1m0fwj62]
                      https://live.staticflickr.com/65535/50625350201_434f15b5fb_k.jpg
                      [/url:1m0fwj62][url=https://flic.kr/p/2k8A9Rx:1m0fwj62]79[/url:1m0fwj62] by mariusmoolman, on Flickr
                      [url=https://flic.kr/p/2k8wjrz:1m0fwj62]
                      https://live.staticflickr.com/65535/50624602003_13f354badb_k.jpg
                      [/url:1m0fwj62][url=https://flic.kr/p/2k8wjrz:1m0fwj62]80[/url:1m0fwj62] by mariusmoolman, on Flickr
                      [url=https://flic.kr/p/2k8AEfZ:1m0fwj62]
                      https://live.staticflickr.com/65535/50625449117_fbcf1414f1_h.jpg
                      [/url:1m0fwj62][url=https://flic.kr/p/2k8AEfZ:1m0fwj62]81[/url:1m0fwj62] by mariusmoolman, on Flickr
                      • tuna1957T Offline
                        tuna1957
                        Brilliant ! Bravo πŸ‘
                        • Mike AmosM Online
                          Completely marvelous and a great inspiration. πŸ‘Š
                          • Bryan KB Offline
                            As professional as it gets. πŸ‘
                            No game, movie or engineering company could do better.
                            • HornOxxH Offline
                              HornOxx
                              ... do we have a "SketchUp Hall of Fame" somewhere here ? πŸ˜„
                              never trust a skinny cook
                              • duanekempD Offline
                                duanekemp
                                What a great project and well executed. Love the details. Bravo.
                                Duane Kemp
                                Kemp Productions
                                Puidoux, Switzerland
                                Gallery:
                                https://duanekemp.artstation.com/
                                  axeonalias
                                  Did a few Blender Ocean render with Panther :
                                  https://live.staticflickr.com/65535/52881783929_94764e92f6_k.jpg
                                  https://live.staticflickr.com/65535/52881999575_78f76ac530_k.jpg
                                  https://live.staticflickr.com/65535/52881783959_8572aca01c_k.jpg
                                  https://live.staticflickr.com/65535/52881625346_e3ac2e1c8d_k.jpg
                                  https://live.staticflickr.com/65535/52881625596_d1add45e6f_k.jpg
                                  https://live.staticflickr.com/65535/52881046172_595c23da93_k.jpg
                                  https://live.staticflickr.com/65535/52882069673_768eec1404_k.jpg
                                  https://live.staticflickr.com/65535/52882069688_99087a3491_k.jpg
                                  https://live.staticflickr.com/65535/52881784519_42360b207e_k.jpg
                                  https://live.staticflickr.com/65535/52882069968_0f25983bc7_k.jpg
                                  https://live.staticflickr.com/65535/52881625966_64f3bb1961_k.jpg
                                  https://live.staticflickr.com/65535/52882000175_e415f67463_k.jpg
                                  https://live.staticflickr.com/65535/52881784724_6282b6fddc_k.jpg
                                  • Rich O BrienR Online
                                    That's insane levels of detail. Your dedication is impressive.
                                    • Mike AmosM Online
                                      Brilliant. Wow indeed. πŸ‘Š
                                      • Bryan KB Offline
                                        Wow! Well done! πŸ‘
                                          axeonalias
                                          Took 4 years but better late than never!
                                          Smit Panthers bridge is complete, ready for testing in game before proceeding to unwrapping:
                                          https://live.staticflickr.com/65535/53098214006_c15a242e26_k.jpg
                                          https://live.staticflickr.com/65535/53098706808_7ce2552388_k.jpg
                                          https://live.staticflickr.com/65535/53098706748_43c3a99af4_k.jpg
                                          https://live.staticflickr.com/65535/53098706738_f639060272_k.jpg
                                          https://live.staticflickr.com/65535/53098614375_0c135d8d58_k.jpg
                                          https://live.staticflickr.com/65535/53098213966_57b21911d5_k.jpg
                                          • ntxdaveN Offline
                                            ntxdave
                                            πŸ‘ πŸ‘
                                            Press F1...thank me later
                                            • 3 / 3
