    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 470.0k Views 92 Watching
      @nlipovac said:
      Is it possible to add option, i.e. hold CTRL, when using vertex slide to copy moved vertices and this way I can add loops without exiting Vertex tools?
      It's already on the list for consideration.
      @nlipovac said:
      And one more wild one, plus if I hold Shift I get that copy to be parallel to ones I have made copy off.
      Would this be different than switching Vertex Slide to Slide by Offset instead of Slide by Percent?
      https://evilsoftwareempire.com/vertex-tools/manual/editing#vertex_slide
      • N Offline
        nlipovac
        Great for this one, would be very handy.
        As for this one, I mean that when I select one cut loop and use Vertex slide to make a copy it would maintain parallel to one I made copy off and not conform to loop or edge I am pushing it to.
        Hope it makes sense.
        Also of the topic, I never learned to make those short gifs, what do you use for that?
          I don't fully manage to visualize what you are asking for. Could you illustrate it by mocking up the desired result compared to existing Offset modes?
          I use ScreenPresso, though it's not free. Though there is a number of free ones out there. This one looks interesting: https://www.screentogif.com/
          • N Offline
            nlipovac
            Sure, here is two examples, one when I copy and move vertex from center loop and one when I copy and move from edge loop. If not mistaken, at moment we get only proprtional movement.
            Parallel to the edge
            Parallel to the middle
            Proportional
              If you switch you Slide By Offset I think you will get what you are looking for. (Except that it moves and doesn't copy the loop.)
              • N Offline
                nlipovac
                [attachment=0:rmfcreq0]<!-- ia0 -->2020-08-19_21h27_42.gif<!-- ia0 -->[/attachment:rmfcreq0]
                This would be my mistake then, thank you for clarification. πŸ‘
                Just add my self shortcuts for those two.
                I am still upvoting on adding an option to copy and move selected vertex.
                Loving new tools! πŸ‘
                  Click this link for see the video! πŸ€“
                  • E Offline
                    Einstein
                    Hi! May I have a couple suggestions for VT2 development?
                    • more SketchUp-native-like manner of manipulating gizmo's handles. What I mean is that you have to click+drag gizmo's arrow to move a vertex and only then type a precise value. I wish I could click, let mouse go, type value and hit ENTER. This would be more "sketchuppish" behaviour. Maybe there could be a button to choose behaviour.
                      Also, current behaviour leads to unwanted situations like: when you precisely adjust radius of your soft selection, then drag a gizmo's handle/arrow to move verts, the selection gets updated before you type desired value of move. I wish I could lock/freeze soft selection so it wouldn't update after a transformation is performed - only when I decide to manually change my selection. This could be an adjustable behaviour too and it would help a lot with precise modelling.
                    • bevel vertices with more segments (like Fredo Corner but Fredo Corner doesn't work with flat faces)
                    • BUGFIX - when you bevel vertices of a flat face, sometimes the face gets removed (but I'm unable to reproduce the bug now)
                    • also make possible to bevel verts without manually dragging them, just by typing value and hitting ENTER
                    • move vertices with snapping (to other vertices, edges, edge midpoints, guides)
                    • soft selection profile edit and profile presets, like in Blender: dome, pinch, random etc. I know they are on the to-do list, just can't wait for them! πŸ˜„
                      Rafhinha
                      Hello, how are you..
                      I bought Vertex 1 and right after that Vertex 2 was launched. When I install Vertex 2 and put my key the following message appears
                      "There was an unexpected server error while trying to active the license. Please try again in a few moments. If the problem persists, please contact support."
                      I've tried it several times, already install Vertex 1.
                      At some point Vertex 2 was released I downloaded, installed and it worked, but it appeared that it was trial trial version
                      My sketchUp 2020
                      windows 10
                      I am downloading Vertex 2 from the email I received with the license and even so it says it is Trial experied
                      • E Offline
                        Einstein
                        If you only bought Vertex Tools 1 licence, it doesn't work with Vertex Tools 2. 2nd version is way more elaborate tool and I guess that's why the Author charges more for VT2.
                        • E Offline
                          Einstein
                          What was added in v2.0.3?
                          • tuna1957T Offline
                            tuna1957
                            Go back to page 20 of this thread. There’s a short video posted that goes over the cool new stuff. A lot has been added πŸ‘
                            Just a thought for the admins... maybe this thread could be split ? One for all the existing and new Vertex1 questions and a new thread for Vertex2 starting with Thomas’s Vertex2 announcement ?
                            • E Offline
                              Einstein
                              tuna1957, I am asking exactly about the latest version 2.0.3, not 2.0.0. The changelog is not very accurate.
                                MEgiveup
                                I'm not sure where to ask this but here goes. I've installed Vertex Tools and have a beginners question. I can't seem to get the soft selection to work. I make a selection and type in a distance and nothing changes and the soft-selected count says zero. I've tried typing in small increments and large increments but nothing changes. What am I missing?
                                • E Offline
                                  Einstein
                                  I was thinking of how to achieve controlled one-axis scale with vertex tools 2.
                                  As far as I know, we currently have two methods of scaling, each having its limitations:
                                  • the "gizmo scale" where we can scale vertices in one axis (non-uniform scale) but cannot choose to scale origin - it is arbitrary set to center of selection,
                                  • the scale tool available from toolbar icon, where we can scale with more precision: pick scaling origin, then source and target position. Very handy, but only lets us do uniform scale.
                                    It would be very cool to combine advantages of both methods and have a precise, non-uniform scaling tool with soft selection.
                                  PS Still looking forward to custom falloff and more falloff preset (Γ  la Blender proportional editing) πŸ˜„
                                  PS 2 From time to time I get a message that my VT2 licence is invalid, then I have to type my key again. It is not a big issue as it happened a few times this year (firstly with VT, now with VT 2), but I thought I would mention it.
                                    I love to hear suggestions! (Sorry for the late reply - the last bit of 2020 was a rough one for me. Had no capacity to stay up to date with the forums.)
                                    You can do these accurate Move/Scale/Rotate actions with the dedicated tools.
                                    I hadn't thought of allowing a click-release behaviour of the gizmo. But I'll add that to the list of things to look into.
                                    Noted.
                                    Can you elaborate on what doesn't work? Example screenshots?
                                    If you can reliably repro I'd love to look into it.
                                    So; select vertices, activate Bevel tool and immediately type into the VCB?
                                    You mean with the Gizmo? Because the Move tool does this. With the gizmo it's not straight forward to how snapping would work as you pick a point in the gizmo and not the mesh.
                                    It will come πŸ˜„
                                      Support for Ruby 2.7 that shipped with SU2021.0.
                                        Does it happen with any model?
                                        Can you share an example model?
                                          @einstein said:
                                          With the gizmo you can move the gizmo to a custom location before you scale.
                                          Adding a feature request for non-uniform scale with the Scale Tool.
                                          That's strange indeed. I've not heard of that. Almost sounds like something is resetting files on your machine. Do you have software that cleans up your machine?
                                            Builder54
                                            This is my first post on the site even though I've been using Sketchup for a few years. I use Vertex Tools quite a lot but I'm having problems with it. Apart from the occasional bug splat, I've posted here a gif of how VT2 freezes, and selection shuts down. In the gif you'll see my mouse is unable to select/highlight anything. Once I get out of the tools environment, I can highlight an area in blue then reactivate the tool. But still nothing changes until I move the gizmo. That for some reason allows me to begin selecting other vertices again. Any thoughts on what I can do to fix this? Or is it a known bug?
                                            thanks
                                            "Don't be afraid of working hard. There are No shortcuts to mastering something."
                                            Robh Ruppel
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 31 / 34
