    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 346.6k Views 17 Watching
      I can't load the Double Arch (Arch in arch) of the previous page ! It's not 2017 version! 😉
      • halroachH
        halroach
        Maybe this will work.
        I took two arch components, and placed one in the other.
        The outer is a wallcutter. The inner is marked with 'Exclude' in the wallcutter options window so it won't interfere with cutting an opening.
        For the outer arch I deleted the glass, and did un-hide for the lines to get the stone appearance. A shortcut for doing this is to un-hide only for the left most 'stone'. Delete all the other stones and refresh. Then the left most stone copies it self all around.
        The inner window is a regular arch window scaled to the right position.
        The whole component as a whole won't scale together but you can always re-scale the inner component so it fits again.
        You will then need to add the horizontal lines on the sides...
        It's a quick solution for now. We'll see if we can make something like this in future updates...
        Please add/vote for this idea at https://flextools.cc/idea-push - There is a similar idea there which actually sparked the creation of the arch window! 😎
        [updated skp to 2017]
        Arch in Arch.skp
        FlexTools - Super Quick Windows, Doors, Slats...
        • halroachH
          halroach
          Updated to 2017!
            Many Thanks! 👍
            • halroachH
              halroach
              New Flex Bifold component released!
              Learn more at https://flextools.cc/blog/flex-bifold/
              https://flextools.cc/wp-content/uploads/2020/06/bifold_01_02e.gif
              • jujuJ
                juju
                Thanks for the info, seems like I'm up to date already. Also checked after the e-mail the other day, same thing, already up to date.
                • halroachH
                  halroach
                  Hello everyone, we're glad to introduce a new 3 Sash FlexSlider.
                  A Multi Sash FlexSlider is also in development, but till it's ready, if you need a quick 3 sash sliding window/door this component will do the work. It works just like the original 2 sash FlexSlider.
                  https://flextools.cc/wp-content/uploads/2020/07/Three-Sash-Slider_01.gif
                  • halroachH
                    halroach
                    We'd like to thank Alex Oliver from SketchUp School for including FlexTools in the list of 10 extension every architect should know.
                    Check out all 10 extensions in the video: https://youtu.be/mtpEmbteWW8
                    • halroachH
                      halroach
                      New update for ComponentFinder!
                      A new navigation sidebar, custom component toolbars, a better user interface and a lot more improvements!
                      More info at the blog: https://flextools.cc/blog/new-componentfinder-navigation-bar-and-toolbars/
                      If you find this update useful (or not!?) we want to hear you!
                      • halroachH
                        halroach
                        New Flex Multi Slider released! 🎉
                        With any number of leaves you wish, 3 configurations, glass or solid panels - It will cover most of the sliding doors and windows you use day-to-day.
                        Check it out: https://flextools.cc/blog/new-flex-multi-slider/
                        https://flextools.cc/wp-content/uploads/2020/11/multi-slider_03_02-1000e.gif
                        • halroachH
                          halroach
                          We haven't done any promotions for a whole year, but hey, today is Black Friday! 😄
                          ➡ https://flextools.cc/black-friday/
                          • halroachH
                            halroach
                            Thanks to Justin for the video!
                            • halroachH
                              halroach
                              Have you ever wished you could change default thumbnails with your own, see your rendered images instead of V-ray proxies? You can do that in ComponentFinder now!
                              Assign your own thumbnails with custom images:
                              Right Click > Set Custom Thumbnail > Choose a JPG or PNG
                              The thumbnail image you assign will be automatically copied into the folder where the component is stored, and it will be named with the same name.
                              Would you find custom thumbnails useful?
                              • halroachH
                                halroach
                                One more new feature in the latest update is the Recently Used tab.
                                You can now reach your recently used components in one click!
                                If you need to find the original folder where a recent component is stored:
                                Right Click > ‘Open Containing Folder in a New Tab’
                                Let us know what you think in the comments!
                                • halroachH
                                  halroach
                                  There are 3 things we can watch forever: fire burning, water falling, and speed modeling with FlexTools. 😄
                                  Thanks to Moshe Shemesh for sharing the video.
                                  • halroachH
                                    halroach
                                    Introducing FlexFence!
                                    With this one dynamic component you can create roughly 70% of fences and railings out there, both wooden and metal style.
                                    Learn more in the blog: https://flextools.cc/blog/introducing-flexfence/
                                    https://flextools.cc/wp-content/uploads/2021/04/flexfence_examples_01e.gif
                                    • halroachH
                                      halroach
                                      Flex Fences (and railings) can be easily joined together:
                                      In order to connect two FlexFences to form a corner:
                                      1. Place two fences in a 90 degree angle to each other, having them share the location of one of their posts.
                                      2. Hide one of the edge posts by clicking on it with the interact tool or through the options menu.
                                      3. If needed, you can choose to extend the picket positions of each fence to reach the other's post, rail or picket.
                                      https://flextools.cc/wp-content/uploads/2021/04/flexfence-connecting.gif
                                      Let us know what you think!
                                      • halroachH
                                        halroach
                                        Check out Justin's new video about Easy Fencing in SketchUp!
                                        • halroachH
                                          halroach
                                          We thought it would be helpful if there was a collection of ready-to-use dynamic fences and railings. So we took some popular fences and railings and recreated them with the FlexFence component!
                                          Each Flex Fence example can be customized further to best suit your design, and then saved for later immediate use.
                                          Download the collection here
                                          What other fences/railings would you like to have dynamic?
                                          Send us pictures or skp models of your go-to fence and railing types! 😄
                                          • P
                                            pibuz
                                            GIGA thanks!!!!
                                            EDIT
                                            is there some sort of pre-setting to be choosed before using these DCs?
                                            Or is FlexTools PRO needed?
                                            I only use component finder, and using these fences as "common" DCs doesn't work at all for me..
                                            WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                            • 7 / 9
