    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 346.6k Views 17 Watching
    • mogrenM
      mogren
      @pilou said:
      Il semble qu'il a pris bonne note et donné une cool astuce! ☀ (voir 2 posts plus haut! 😉
      What I would like ☀
      • mogrenM
        mogren
        Exemple
          Hospices imaginaires ou ayant existés ?
          • mogrenM
            mogren
            Décor film
            • halroachH
              halroach
              @mogren said:
              What I would like ☀
              You should be able to get that with the following settings.
              'Inset' to move the window in/out in relation to the wall.
              'Frame - Depth' to get it as deep as you need.
              Play with the 'Frame - Width' setting to change what you wrote as Height in your picture.
              FlexTools - Super Quick Windows, Doors, Slats...
              • mogrenM
                mogren
                @halroach said:
                @mogren said:
                What I would like ☀
                [attachment=1:3clrfqal]<!-- ia1 -->flexwindow arch in arch settings.png<!-- ia1 -->[/attachment:3clrfqal]
                To follow your example we need two windows one above the other to have the wooden frame (see the red arrow)?
                  Je crois que oui, c'est ce qui était décrit dans les posts précédents 😉
                  Il faut utiliser 2 composants l'un dans l'autre!
                  I took two arch components, and placed one in the other.
                  • mogrenM
                    mogren
                    Oui effectivement pardon j'ai posé la question trop vite
                    • mogrenM
                      mogren
                      Ceci dit l'idéal n'est pas encore là
                        I can't load the Double Arch (Arch in arch) of the previous page ! It's not 2017 version! 😉
                        • halroachH
                          halroach
                          Maybe this will work.
                          The outer is a wallcutter. The inner is marked with 'Exclude' in the wallcutter options window so it won't interfere with cutting an opening.
                          For the outer arch I deleted the glass, and did un-hide for the lines to get the stone appearance. A shortcut for doing this is to un-hide only for the left most 'stone'. Delete all the other stones and refresh. Then the left most stone copies it self all around.
                          The inner window is a regular arch window scaled to the right position.
                          The whole component as a whole won't scale together but you can always re-scale the inner component so it fits again.
                          You will then need to add the horizontal lines on the sides...
                          It's a quick solution for now. We'll see if we can make something like this in future updates...
                          Please add/vote for this idea at https://flextools.cc/idea-push - There is a similar idea there which actually sparked the creation of the arch window! 😎
                          [updated skp to 2017]
                          Arch in Arch.skp
                          • halroachH
                            halroach
                            Updated to 2017!
                              Many Thanks! 👍
                              • halroachH
                                halroach
                                New Flex Bifold component released!
                                Learn more at https://flextools.cc/blog/flex-bifold/
                                https://flextools.cc/wp-content/uploads/2020/06/bifold_01_02e.gif
                                • jujuJ
                                  juju
                                  Thanks for the info, seems like I'm up to date already. Also checked after the e-mail the other day, same thing, already up to date.
                                  • halroachH
                                    halroach
                                    Hello everyone, we're glad to introduce a new 3 Sash FlexSlider.
                                    A Multi Sash FlexSlider is also in development, but till it's ready, if you need a quick 3 sash sliding window/door this component will do the work. It works just like the original 2 sash FlexSlider.
                                    https://flextools.cc/wp-content/uploads/2020/07/Three-Sash-Slider_01.gif
                                    • halroachH
                                      halroach
                                      We'd like to thank Alex Oliver from SketchUp School for including FlexTools in the list of 10 extension every architect should know.
                                      Check out all 10 extensions in the video: https://youtu.be/mtpEmbteWW8
                                      • halroachH
                                        halroach
                                        New update for ComponentFinder!
                                        A new navigation sidebar, custom component toolbars, a better user interface and a lot more improvements!
                                        More info at the blog: https://flextools.cc/blog/new-componentfinder-navigation-bar-and-toolbars/
                                        If you find this update useful (or not!?) we want to hear you!
                                        • halroachH
                                          halroach
                                          New Flex Multi Slider released! 🎉
                                          With any number of leaves you wish, 3 configurations, glass or solid panels - It will cover most of the sliding doors and windows you use day-to-day.
                                          Check it out: https://flextools.cc/blog/new-flex-multi-slider/
                                          https://flextools.cc/wp-content/uploads/2020/11/multi-slider_03_02-1000e.gif
                                          • halroachH
                                            halroach
                                            We haven't done any promotions for a whole year, but hey, today is Black Friday! 😄
                                            ➡ https://flextools.cc/black-friday/
                                            • 7 / 9
