    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 290.1k Views 17 Watching
    • mogrenM Offline
      mogren
      @pilou said:
      Je crois que oui, c'est ce qui Ă©tait dĂ©crit dans les posts prĂ©cĂ©dents 😉
      Il faut utiliser 2 composants l'un dans l'autre!
      I took two arch components, and placed one in the other.
      Oui effectivement pardon j'ai posé la question trop vite
      • mogrenM Offline
        mogren
        Ceci dit l'idéal n'est pas encore là
          I can't load the Double Arch (Arch in arch) of the previous page ! It's not 2017 version! 😉
          • halroachH Offline
            halroach
            Maybe this will work.
            The outer is a wallcutter. The inner is marked with 'Exclude' in the wallcutter options window so it won't interfere with cutting an opening.
            For the outer arch I deleted the glass, and did un-hide for the lines to get the stone appearance. A shortcut for doing this is to un-hide only for the left most 'stone'. Delete all the other stones and refresh. Then the left most stone copies it self all around.
            The inner window is a regular arch window scaled to the right position.
            The whole component as a whole won't scale together but you can always re-scale the inner component so it fits again.
            You will then need to add the horizontal lines on the sides...
            It's a quick solution for now. We'll see if we can make something like this in future updates...
            Please add/vote for this idea at https://flextools.cc/idea-push - There is a similar idea there which actually sparked the creation of the arch window! 😎
            [updated skp to 2017]
            Arch in Arch.skp
            FlexTools - Super Quick Windows, Doors, Slats...
            • halroachH Offline
              halroach
              Updated to 2017!
                Many Thanks! 👍
                • halroachH Offline
                  halroach
                  New Flex Bifold component released!
                  Learn more at https://flextools.cc/blog/flex-bifold/
                  https://flextools.cc/wp-content/uploads/2020/06/bifold_01_02e.gif
                  • jujuJ Offline
                    juju
                    Thanks for the info, seems like I'm up to date already. Also checked after the e-mail the other day, same thing, already up to date.
                    • halroachH Offline
                      halroach
                      Hello everyone, we're glad to introduce a new 3 Sash FlexSlider.
                      A Multi Sash FlexSlider is also in development, but till it's ready, if you need a quick 3 sash sliding window/door this component will do the work. It works just like the original 2 sash FlexSlider.
                      https://flextools.cc/wp-content/uploads/2020/07/Three-Sash-Slider_01.gif
                      • halroachH Offline
                        halroach
                        We'd like to thank Alex Oliver from SketchUp School for including FlexTools in the list of 10 extension every architect should know.
                        Check out all 10 extensions in the video: https://youtu.be/mtpEmbteWW8
                        • halroachH Offline
                          halroach
                          New update for ComponentFinder!
                          A new navigation sidebar, custom component toolbars, a better user interface and a lot more improvements!
                          More info at the blog: https://flextools.cc/blog/new-componentfinder-navigation-bar-and-toolbars/
                          If you find this update useful (or not!?) we want to hear you!
                          • halroachH Offline
                            halroach
                            New Flex Multi Slider released! 🎉
                            With any number of leaves you wish, 3 configurations, glass or solid panels - It will cover most of the sliding doors and windows you use day-to-day.
                            Check it out: https://flextools.cc/blog/new-flex-multi-slider/
                            https://flextools.cc/wp-content/uploads/2020/11/multi-slider_03_02-1000e.gif
                            • halroachH Offline
                              halroach
                              We haven't done any promotions for a whole year, but hey, today is Black Friday! 😄
                              ➡ https://flextools.cc/black-friday/
                              • halroachH Offline
                                halroach
                                Thanks to Justin for the video!
                                • halroachH Offline
                                  halroach
                                  Have you ever wished you could change default thumbnails with your own, see your rendered images instead of V-ray proxies? You can do that in ComponentFinder now!
                                  Assign your own thumbnails with custom images:
                                  Right Click > Set Custom Thumbnail > Choose a JPG or PNG
                                  The thumbnail image you assign will be automatically copied into the folder where the component is stored, and it will be named with the same name.
                                  Would you find custom thumbnails useful?
                                  • halroachH Offline
                                    halroach
                                    One more new feature in the latest update is the Recently Used tab.
                                    You can now reach your recently used components in one click!
                                    If you need to find the original folder where a recent component is stored:
                                    Right Click > ‘Open Containing Folder in a New Tab’
                                    Let us know what you think in the comments!
                                    • halroachH Offline
                                      halroach
                                      There are 3 things we can watch forever: fire burning, water falling, and speed modeling with FlexTools. 😄
                                      Thanks to Moshe Shemesh for sharing the video.
                                      • halroachH Offline
                                        halroach
                                        Introducing FlexFence!
                                        With this one dynamic component you can create roughly 70% of fences and railings out there, both wooden and metal style.
                                        Learn more in the blog: https://flextools.cc/blog/introducing-flexfence/
                                        https://flextools.cc/wp-content/uploads/2021/04/flexfence_examples_01e.gif
                                        • halroachH Offline
                                          halroach
                                          Flex Fences (and railings) can be easily joined together:
                                          In order to connect two FlexFences to form a corner:
                                          1. Place two fences in a 90 degree angle to each other, having them share the location of one of their posts.
                                          2. Hide one of the edge posts by clicking on it with the interact tool or through the options menu.
                                          3. If needed, you can choose to extend the picket positions of each fence to reach the other's post, rail or picket.
                                          https://flextools.cc/wp-content/uploads/2021/04/flexfence-connecting.gif
                                          Let us know what you think!
                                          • halroachH Offline
                                            halroach
                                            Check out Justin's new video about Easy Fencing in SketchUp!
                                            • 7 / 9
