    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 342.8k Views 17 Watching
    • mogrenM
      mogren
      @halroach said:
      @mogren said:
      What I would like ☀
      You should be able to get that with the following settings.
      'Inset' to move the window in/out in relation to the wall.
      'Frame - Depth' to get it as deep as you need.
      Play with the 'Frame - Width' setting to change what you wrote as Height in your picture.
      [attachment=1:3clrfqal]<!-- ia1 -->flexwindow arch in arch settings.png<!-- ia1 -->[/attachment:3clrfqal]
      To follow your example we need two windows one above the other to have the wooden frame (see the red arrow)?
        Je crois que oui, c'est ce qui était décrit dans les posts précédents 😉
        Il faut utiliser 2 composants l'un dans l'autre!
        I took two arch components, and placed one in the other.
        • mogrenM
          mogren
          Oui effectivement pardon j'ai posé la question trop vite
          • mogrenM
            mogren
            Ceci dit l'idéal n'est pas encore là
              I can't load the Double Arch (Arch in arch) of the previous page ! It's not 2017 version! 😉
              • halroachH
                halroach
                Maybe this will work.
                The outer is a wallcutter. The inner is marked with 'Exclude' in the wallcutter options window so it won't interfere with cutting an opening.
                For the outer arch I deleted the glass, and did un-hide for the lines to get the stone appearance. A shortcut for doing this is to un-hide only for the left most 'stone'. Delete all the other stones and refresh. Then the left most stone copies it self all around.
                The inner window is a regular arch window scaled to the right position.
                The whole component as a whole won't scale together but you can always re-scale the inner component so it fits again.
                You will then need to add the horizontal lines on the sides...
                It's a quick solution for now. We'll see if we can make something like this in future updates...
                Please add/vote for this idea at https://flextools.cc/idea-push - There is a similar idea there which actually sparked the creation of the arch window! 😎
                [updated skp to 2017]
                Arch in Arch.skp
                FlexTools - Super Quick Windows, Doors, Slats...
                • halroachH
                  halroach
                  Updated to 2017!
                    Many Thanks! 👍
                    • halroachH
                      halroach
                      New Flex Bifold component released!
                      Learn more at https://flextools.cc/blog/flex-bifold/
                      https://flextools.cc/wp-content/uploads/2020/06/bifold_01_02e.gif
                      • jujuJ
                        juju
                        Thanks for the info, seems like I'm up to date already. Also checked after the e-mail the other day, same thing, already up to date.
                        • halroachH
                          halroach
                          Hello everyone, we're glad to introduce a new 3 Sash FlexSlider.
                          A Multi Sash FlexSlider is also in development, but till it's ready, if you need a quick 3 sash sliding window/door this component will do the work. It works just like the original 2 sash FlexSlider.
                          https://flextools.cc/wp-content/uploads/2020/07/Three-Sash-Slider_01.gif
                          • halroachH
                            halroach
                            We'd like to thank Alex Oliver from SketchUp School for including FlexTools in the list of 10 extension every architect should know.
                            Check out all 10 extensions in the video: https://youtu.be/mtpEmbteWW8
                            • halroachH
                              halroach
                              New update for ComponentFinder!
                              A new navigation sidebar, custom component toolbars, a better user interface and a lot more improvements!
                              More info at the blog: https://flextools.cc/blog/new-componentfinder-navigation-bar-and-toolbars/
                              If you find this update useful (or not!?) we want to hear you!
                              • halroachH
                                halroach
                                New Flex Multi Slider released! 🎉
                                With any number of leaves you wish, 3 configurations, glass or solid panels - It will cover most of the sliding doors and windows you use day-to-day.
                                Check it out: https://flextools.cc/blog/new-flex-multi-slider/
                                https://flextools.cc/wp-content/uploads/2020/11/multi-slider_03_02-1000e.gif
                                • halroachH
                                  halroach
                                  We haven't done any promotions for a whole year, but hey, today is Black Friday! 😄
                                  ➡ https://flextools.cc/black-friday/
                                  • halroachH
                                    halroach
                                    Thanks to Justin for the video!
                                    • halroachH
                                      halroach
                                      Have you ever wished you could change default thumbnails with your own, see your rendered images instead of V-ray proxies? You can do that in ComponentFinder now!
                                      Assign your own thumbnails with custom images:
                                      Right Click > Set Custom Thumbnail > Choose a JPG or PNG
                                      The thumbnail image you assign will be automatically copied into the folder where the component is stored, and it will be named with the same name.
                                      Would you find custom thumbnails useful?
                                      • halroachH
                                        halroach
                                        One more new feature in the latest update is the Recently Used tab.
                                        You can now reach your recently used components in one click!
                                        If you need to find the original folder where a recent component is stored:
                                        Right Click > ‘Open Containing Folder in a New Tab’
                                        Let us know what you think in the comments!
                                        • halroachH
                                          halroach
                                          There are 3 things we can watch forever: fire burning, water falling, and speed modeling with FlexTools. 😄
                                          Thanks to Moshe Shemesh for sharing the video.
                                          • halroachH
                                            halroach
                                            Introducing FlexFence!
                                            With this one dynamic component you can create roughly 70% of fences and railings out there, both wooden and metal style.
                                            Learn more in the blog: https://flextools.cc/blog/introducing-flexfence/
                                            https://flextools.cc/wp-content/uploads/2021/04/flexfence_examples_01e.gif
                                            • 7 / 9
