    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 415.2k Views 92 Watching
    • CadFatherC Offline
      CadFather
      when i choose the select tools from the menu, I only get the rectangle selection.
      works fine from the panel though
      (fantastic update btw)
        Menu or toolbar? Exactly what item do you select? Can you do a screenshot for me?
          CadFather
          Menu. same thing if i assign a shortcut to them (polygon, freehand, etc)
            Ah! I see the same thing. That's a bug - thank you for reporting!
            • cmeedC Offline
              cmeed
              this has probably been asked before - can I move the gizmo and have it snap to a point? in 10 years of questions I think this has been asked.... 'negative' will be the answer.
              maybe i need to ask why cant it?
              cheers
              c
                Not so.
                Right click on the gizmo, choose the option and hold Shift while clicking to place it.
                Click on the picture
                  Because it's not been entirely clear what to snap to. The user grabs hold of the gizmo which is offset from the gizmo origin, so is snapping supposed to snap the origin to the point snapped? Or the point grabbed?
                  There's been some conversations about this - this thread for instance: http://sketchucation.com/forums/viewtopic.php?f=323&t=66039#p606094
                  Snapping is described to relate relative to the gizmo origin, and with improved control of setting the origin.
                  If you have your own idea of how snapping should work with the Gizmo I'm happy to hear it. I'm not sure everyone has the same expectations on how this would work.
                  Because of that the separate Move/Rotate/Scale tools has been the main means of precision adjustments. While the gizmo is more eyeballing it.
                  I'd be curious to hear why you prefer the Gizmo to snap as oppose to using the separate Move/Rotate/Scale tools. (Maybe there's some improvements with them that you achieve the same thing?)
                    Oh wait, did I read that correctly?
                    Did you talk about snapping while positioning the Gizmo? Or snapping while using the Gizmo Move?
                    • N Offline
                      nlipovac
                      Is it possible to add option, i.e. hold CTRL, when using vertex slide to copy moved vertices and this way I can add loops without exiting Vertex tools?
                      And one more wild one, plus if I hold Shift I get that copy to be parallel to ones I have made copy off.
                        It's already on the list for consideration.
                        Would this be different than switching Vertex Slide to Slide by Offset instead of Slide by Percent?
                        https://evilsoftwareempire.com/vertex-tools/manual/editing#vertex_slide
                        • N Offline
                          nlipovac
                          Great for this one, would be very handy.
                          As for this one, I mean that when I select one cut loop and use Vertex slide to make a copy it would maintain parallel to one I made copy off and not conform to loop or edge I am pushing it to.
                          Hope it makes sense.
                          Also of the topic, I never learned to make those short gifs, what do you use for that?
                            I don't fully manage to visualize what you are asking for. Could you illustrate it by mocking up the desired result compared to existing Offset modes?
                            I use ScreenPresso, though it's not free. Though there is a number of free ones out there. This one looks interesting: https://www.screentogif.com/
                            • N Offline
                              nlipovac
                              Sure, here is two examples, one when I copy and move vertex from center loop and one when I copy and move from edge loop. If not mistaken, at moment we get only proprtional movement.
                              Parallel to the edge
                              Parallel to the middle
                              Proportional
                                If you switch you Slide By Offset I think you will get what you are looking for. (Except that it moves and doesn't copy the loop.)
                                • N Offline
                                  nlipovac
                                  [attachment=0:rmfcreq0]<!-- ia0 -->2020-08-19_21h27_42.gif<!-- ia0 -->[/attachment:rmfcreq0]
                                  This would be my mistake then, thank you for clarification. πŸ‘
                                  Just add my self shortcuts for those two.
                                  I am still upvoting on adding an option to copy and move selected vertex.
                                  Loving new tools! πŸ‘
                                    Click this link for see the video! πŸ€“
                                    • E Offline
                                      Einstein
                                      Hi! May I have a couple suggestions for VT2 development?
                                      • more SketchUp-native-like manner of manipulating gizmo's handles. What I mean is that you have to click+drag gizmo's arrow to move a vertex and only then type a precise value. I wish I could click, let mouse go, type value and hit ENTER. This would be more "sketchuppish" behaviour. Maybe there could be a button to choose behaviour.
                                        Also, current behaviour leads to unwanted situations like: when you precisely adjust radius of your soft selection, then drag a gizmo's handle/arrow to move verts, the selection gets updated before you type desired value of move. I wish I could lock/freeze soft selection so it wouldn't update after a transformation is performed - only when I decide to manually change my selection. This could be an adjustable behaviour too and it would help a lot with precise modelling.
                                      • bevel vertices with more segments (like Fredo Corner but Fredo Corner doesn't work with flat faces)
                                      • BUGFIX - when you bevel vertices of a flat face, sometimes the face gets removed (but I'm unable to reproduce the bug now)
                                      • also make possible to bevel verts without manually dragging them, just by typing value and hitting ENTER
                                      • move vertices with snapping (to other vertices, edges, edge midpoints, guides)
                                      • soft selection profile edit and profile presets, like in Blender: dome, pinch, random etc. I know they are on the to-do list, just can't wait for them! πŸ˜„
                                        Rafhinha
                                        Hello, how are you..
                                        I bought Vertex 1 and right after that Vertex 2 was launched. When I install Vertex 2 and put my key the following message appears
                                        "There was an unexpected server error while trying to active the license. Please try again in a few moments. If the problem persists, please contact support."
                                        I've tried it several times, already install Vertex 1.
                                        At some point Vertex 2 was released I downloaded, installed and it worked, but it appeared that it was trial trial version
                                        My sketchUp 2020
                                        windows 10
                                        I am downloading Vertex 2 from the email I received with the license and even so it says it is Trial experied
                                        • E Offline
                                          Einstein
                                          If you only bought Vertex Tools 1 licence, it doesn't work with Vertex Tools 2. 2nd version is way more elaborate tool and I guess that's why the Author charges more for VT2.
                                          • E Offline
                                            Einstein
                                            What was added in v2.0.3?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 33
                                            • 34
                                            • 12 / 34
